    New firmware release v1.12.0.b1 (Sigfox and LoRa coexistency on the FiPy)
    firmware
    17 Posts 6 Posters 2.9k Views 6 Watching
      daniel
      This release mainly adds Sigfox and LoRa coexistency on the FiPy. There are some additional bug fixes included:
      • esp32: LoRa+Sigfox coexistency on the FiPy.
      • esp32: Allow pin interrupts to be triggered even when the cache is disabled.
      • esp32: Do not allow timer alarms ISR to run with the cache disabled.
        Otherwise the CPU crashes when writing to flash and the interrupt triggers.
      • esp32: Solve BLE hang when searching for services.
      • esp32: Correct behaviour of Alarm.callback(None). The alarm is correctly cancelled now.
      • modpycom.c/pulses_get(): prevent lock-up at long pulses. Thanks to @robert-hh.
      • esp32: Use spi_flash_get_chip_size() to determine the flash size. Thanks to @robert-hh.
      Cheers,
      Daniel
      robert-hhR L 2 Replies Last reply Reply Quote 2
      • X Offline
        Xykon administrators
        Just in case anyone needs it, I have updated the download links under downgrading for advanced users to include the previous 1.10.2.b1 major release.
        I am working on a new firmware update tool that will have downgrade functionality. You should see another beta being released later this week.
        Christian Ehlers
          robert-hh @daniel
          @daniel uos.uname causes a core dump on FiPy. See https://github.com/pycom/pycom-micropython-sigfox/issues/118
            daniel
            @robert-hh thanks. Found the cause. Will fix ASAP.
              danielm
              @Xykon
              Can this currently developed upgrade/downgrade tool be used to flash custom image as well?
              • X Offline
                Xykon administrators @danielm
                @danielm You can do that with the command line version of the tool. I will post some more details about that with the next beta release.
                Christian Ehlers
                • N Offline
                  naveen
                  Why am I getting sigfox.id() and sigfox.pac() as b'ffffffff' and b'ffffffffffffffff' respectively?
                    daniel
                    @naveen did you get the Sigfox ID and PAC printed on the screen after the updater tool completed?
                    • N Offline
                      naveen
                      I am getting the message shown below but no id or pac info:
                      Result:
                      Your device was successfully updated!
                      Please remove the wire and reset the board.
                        daniel
                        After updating and doing:
                        import os
                        os.uname()
                        What do you get?
                        Cheers,
                        Daniel
                        • N Offline
                          naveen
                          Everytime I run "os.uname()", FiPy disconnects and only gives partial output as below:
                          (sysname='FiPy', nodename='FiPy', release='1.12.0.b1', version='v1.8.6-849-fcbbfe3 on 2018-01-03', machine='FiPy with ESP32' , lorawan=' > Failed to connect (Connection was reset)
                            daniel
                            @naveen please let us know your WLAN mac address so that we can reset and you can get your Sigfox ID and PAC again.
                            Please run:
                            import binascii
                            from network import WLAN
                            print(binascii.hexlify(WLAN().mac()))
                            And let us know your MAC address. Thanks.
                            Cheers,
                            Daniel
                            • N Offline
                              naveen
                              Mac address: <removed by admin>
                              X 1 Reply Last reply Reply Quote 1
                              • X Offline
                                Xykon administrators @naveen
                                @naveen It seems your sigfox credentials haven't been properly generated during the initial upgrade/device registration.
                                I have removed your device... can you please try to upgrade/register again?
                                Christian Ehlers
                                • N Offline
                                  naveen
                                  OK, I am trying to upgrade/register again. Now I see an option "Country Selection" and I choose "Japan" where I live. Next is "SigFox region selection" but I do not find "Japan" in the available options.
                                    daniel
                                    @naveen we will add Japan with the next release of the updater tool. In the meantime, please select Europe as Sigfox region. Thanks.
                                      livius @daniel
                                      @daniel
                                      Wipy2
                                      I give another try with recent software compared to 1.7.2.b1 {which is stablest for me for wipy2}.
                                      After flash (today):
                                      1. connection to router give me timeout (30seconds) but if i ignore this i can connect to the socket in the network - i use static ip setting.
                                      2. i2c (i2c=I2C(0, I2C.MASTER, baudrate=100000, pins=("P9", "P10")))
                                      • bh1750 ok,
                                      • pcf8574 ok
                                      • read from bmp180 read only 0 for preasure but temperature is ok
                                      flashed 3 times and tested 30 times with removing cables (5 times and also simple reset 5 for every flash).
                                      downgraded to 1.7.2.b1 all work ok.
                                      I must bring back my logic analyser to see issue on i2c but maybe you have some hint here?
                                      And also what can be the reason of issue from point 1?
