    New Firmware Release Candidate v1.20.0
    firmware
    81 Posts 17 Posters 26.3k Views 18 Watching
      panda
      Actually that error is not related to writing a file. I am not sure what is causing it. It does not appear to happen in direct response to any particular user scripts/code, but in safe mode it is not an issue.
        combaindeft @iwahdan
        @iwahdan
        I'm still having DNS Resolve issues with this release too
        https://forum.pycom.io/topic/4055/nb-iot-in-hungary/3
        https://forum.pycom.io/topic/4021/usocket-getaddrinfo-issues
        • I Offline
          iwahdan
          Hello All ,
          I've released a new version of Release candidate v1.20.0.rc1 having the following updates:
          Improvments
          • Exposed Keyboard Interrupts Control to Micropython
          Bug Fixes
          • Fixed DeepSleep high current Consumption when LTE is not Initialized
          • Increased Delay before initialising RGB color to not Have RGB turn green at startup
          Link to release on GitHub https://github.com/pycom/pycom-micropython-sigfox/releases/tag/v1.20.0.rc1
          you can also download this Firmware via Firmware updater using development as firmware type.
          Wahdan
          D robert-hhR S E 5 Replies Last reply Reply Quote 1
            danielm @iwahdan
            @iwahdan
            Did you test deep sleep current levels also on G01?
            • I Offline
              iwahdan @danielm
              @danielm yes, with same results as GpY
              Wahdan
                robert-hh @iwahdan
                @iwahdan Very good. Thanks. I will try it this evening.
                  serafimsaudade @iwahdan
                  @iwahdan
                  But when I try format to littleFS. It don't work.
                  P X 2 Replies Last reply Reply Quote 0
                    Paul Thornton @serafimsaudade
                    @serafimsaudade HI. Can you give us any more details on the issue your having. do you get any error messages?
                    • X Offline
                      Xykon administrators @serafimsaudade
                      @serafimsaudade said in New Firmware Release Candidate v1.20.0.rc0:
                      Please try the following:
                      pycom.bootmgr(fs_type=pycom.LittleFS, reset=True)
                      This will update the configuration to use LittleFS instead of FatFS. The board will reset automatically.
                      Similarly you can switch back to FatFS:
                      pycom.bootmgr(fs_type=pycom.FAT, reset=True)
                      Note: When switching between LittleFS and FatFS, the flash file system will be re-formatted thus erasing all content.
                      Christian Ehlers
                        serafimsaudade @Paul Thornton
                        @paul-thornton
                        When using the Pycom Upgrade software for linux. When I chose LittleFS, the pycom finish the upgrade and start with FatFs
                          serafimsaudade @Xykon
                          @xykon
                          Tks, that works :)
                            serafimsaudade
                            Now I'm having another problem :/.
                            When I call rtc.ntp_sync(pool.ntp.org) func the rtc get the correct time and date but the rtc.synced() never return True.
                            Using the 1.19.0.b5 fw this problem disappear.
                              robert-hh @iwahdan
                              @iwahdan The Exposed Keyboard Interrupts Control to Micropython does not work. Reason:
                              The API changes the persistent flags, but the code in machuart.c and telnet.c looks at the non-persistent flags. IMHO, these non-persistent flags are not required, because it is a user script which modifies the flags and can set it back. At the REPL loop in pyexec.c, these flags are anyhow reset to the default state, once REPL gets control again. So better use the mechanism of the initial PR.
                              • I Offline
                                iwahdan @robert-hh
                                Hello @robert-hh, sorry I misunderstood your initial PR, somehow I thought there was a need to control keyboard interrupts in normal REPL, which why I had to do these modifications for it to work.
                                I agree with you, your PR is then sufficient and no further modifications needed, will correct this shortly
                                Wahdan
                                • E Offline
                                  EinarJ @iwahdan
                                  @iwahdan Why is PSM and eDRX not used when running deinit(dettach=False)?
                                    danielm @EinarJ
                                    @einarj
                                    I did not perform any tests with those features yet but I think you must set requested mode and related timers by AT commands, e.g.:
                                    Power Saving Mode Setting:
                                    +CPSMS=[<mode>[,<Requested_Periodic-RAU>[,<Requested_GPRSREADYtimer>[,<Requested_PeriodicTAU>[,<Requested_Active-Time>]]]]]
                                    • E Offline
                                      EinarJ @danielm
                                      @danielm I've tried, but it doesn't seem to have any effect. I can see it's being disabled by default in the LTE init, so I've set the command manually after that. The PSM should,in theory, cause the LTE modem go into PSM mode right after the data is sent, but that doesn't seem to happen. Maybe it's becsuse the the flag for going into PSM is not being passes to the modem. But, PSM is useless if you don't cannot setup eDRX. The modem gives me an error if I try the setting specified in the AT-command specs. Do you know if the vendor has implemented these features into the FW?
                                        danielm @EinarJ
                                        @einarj
                                        There are some eDRX-related commands as well:
                                        • eDRX Read Dynamic Parameters: +CEDRXRDP
                                        • eDRX Setting: +CEDRXS
                                        • Specific eDRX Settings: +SQNEDRX
                                        I have no idea if PSM/eDRX commands are implemented and working as expected because I did not test them yet.
                                        @iwahdan @Paul-Thornton
                                        In my opinion Pycom should provide statement regarding readiness of PSM/eDRX features implemented in the modem's firmware because without these features it is not possible to develop battery-powered solutions with reasonable long battery life-time which is the main purpose of NB-IoT.
                                        There should also be tutorial available in the documentation because of importance of these features.
                                        X 1 Reply Last reply Reply Quote 2
                                        • X Offline
                                          Xykon administrators @danielm
                                          @danielm said in New Firmware Release Candidate v1.20.0.rc0:
                                          I will try to post more details about PSM/eDRX as soon as possible. Generally the standard 3GPP AT commands should be used using lte.send_at_command(). However in order to tell the modem to go into PSM/eDRX mode, lte.deinit(dettach=False) should be called. The wrong spelling of dettach aside, the modem checks the state of the flow control pins to see if it is OK to go into low power mode. The deinit command releases the flow control pins thus allowing the modem to go into the configured sleep mode.
                                          In regards to the release candidate, after uploading v1.20.0.rc2 earlier today, which includes the latest Sequans firmware updater and Pybytes scripts, I have realised an error was made in pycom_config.h that causes the fs_type flag to be stored at an incorrect position. This is also the reason why the setting from the firmware updater is ignored. I have already uploaded a correction to the release-candidate branch as I had issues updating the perviously used v1.20.0.rc0 branch. I will upload a new version shortly but wanted to give people a heads-up to check the file system type in the firmware updater when updating. This should only affect people who used the commands I posted above to manually switch the fs_type with the pycom_bootmgr command.
                                          Christian Ehlers
                                          D S 4 Replies Last reply Reply Quote 1
                                            danielm @Xykon
                                            @xykon
                                            Yesterday I did some tests with PSM-related AT commands.
                                            Is seems that following commands should sent before attaching (after first boot). Of course timer values of '+CPSMS' may be adapted.
                                            self.lte.send_at_cmd('AT+CPSMS=1,,,"01000001","00000001"')
                                            self.lte.send_at_cmd('AT+CEREG=4')
                                            After successful attach '+CEREG?' returns Active time and Periodic TAU values allocated by the network which may be identical to requested values (this is the case in NB-IoT network of Slovak Telekom) but in other networks they may be limited by the network.
                                            It seems that '+CPSMS' command has to be called after consequent boots from deep-sleep (with LTE already attached) as well.
                                            E 1 Reply Last reply Reply Quote 2
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 5
                                            • 2 / 5
