    Bluetooth services is not started
    bluetoothserviceslopynot started
    15 Posts 4 Posters 3.2k Views 4 Watching
    • Nagarjuna ReddyN Offline
      Nagarjuna Reddy
      good afternoon i have one problem at server side
      services=conn.services() its not working what is the problem
      client.py
      def ble_reciever(self):
          bluetooth = Bluetooth()
          print("Scanning 4509 client")
          bluetooth.start_scan(-1)
              adv = bluetooth.get_adv()
              if adv and bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'LoPy':
                  print("connecting rr Lopy in 4509 client")
                  conn = bluetooth.connect(adv.mac)
                  print("connectede w Lopy in 4509 client")
                      print("getrdasdf  servicess..")
                      services = conn.services()
                      print("get servicess..")
                      for service in services:
                          #time.sleep(3)
                          print("start reading..")
                          if type(service.uuid()) == bytes:
                              print('Reading chars from service = {}'.format(service.uuid()))
                              print('Reading chars from service = %x' % service.uuid())
                          chars = service.characteristics()
                          for char in chars:
                              if (char.properties() & Bluetooth.PROP_READ):
                                  print('char {} value = {}'.format(char.uuid(), char.read()))
                  conn.disconnect()
                  print("Disconnected 4509 client")
                  break
                  time.sleep(0.050)
      Ch.nagarjuna reddy
        livius @Nagarjuna Reddy
        @nagarjuna-reddy said in Bluetooth services is not started:
        why you connect twice?
        First before loop next inside loop?
        Nagarjuna ReddyN 2 Replies Last reply Reply Quote 0
          Nagarjuna Reddy @livius
          @livius
          i am also check that no working
          Ch.nagarjuna reddy
          Nagarjuna ReddyN 1 Reply Last reply Reply Quote 0
            Nagarjuna Reddy @Nagarjuna Reddy
            @nagarjuna-reddy
            print("get service......") why its not printing
            Ch.nagarjuna reddy
            L 1 Reply Last reply Reply Quote 1
              @livius
              hi livius iam checking what you said that but not working so please help me
              program
                      #if adv:
                          #print("Found adv in 4509 client")
                          # try to get the complete name
                          #print(bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL))
                          # try to get the manufacturer data (Apple's iBeacon data is sent here)
                          #print(binascii.hexlify(bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_MANUFACTURER_DATA)))
                          print("connected Lopy in 4509 client")
                                  #time.sleep(3)
                                  for char in chars:
                          conn.disconnect()
                          break
                          time.sleep(0.050)
              def ble_transmitter(self):
                  print('Advertising Bluetooth...')
                  bluetooth.set_advertisement(name='LoPy', service_uuid=b'1234567890abcdef')
                  def conn_cb (bt_o):
                      events = bt_o.events()
                      if  events & Bluetooth.CLIENT_CONNECTED:
                          print("Client connected")
                          print("Client disconnected")
                  bluetooth.advertise(True)
                  #Create service and characteristic
                  srv1 = bluetooth.service(uuid='0000000000000000', isprimary=True)
                  chr1 = srv1.characteristic(uuid='0000000000000002', properties=Bluetooth.PROP_INDICATE | Bluetooth.PROP_BROADCAST | Bluetooth.PROP_READ | Bluetooth.PROP_NOTIFY, value='InitialValue')
                  #Create callback for read events on the characteristic
                  def char1_cb(chr):
                      events = chr.events()
                      if events & Bluetooth.CHAR_READ_EVENT :
                          print('Bluetooth.CHAR_READ_EVENT')
                  chr1.callback(trigger=Bluetooth.CHAR_READ_EVENT, handler=char1_cb)
                  #Update the characteristic value very few seconds
                  #i=0
                      val = 'Value{}'.format(i)
                      print('Setting value: {}'.format(val))
                      chr1.value(val) #Set the characteristic value - should trigger notification is a client has registered for notifications
                      time.sleep(3)
                      i+=1
              Ch.nagarjuna reddy
                @nagarjuna-reddy
                you removed it before loop but better here if you remove it from loop
                only connect before (you have only one disconnect)
                  st3ty
                  I have the exact same problem.
                  I am trying to connect two Wipys via bluetooth.
                  I get the connection on both sides.
                  But the programm frezzes with the line services = connection.services()
                  Is this a bug or is it a problem with my code?
                  from network import Bluetooth
                  import binascii
                  adv = None
                      if adv and bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL) == 'WiPy':
                          if bluetooth.isscanning():
                              bluetooth.stop_scan()
                          try:
                              connection = bluetooth.connect(adv.mac)
                              while not connection.isconnected():
                                  pass
                              if connection.isconnected():
                                  print("Connected to device with addr = {}".format( binascii.hexlify( adv.mac ) ) )
                                  print("and name = ", bluetooth.resolve_adv_data(adv.data, Bluetooth.ADV_NAME_CMPL))
                                  break
                          except:
                              # start scanning again
                              continue
                  print('test1')
                  print('test2')
                    @livius
                    i cannot understand livius so edit my code and send to me please........
                    Ch.nagarjuna reddy
                      i only mean that you must connect only once and for one connect you need one disconnect
                      below "fixed" code in this matter
                      i have also added small sleep time - look if it help somehow with your problem (i do not tested this self)
                      			#if adv:
                      					time.sleep(0.050)
                      					for char in chars:
                      				conn.disconnect()
                      				break
                      				time.sleep(0.050)
                      		def conn_cb (bt_o):
                      		def char1_cb(chr):
                      		#i=0
                      			time.sleep(3)
                      			i+=1
                        @livius said in Bluetooth services is not started:
                        transmitter run in one LoPy and reciever LoPy is connected but not get any values from transmitter side i want to
                        bolded text
                        i=0
                        time.sleep(3)
                        i+=1
                        this is a transmitter side loop this loop values is getting to once connected reciever is recieved that for loop values but in their not iam getting so please solve my problem
                        Ch.nagarjuna reddy
                          @nagarjuna-reddy
                          livius you already edit my code but same problem i am getting what iam expected output is sending before message so please check and replay it arguently.
                          Ch.nagarjuna reddy
                            @livius
                            ivius
                            you already edit my code but same problem i am getting what iam expected output is sending before message so please check and replay it urgently.
                            Ch.nagarjuna reddy
                              Nagarjuna Reddy @st3ty
                              @st3ty
                              hi i am also have a same problem if you success to execute please send your code to me.
                              Thank you
                              Ch.nagarjuna reddy
                                jmahesh @Nagarjuna Reddy
                                conn.disconnect()
                                put a sleep time before service loop, that will make the services to read. I tried and it is working.
                                time.sleep(1.0);
                                print('sleep resumed', conn.services())
                                print(services)
                                for service in conn.services():
                                  st3ty @jmahesh
                                  @jmahesh
                                  I tried it too and it's working.
                                  Thank You!
