    New Stable release v1.18.1
    firmwarelte
    21 Posts 8 Posters 4.9k Views 10 Watching
    • I Offline
      iwahdan
      Hello everyone
      We have released a new stable firmware v1.18.1
      New updates:
      • New updated Scripts for Sequins LTE modem firmware upgrade added as Frozen Code
      • Added support for upgrading LTE modem Firmware via UART
      • Updated structure for esp32/frozen folder
      Note: For upgrading the LTE modem firmware please follow the steps in the following Link
      The new LTE modem upgrade Scripts can be found https://github.com/pycom/pycom-libraries/tree/master/lib/sqnsupgrade
      You can download the new Stable firmware using pycom firmware updater tool.
      or
      To download source files , this could be found here https://github.com/pycom/pycom-micropython-sigfox
      The firmware Files for Sequans LTE modem can be found Here https://software.pycom.io/downloads/sequans2.html
      Wahdan
        tuftec
        Thanks for the update, but I can not get it to work.
        What am I doing wrong??
        Are the upgrade instructions complete???
        This is what I get.
        configsip: 0, SPIWP:0xee
        mode:DIO, clock div:1
        load:0x3fff8028,len:8
        load:0x3fff8030,len:1728
        load:0x4009fa00,len:0
        load:0x4009fa00,len:14584
        entry 0x400a059c
        Pycom MicroPython 1.18.1 [v1.8.6-849-f517b1d] on 2018-08-28; FiPy with ESP32
        import sqnsupgrade
        sqnsupgrade.run('/sd/NB1-37781.dup','/sd/updater.elf')
        File "sqnsupgrade.py", line 538, in run
        File "sqnsupgrade.py", line 168, in detect_modem_state
        File "sqnsupgrade.py", line 89, in return_code
        AttributeError: 'NoneType' object has no attribute 'decode'
        I think I followed the instructions correctly after loading the latest, stable firmware.
        Peter.
        • I Offline
          IOAg @tuftec
          @tuftec @administrators same error for me as well.
          • I Offline
            iwahdan @IOAg
            Hi @ioag @tuftec , may I ask you if your modems where upgraded successfully before or did you had the problem of modem being bricked?
            Wahdan
            I T 2 Replies Last reply Reply Quote 0
            • I Offline
              IOAg @iwahdan
              Hi @iwahdan, my modem is not bricked. I am trying to update to latest firmware because there is an connectivity issue in Australia usingLTE CAT M1 with Telstra. Should I follow follow another process? Thanks.
              • I Offline
                iwahdan @IOAg
                ok, thanks @IOAg , I am looking in to that error you had and will update you Asap
                Wahdan
                • E Offline
                  EinarJ
                  I am getting this error when trying to upgrade the modem:
                  import sqnsupgrade
                  AttributeError: 'module' object has no attribute 'run'
                  The FiPy is upgraded to the latest FW with the updating tool. Formatted the SD card, mounted it and transferred the files as described. Got the latest version of the sqnsupgrade from GitHub and transferred it to the FiPy.
                  • I Offline
                    iwahdan @EinarJ
                    Hi @einarj, you don't need to transfer scripts fro GitHub to the Fipy, these scripts are already embedded in the Firmware (v1.18.1) as frozen code
                    Wahdan
                    E 1 Reply Last reply Reply Quote 1
                    • E Offline
                      EinarJ @iwahdan
                      Hi @iwahdan ,
                      It seems the firmware updating tool only upgrades the FiPy to 1.18.0.r1
                      Tool version is 1.15.1
                      BR.
                      Einar
                      • I Offline
                        iwahdan @EinarJ
                        Hi @einarj, could you update to version 1.15.2 https://forum.pycom.io/topic/3454/new-development-firmware-updater-1-15-2-b1
                        Wahdan
                        • E Offline
                          EinarJ @iwahdan
                          Thanks @iwahdan ,
                          Managed to upgrade it to 1.18.1 - but I get the same error as mentioned from others:
                          import sqnsupgrade
                            peterv
                            Hi @iwahdan,
                            Looks like the delay is not long enough:
                            >>> from sqnsupgrade import sqnsupgrade
                            >>> sqnup = sqnsupgrade()
                            >>> sqnup.detect_modem_state()
                            >>> sqnup.detect_modem_state(initial_delay=8)
                            I 1 Reply Last reply Reply Quote 2
                            • I Offline
                              iwahdan @peterv
                              @peterv , I do acknowledge now that this error happens with some modules , not all of them, we are working on doing a fix for that.
                              Wahdan
                                apallo @EinarJ
                                  apallo
                                    tuftec @iwahdan
                                    Hi @iwahdan, My LoPy is brand new. Never been used.
                                    Peter.
                                      robert-hh @iwahdan
                                      @iwahdan The new release excludes own files in the frozen directory to be included into the build. At the moment they have to be places in one of the subdirectories, Base or Common. Maybe the build script is changed again, or an additional subdirectory is defined for user code, like Custom (?).
                                      Edit: The script to be changed is py/mkrules.mk.
                                      Edit2: I do not understand the need to change the makefile, because files in subdirectories have always been included into the build.
                                      • I Offline
                                        iwahdan @robert-hh
                                        @robert-hh , yes since the frozen folder structure has been changed py/mkrules.mk had to be updated, your proposal sounds very good , I'll consider it in the new release which I believe will not be far away, for now as you mentioned you can place your scripts in either the Base or Common folder .
                                        we have gone with this structure as we are planning to merge the Pybytes firmware into the Base Firmware Build Environment , so Scripts in Common would be included in both Base and PyBytes Builds but PyBytes builds would include Common and other scripts in a new Folder , will be called Pybytes... and LTE with Only FIPY and GPY.
                                        Hope that explains it.
                                        Wahdan
                                        • I Offline
                                          iwahdan
                                          A new firmware v1.18.1.r1 has been released for fixing the issue encountered during modem state detection
                                          Wahdan
                                            robert-hh @iwahdan
                                            @iwahdan OK. I adapted my mkrules.py script already to include files from a 'Custom' folder.
                                            • 1
                                            • 2
                                            • 2 / 2
