New LTE Firmware releases v1.18.1.r4 (stable) & 1.19.0.b5 (development) & NB-IoT firmware 40343
Hello everyone,
A new stable firmware v1.18.1.r4 is now available for the LTE modules (GPy, G01, FiPy). This update fixes an issue where the modem becomes unresponsive during
LTE.init(), improves the reliability ofLTE.pppsuspend()and improvesLTE.isattached()detection. A development version with the same LTE improvements is also now available (1.19.0.b5).A new NB-IoT firmware 40343 is also now available for download at http://software.pycom.io/downloads/sequans2.html
This new firmware most importantly fixes the DNS issue that was introduced in recent versions. It should also have full support for PSM and eDRX though I haven't tested these features yet.
Unfortunately I am not able to provide differential upgrade packages from every previous NB-IoT firmware as the older firmwares don't always upgrade correctly. You can either upgrade from the factory firmware 33080 or the previous NB-IoT firmware 38729, otherwise please use the full firmware package for now.
If you haven't already, please make sure to also read the previous update before updating your modem.
With this new NB-IoT firmware you can use the same commands as used for a CAT-M1 firmware. The following code has been successfully tested with Vodafone NL:
from network import LTE lte = LTE() lte.attach(band=20, apn="nb.inetd.gdsp") while not lte.isattached(): time.sleep(0.25) lte.connect() # start a data session and obtain an IP address while not lte.isconnected(): time.sleep(0.25)If you require any additional AT commands to make a successful NB-IoT connection please post them here so I can add them to the API.
@robert-hh said in New LTE Firmware releases v1.18.1.r4 (stable) & 1.19.0.b5 (development) & NB-IoT firmware 40343:
@xykon Hi @Xykon Did you push that to master or is it the same code as in branch lte-xykon?
The stable firmware is only in the lte-xykon branch for now.
I'm getting the same error, but don't happens all the time. It seems a DNS problem.
If a use the IP address the error disappears.Tested with MEO/Altice Portugal
Will you be adding an option to the updater to use LittleFS?
@reidfo If you use the development version of the firmware and updater, you have an option to choose file systems (check
Show Advanced Settings). -
I get the same error even if I use an IP address. I don't think it's a DNS problem.
@dan Thanks, not sure how I missed that. I updated to 1.19.0.b5 using the updater and it broke LTE on my FiPy. The board would initially attach, then after several seconds the connection seemed to hang. AT commands took several seconds to complete. I downgraded back to my previous firmware (1.19.0.b4 built myself from the development branch) and it started working again.
@serafimsaudade @tlanier we are looking into the issue with sockets
@dan
Is there any time estimation for fix of socket issue? -
@dan
If it helps, note that the socket error occurs even if I'm using WIFI and connecting to a static IP. I don't think the problem has anything to do with the LTE module.
@tlanier
Is the behaviour identical on 1.19.0.b5 and 1.18.1.r4? -
@tlanier
I'm using mqtt that use sockets over wifi connection with no problem. -
The problem with the previous code was my own fault. The "ssl.wrap_socket(s)" line should not be used when connecting to a non-secure site.
I now believe that the problem only occurs when connecting to a secure site. I can successfully connect using WIFI to a non-secure site. If I try to connect to a secure site (www.google.com), I get a stack overflow error.
@tlanier
I'm now successfully connecting and downloading from a non-secure site using either LTE or WIFI. The errors occur if I try to connect to a secure site (www.google.com) using either LTE or WIFI.# TEST - uses cell modem def get1(): try: log('creating LTE object - carrier verizon') # lte = LTE() lte = LTE(carrier="verizon") # lte = LTE(carrier="at&t") # instantiate the LTE object log('resetting modem, may take up to 5 secs...') lte.reset() log('attaching...') lte.attach(apn='apn.hologram.io') # attach the cellular modem to a base station # lte.attach(band=13) # attach the cellular modem to a base station i = 0 while not lte.isattached(): log('waiting for isattached...') utime.sleep_ms(1000) log('connecting...') # lte.connect() # start a data session and obtain an IP address lte.connect(cid=3) # cid=3 for verizon - start a data session and obtain an IP address while not lte.isconnected(): log('waiting for isconnected...') utime.sleep_ms(500) log('create socket') s = socket.socket() log("Connect to: www.ces-web.com") sockaddr = socket.getaddrinfo('www.ces-web.com', 80)[0][-1] #log("Connect to: www.google.com") #s = ssl.wrap_socket(s) #sockaddr = socket.getaddrinfo('www.google.com', 443)[0][-1] log("socket address: {}".format(sockaddr)) s.connect(sockaddr) log("send GET request") s.send(b"GET / HTTP/1.0\r\n\r\n") log("receive response") log(s.recv(16)) s.close() log("socket closed") lte.disconnect() log("disconnected") lte.dettach() log("dettached") lte.deinit() log("deinit") except Exception as ex: sys.print_exception(ex) sys.exit() -
With this latest version on a GPy and latest CAT M1 modem firmware I can no longer connect with hologram SIM.
lte.connect() will dettach the modem and the REPL input hangs.
Previously I could successfully do:
lte = LTE('verizon') lte.attach(apn='apn.hologram.io') ... lte.connect(cid=3)Going back to 1.18.1.r1 and 38638 modem fw works fine. Why would this change? How do I connect to Hologram with the latest updates?
The creg info is:
['+CEREG: 2,5,"3D03","00F0F703",7', 'OK']
Thanks everyone for the reports.
@iwahdan is looking into the SSL issue as this doesn't seem to be directly related to the LTE changes I made.
@panda Unfortunately we don't have hologram.io in The Netherlands so all I can do is emulate Verizon on our Amarisoft eNB.
Could you please try the following 3 commands between
attachandconnect?print(lte.send_at_cmd('AT+CGATT?')) print(lte.send_at_cmd('AT+CFUN?')) print(lte.send_at_cmd('AT!="showphy"'))You mention that the REPL input hangs after connect()... if you do a hard reset does it keep hanging?
If you are able to reset the module and enter code, can you please run the 3 commands again without calling attach first?
@xykon said in New LTE Firmware releases v1.18.1.r4 (stable) & 1.19.0.b5 (development) & NB-IoT firmware 40343:
attachandconnect?text
print(lte.send_at_cmd('AT!="showphy"'))['+CGATT: 1', 'OK']
['+CFUN: 1', 'OK']
['DL SYNCHRO STATISTICS', '=====================', ' Synchro state : DRX_SLEEP', ' PPU SIB1 ACQ watchdog : 0', ' Frequency Hypothesis RF (Hz) : 0', ' RSRP (dBm) : -94.06', ' RSRQ (dB) : -10.79', ' Channel estimation state (Cell-spec.) : HIGH CINR', ' Channel estimation state (UE-spec.) : LOW CINR', ' Channel estimation state (MBSFN) : LOW CINR', ' Channel estimation CINR : 10.10', ' Channel length : SHORT', ' AGC', ' AGC RX gain (dB) : 53.71', ' RX PSD BO (dBFs) : -20.63', ' RX PSD (dBm) : -99.33', ' Noise level RS (dBm) : -104.16', ' Digital gain (dB) : 9.03', ' CINR RS (dB) : 10.10', ' NARROWBANDS', ' Last DL NB : Central', ' Last UL NB : N/A', ' AFC', ' Frequency offset RF (Hz) : -316', ' Frequency offset BB (Hz) : 0', ' PBCH', ' MIB received quantity : 1239', ' MIB timeout quantity : 0', 'OK']
No, reset solves it.
['+CGATT: 0', 'OK']
['+CFUN: 4', 'OK']
['DL SYNCHRO STATISTICS', '=====================', ' Synchro state : OFF', ' PPU SIB1 ACQwatchdog : 0', ' Frequency Hypothesis RF (Hz) : 0', ' RSRP (dBm) : 0.00', ' RSRQ (dB) : 0.00', ' Channel estimation state (Cell-spec.) : LOW CINR',' Channel estimation state (UE-spec.) : LOW CINR', ' Channel estimation state (MBSFN) : LOW CINR', ' Channel estimation CINR : 0.00', ' Channel length : SHORT', ' AGC', ' AGC RX gain (dB) : 0.00', ' RX PSD BO (dBFs) : 0.00', ' RX PSD (dBm) : 0.00', ' Noise level RS (dBm) : 0.00', ' Digital gain (dB) : 0.00', ' CINR RS (dB) : 0.00', ' NARROWBANDS', ' Last DL NB :0', ' Last UL NB : 0', ' AFC', ' Frequency offset RF (Hz) : 0', ' Frequency offset BB (Hz) : 0', ' PBCH', ' MIB received quantity : 0', ' MIB timeout quantity : 0', 'OK']
Hi @tlanier ,I am not able to reproduce the stack overflow issue you got yet, however I've made some improvements to LTE and sockets in a pre-release v1.18.1.r5 :
https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.18.1.r5
maybe you can see if that solves the problem.
