    Add Device doesn't give option to add shield
    lopypysensepybytes
    3 Posts 2 Posters 673 Views 2 Watching
      arthurjw
      I am trying to connect a LoPy with pysense shield to Pybytes. Using add device it doesn't give option to add a shield but goes straight to networks. Is their something extra I need to do?
        jirkakrepl @arthurjw
        Hi @arthurjw we decided to remove shield option because it didn't change anything regarding device code. It may only served as some kind of label (description of device).
        software developer @ Pycom
          arthurjw
          Thank you for your reply. Is there a simple example anywhere of sending data (temperature, humidity) to pybytes using the pysense shield?
