    LoPy pcb female connector
    hardwarelopypcbconnectors
    4 Posts 2 Posters 1.7k Views 2 Watching
    • cocoaC Offline
      cocoa
      Hi folks,
      I can't find the right pcb female connector for LoPy (14 pos, SIL, 2.54mm, Vertical, through hole).
      The lopy's male pins are too short to stay firmly inserted in a standard 2.54mm sil connector.
      I'm searching a low profile connector similar to the one used on Pycom Expansion board 2.0.
      Someone can give me the Mouser or Digikey order code ?
      Any help greatly appreciated.
        TCB @cocoa
        @cocoa try these at Adafruit.
        https://www.adafruit.com/product/2940
        I have not used them but like you I was looking and could not find any others
        cocoaC 1 Reply Last reply Reply Quote 0
          TCB
          Sorry just realized these were not 14 position.
          I measured the header height on my Pysense and its 5mm
          So feeling a tad guilty I did a Google for "Female header 14 2.54 mm 5.00" and found this item which I think should work.
          https://www.gct.co/connector/bg095#.WdiHp2iCybg
          There were a bunch of others as well but this one had good documentation and I did not know where you are geographically located.
          If you get one let me us all know if it works
          Cheers
          • cocoaC Offline
            cocoa @TCB
            @tcb Thank you!
