    SDI-12 Soil Moisture Probe Help
    sdi-12rs485lopy
    38 Posts 4 Posters 4.0k Views 4 Watching
      jimpower
      I have a large soil moisture probe which uses SDI-12 protocol :( I have connected my LoPy to an expansion board then into a RS-485 Breakout board like below.
      Here is my code just to test the output of a SDI-12 request
      import network
      import gc
      import utime
      from machine import RTC
      from machine import ADC
      from machine import Pin
      from machine import UART
      from network import LoRa
      execfile('/flash/Network/LoRa.py')
      f_device = open('/flash/Config/Device_Details.txt', 'r')
      device_setting = f_device.readline()
      device_strings = [i.strip() for i in device_setting.split(',')]
      f_device.close()
      rtc = RTC()
      adc = ADC()
      lora = LoRa()
      uart = UART(1, baudrate=1200)
      p_tx = Pin('P3', mode=Pin.OUT)
      p_dir = Pin('P11', mode=Pin.OUT)
      def SDI12(cmd):
          uart.deinit()
          p_tx.value(0)
          p_dir.value(1)                                                          # set output dir
          utime.sleep_us(12800)                                                   # send BREAK
          p_tx.value(1)
          utime.sleep_us(8333)                                                    # send MARK
          uart.init(1200, bits=7, parity=UART.EVEN, stop=1, timeout_chars=75)     # init with given parameters
          uart.write(cmd)                                                         # send command
          utime.sleep_us(8333 * len(cmd))                                         # wait to send command (byte time * command lenght)
          p_dir.value(0)                                                          # output set to read
          line = uart.readline()                                                  # read data from UART
          return line;
      time.sleep(2)
          batt = adc.channel(attn=1, pin='P16')
          #s = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
          #s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5)
          #s.setblocking(True)
          #s.send("Battery Status : " + str(batt.value()) + " mV")
          #s.setblocking(False)
          print('--------------------------------')
          print("Battery Status     : " + str(batt.value()) + " mV")
      #                   Measure Temperature                  #
          #line = ('000312')
          utime.sleep(2)
          line = SDI12('?!')
          utime.sleep(3)
          print(line)
          #temp_time_samp = int(line[1:4])
          #temp_sens_samp = int(line[4:6])
          #print("Temp Read Time     : " + str(temp_time_samp) + " Secs")
          #print("Temp Sensor Read   : " + str(temp_sens_samp) + " Sensors")
      #                     Garbage Collect                    #
          gc.enable()
          gc.collect()
          print("Sensor Memory Free : " + str(gc.mem_free()))
          time.sleep(60)
      I'm not sure if I'm handling the SDI-12 requests correctly by using an RS-485 breakout, the code doesn't fail at any point, however I get a none response. I'm guessing its something to do with the wait times between polling as the probe goes into a deep sleep mode until prompted by an address character.
        robert-hh @jimpower
        @jimpower Looking at the protocol, a simple 3.3 to 5 V level shifer should be enough to connect to the SDI-12 data line. You should connect it with a series resistor in TX, to copy with the half duplex property. That might be the reason for the RS485 adapter, which would allow an easier coupling. xxPy's do not support half duplex operation at the moment. Maybe it is also possible to switch the TX line after UART init to open drain. But that is to be tested.
        For the actual device, you may maybe only have to exchange A and B at the breakout board. That should be required if the "silent" state at the RX side of the the xxPY is 0. And some ground lines seem to be missing in your pictures.
          jimpower @robert-hh
          @robert-hh "And some ground lines seem to be missing in your pictures." If you're referring to the A - 1.8V this is purely used as a reference from battery charge controller, I could run this back to the LoPy vref I guess. I didn't include the 12v and earth lines of the sensor but they are connected to a separate solar mppt controller.
          As SDI-12 uses the one wire for TX & RX (B) I didn't think i could use a simple UART TTL I could try this but I'm not sure how to go about swapping between them. A is used as a reference only. I do think I may need to add a resistor in series between the RX and 3.3V, and should probably add a cap in series between RO and ground.
            robert-hh @jimpower
            @jimpower The nopte about swapping A & B was with the RS485 breakout board, if the quiescent level at the xxPy RX is 0, when it should be 3.3V.
              jimpower @robert-hh
              @robert-hh said in SDI-12 Soil Moisture Probe Help:
              Could you help me to understand how i should do this?
                robert-hh @jimpower
                @jimpower connect the 1.8V source to A and the moisture sensor to B. RS485 is a differential signal, so swapping the cables inverts the polarity.
                J 2 Replies Last reply Reply Quote 0
                  jimpower @robert-hh
                  @jimpower connect the 1.8V source to A and the moisture sensor to B. RS485 is a current loop signal, so swapping the cables inverts the polarity.
                  This is how they are connected in the current state. A goes to 1.8V (which isn't a source just a Vref not sure if this should be 3.3v however) and B goes to the probe.
                    robert-hh @jimpower
                      jimpower @robert-hh
                      @robert-hh This could be an issue, only having 12v and 3.3v sources, I thought the RS-485 breakout could do 5v to 3.3v step down but not the other way. I may have to build a 12v to 5v step down circuit.
                        robert-hh @jimpower
                        @jimpower RS485 is a symmetrical differential interface of at least +/- 200 mV The SDI-12 uses 5V logic levels, the xxPys a 3.3 V level. The RS485 is (mis-)used to create a half duplex interface AND to do the level transformation.
                        Looking at the data sheet It is now clear to me why the 1.8 V is needed. The max output level of the RS485 to the sensor is 3.3 V. To achieve 5V, the 1.8 V is added.
                          jimpower @robert-hh
                          @robert-hh
                          Updated, does this look correct?
                          With this I did manage to receive something although not correct I am getting closer
                            jimpower @robert-hh
                            @robert-hh I am getting responses from the SDI-12 Probe now, the reading of the sensors is working I just can't get the full read (maybe due to the size of it) could you help me to understand how to increase the buffer size to get all readings. Please see below the commands and their expected responses.
                            This works correctly
                            CMD - '?!' (Probe Address)
                            RES - '0'
                            CMD - '02C' (Take Temp Reading)
                            RES - '000312' (1-4 is the time taken to read sensors 5-6 is the amount of sensors read)
                            This doesn't show all readings
                            CMD - '0D0' (Show Temp Readings first 8 sensors)
                            RES - '0+028.12+027.24+027.03+026.78+026.65+025.45+023.34+021.21' (temp readings after each +0)
                            ***Only some of the readings show I have never been able to get more then 6 show at a time.
                            This doesn't seem to work yet
                            CMD - '0D1' (Show temp readings last 4 sensors)
                            RES - '0+028.12+027.24+027.03+026.78'
                            Hopefully it is just a buffer size issue and the payload is not too large.
                              robert-hh @jimpower
                              @jimpower Code and exact sensor product name would be helpful. I found a data sheet telling that the longest response string is 80 bytes. That should not be a problem with the UART. The Rx buffer length is set to 512 bytes.
                                jimpower @robert-hh
                                @robert-hh
                                I'm using an Enviropro EP100G-12 which has 12 rows of sensors at 10cm intervals, each row contains a temp, moisture and ec sensor.
                                http://enviroprosoilprobes.com/Files/EnviroPro_SDI-12_CommandsV2.pdf
                                http://enviroprosoilprobes.com/Files/EnviroPro_EPCU_User_ManualV3.pdf
                                import network
                                import gc
                                import utime
                                f_device.close()
                                rtc = RTC()
                                adc = ADC()
                                lora = LoRa()
                                def SDI12(cmd):
                                    uart.deinit()
                                    p_tx.value(0)
                                    utime.sleep_us(14000)                                                   # send BREAK
                                    p_tx.value(1)
                                    line = uart.read(75)                                                   # read data from UART
                                    return line;
                                time.sleep(2)
                                    utime.sleep(2)
                                    line = SDI12('?!')              #Wake Up Sensor
                                    print(line)                     #Print Sensor Response
                                    utime.sleep(3)                  #Wait before Next Cmd
                                    line = SDI12('0C2!')            #Probe Temp Measure
                                    print(line)                     #Print Time/Sensors
                                    utime.sleep(5)                  #Wait before Next Cmd
                                    data = SDI12('0D0!')            #Probe Temp Readings
                                    print(data)                     #Print Temp Readings
                                    #utime.sleep(10)
                                    #data = SDI12('0D1!')            #Probe Temp Readings
                                    #print(data)                     #Print Temp Readings
                                #                     Garbage Collect                    #
                                    gc.enable()
                                    gc.collect()
                                    time.sleep(30)```
                                robert-hhR B 2 Replies Last reply Reply Quote 0
                                  robert-hh @jimpower
                                  @jimpower Thanks. The code looks principly OK. What happens if you increase the receive timeout?
                                  The documentation of the product is weird. Why cannot they include a proper protocol definition? Did you see b.t.w. CR/LF transmitted at the end of response messages?
                                    jimpower @robert-hh
                                    @robert-hh
                                    yes it says technical document "coming soon"
                                    here is a snippet of my uart.readline()
                                    Do you think this timeout_chars is correct? I wasn't sure what to put in here.
                                    uart.init(1200, bits=7, parity=UART.EVEN, stop=1, timeout_chars=75)```
                                      robert-hh @jimpower
                                      @jimpower SInce the length of the response is not known, you need astrategy to tell when the respons eis complete:
                                      • either the response has a known terminal symbol, like ! in the command, or \r\n, then you can read until you see that symbol, and wait as second condition for a long timeout. Waitung for \r\n is done by uart.readline().
                                      • or you have to wait for a timeout.
                                        The 75 char timeout seems reasonable, but to sort out implementation errors in Micropython, you could increase that for testing and see, if you receive a longer message. Thre reason I ask is, taht I faintly remember some discussion around the rx timeout of uart.read.
                                        jimpower @robert-hh
                                        @robert-hh I'm not sure what happened but I changed my code back to the way it was before playing around with break times, uart timeout etc and it works.
                                        A note for anyone wanting to interface with SDI-12 with a LoPy you need to perform a gc.collect() after every read and then wait for 30secs before you can read from any other sensors.
                                        @robert-hh thanks for your help with this it was pivotal to getting a working SDI-12 interface.
                                        @AntonioValente thanks for your initial concept which lead to this solution.
                                        • B Offline
                                          Bryan Hom @jimpower
                                          @jimpower I know this is an old thread but where are you getting the 1.8V ref from?
                                            robert-hh @Bryan Hom
                                            @Bryan-Hom Yuo can use a small voltage regulator and derive it from 3.3V. If
                                            • 1
                                            • 2
                                            • 1 / 2
