    Can't connect GPy to pybytes with NB-IoT
    gpy nbiotpybytesconnect issuesdns
    9 Posts 4 Posters 792 Views 4 Watching
    • E Offline
      ebran
      Re: Can't connect Fipy via LTE NB-IoT to Pybytes
      Connecting my GPy to Pybytes via Wifi works fine, but I have a similar issue as above with NB-IoT. On booting the GPy with latest pybytes firmware:
      Firmware: 1.18.2.r6
      Pybytes: 0.9.12
      Initialized watchdog for WiFi and LTE connection with timeout 660000 ms
      LTE init(carrier=standard, cid=1)
      LTE attach(band=20, apn=lpwa.telia.iot, type=None)
      LTE connect()
      LTE is_connected()
      LTE connection established
      Unknown error while connecting to MQTT server [Errno 113] EHOSTUNREACH
      Quite close to connecting to Pybytes I think... Could this be DNS related?
      My carrier is Telia. These REPL lines give me perfect access to Internet:
      >>> import socket
      >>> from network import LTE
      >>> lte = LTE()
      >>> lte.send_at_cmd('AT!="addscanband band=20"')
      '\r\n\r\nOK\r\n'
      >>> lte.attach(band=20, apn="lpwa.telia.iot")
      >>> lte.isattached()
      True
      >>> lte.connect()
      >>> lte.isconnected()
      True
      >>> socket.dnsserver(0,'8.8.8.8')
      >>> socket.dnsserver(1,'8.8.4.4')
      >>> socket.dnsserver()
      ('8.8.8.8', '8.8.4.4')
      >>> print(socket.getaddrinfo("www.google.com", 80)[0][-1])
      ('172.217.21.132', 80)
      Grateful for your advice.
      // Erik
      • X Offline
        Xykon administrators @ebran
        @ebran Are you sure Telia is allowing tcp/ip mqtt access to 3rd party platforms via NB-IoT? A lot of providers place restrictions on what you can do and only allow connectivity to their own proprietary platform. I've briefly looked through what's available on google and I only found information on how to connect to the Telia cloud platform through nb-iot.
        Christian Ehlers
        • E Offline
          ebran @Xykon
          @Xykon Telia allows tcp/ip mqtt access.
          It was as I suspected, a DNS server issue. I solved it by modifying the pybytes source code to use Google DNS.
          diff --git a/lib/pybytes_connection.py b/lib/pybytes_connection.py
          index b7c3f49..3d16201 100644
          --- a/lib/pybytes_connection.py
          +++ b/lib/pybytes_connection.py
          @@ -130,6 +130,10 @@ class PybytesConnection:
                           print("You need a device with FiPy or GPy firmware to connect via LTE")
                           return False
                       try:
          +                # use Google DNS servers
          +                socket.dnsserver(0,'8.8.8.8')
          +                socket.dnsserver(1,'8.8.4.4')
                           time.sleep(3)
                           print_debug(1, 'LTE init(carrier={}, cid={})'.format(lte_cfg.get('carrier'), lte_cfg.get('cid', 1)))
          And also need to reset modem on boot-up, because otherwise it can hang when connecting to the MQTT server, for whatever reason (?):
          # boot.py -- run on boot-up
          print("Resetting modem...", end="\r")
          lte = LTE()
          lte.reset()
          lte.send_at_cmd('AT^RESET')
          print("Resetting modem... Done.")
          I have to disable pybytes autostart in the json file, to get this working, obviously.
          // Erik
            Scott Basgaard @ebran
            @ebran said in Can't connect GPy to pybytes with NB-IoT:
            •            socket.dnsserver(1,'8.8.4.4')
            @ebran can I ask how you modified this library?
              The feature you mention is available in the latest firmware (1.20.2.r1)
                Scott Basgaard @Gijs
                @Gijs thanks for the reply.
                Can I ask how? I'm getting
                Socket create error: [Errno 202] EAI_FAIL
                when using Pybytes and not setting DNS to 8.8.8.8. and 8.8.4.4 in manual LTE connect tests.
                  To be honest, I'm not completely sure.
                  It could be the case your LTE carrier is not providing the DNS servers correctly, or that the LTE modem is not picking up on them. You can verify by calling socket.dnsserver() after the lte connection is established, but before you change the servers yourself?
                  Best,
                    @Gijs thanks again. Looks like I can't set them and they are ('193.181.246.58', '193.181.246.57') wherever I print socket.dnsserver().
                    • E Offline
                      ebran @Scott Basgaard
                      @Scott-Basgaard Well at the time I'm pretty sure you could download what was called the "pybytes" firmware and modify it accordingly (with the patch above). But this particular problem was sorted out in a later version of the built-in pybytes library, at least for me.
                      FWIW, back then you had to set the dns server with socket.dnsserver() before you did from network import LTE.
