LoPy connects to TheThingsNetwork but payload is empty
  • Sorry, beginner question…
    I am connecting a LoPy to TheThingsNetwork via OTAA. I am sending a integer of the temperature in the payload (which is converted to bytes using the Pycom lora socket object’s send method). The sensor and node all appear to work correctly, however I don't actually know what is being sent by the LoRa radio module.
    The node’s application on the TTN console shows the device activating, then the uplink occurs a few seconds later.
    The Payload in the uplink however shows nothing (actually is reads: 00000000000000000000000000).
    Have I forgotten something really obvious? I have already posted this question on TheThingsNetwork forum but I am not sure if this problem may be a LoPy issue.
  • @philwilkinson For readable data you could also use:
    data = "%.2f" % si.temperature()
    and use float(recv_data) for back-conversion.
  • @philwilkinson Since you did no use tohex while sending, fromhex is not needed, unles the tohex is done somewhere else.
  • Brilliant! thanks @robert-hh for the guidance. I need to study my data types a lot more!
    As I thought I should keep a float temperature reading for reasonable accuracy; my code now reads:
    s.setblocking(True)
    raw_data = round((si.temperature()), 2)
    data = struct.pack('f', raw_data)
    s.send(data)
    print('sent ', raw_data, ' to TTN')
    I now have to work out how to get the payload back into a readable format using something like
    struct.unpack('f', (bytes.fromhex('HEX value in payload')))
  • @philwilkinson Yes. That's why you get e straing ouf zeroes:
    when you convert the float number to an int, you may receive a number like 8. bytes(8) however creates a bytearray of 8 bytes length, each with the value 0.
    To convert a number into a bytearray containing this number you can either usr str(number) or similar to convert it to an ascii string, or struct.pack(), like:
    struct.pack("<i", number)
    See https://docs.python.org/3/library/struct.html
  • results in
  • I didn't include the whole script as it would get too long...!
    # set the LoRaWAN data rate
    # make the socket blocking
    # (waits for the data to be sent and for the 2 receive windows to expire)
    s.setblocking(True)
    from pysense import Pysense
    from SI7006A20 import SI7006A20
    py = Pysense()
    si = SI7006A20(py)
    data = int(si.temperature())  #converted float to integer
    s.send(bytes(data))
    print('sent data to TTN')
    # (because if there's no data received it will block forever...)
    s.setblocking(False)
  • @philwilkinson Can you post the code that creates the payload. Pleas enclose code in lines of three backticks (```)
