    How to add more than 1 Wifi Network to pybytes_config.json ?
    jsonpybyteswifiwipy3.0
    2 Posts 2 Posters 788 Views 2 Watching
    • K Offline
      klaus
      What is the correct syntax to add more Wifi networks to pybytes_config.json ? I carefully checked the available documentation, but I could not fin a hint. Below is a sample file that is appearantly not working correctly. I would like to connect to the nwteork "wifi" first. If that is not available, I would like to connect to the network "wifi1". Has anybody come accross this isue yet and maybe already solved it ? I already tried adding multpile Wifi networks at https://pybytes.pycom.io/settings/device and downloaded the resulting pybytes library. The json file always exclusively reflects the first Wifi network in the list.
      "network_preferences": [
      "wifi","wifi1"
      "device_id": "4914cf28-10d2-4c28-we4e-1cxf2e702bbc",
      "server": "mqtt.pybytes.pycom.io",
      "pybytes_autostart": true,
      "username": "a@b.com",
      "wlan_antenna": 0,
      "wifi": {
      "ssid": "my_first_ssid",
      "password": "123456789012345"
      "wifi1": {
      "ssid": "my_second_ssid",
      "password": "2345678901234567"
      "ota_server": {
      "port": 443,
      "domain": "software.pycom.io"
      "cfg_msg": "Using configuration from config block, written with FW updater"
      • danD Offline
        dan
        Hi @klaus,
        Currently, you can only configure one WiFi network, and save multiple in the Pybytes console.
