    Guru Meditation Error
    58 Posts 7 Posters 2.5k Views 7 Watching
      andreas
      @andreas said in Guru Meditation Error:
      P.S.: To be safe that the core dump decoding gives us the correct results: Are you using lopy4-vanilla-dragonfly-onewire or lopy4-vanilla-dragonfly-onewire-i2s?
      I've tried to reproduce a corresponding application.elf file for the LoPy4-0.7.0-vanilla-dragonfly-modonewire-i2s firmware which shows the core dump is happening here:
      ==================== CURRENT THREAD STACK =====================
      #0  0x4009192e in vTaskExitCritical (mux=0x844a) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:4274
      #1  0x401124f0 in lora_bandwidth (n_args=<optimized out>, args=0x3ffc990c <lora_partial_rx_packet+12>) at mods/modlora.c:2117
      See also [1]. I believe this is also due to a erroneous core dump decoding, so nevermind.
      I have now kept the application.elf file for the new build LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz. If you are able to catch another core dump when running this firmware, we would probably get correct results. Sorry for the extra mile.
      [1] https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/mods/modlora.c#L2116-L2118
      S 3 Replies Last reply Reply Quote 0
        andreas
        Another attempt by trying to reproduce a corresponding application.elf file for the LoPy4-0.7.0-vanilla-dragonfly firmware without support for 1-Wire and I2S.
        #0  0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
        #1  0x401124f0 in ?? ()
        Backtrace stopped: previous frame identical to this frame (corrupt stack?)
        ======================== THREADS INFO =========================
          Id   Target Id         Frame
          16   process 15        0x4000bff0 in ?? ()
          15   process 14        xQueueGenericSend (xQueue=0x3ffb2e50, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
          14   process 13        xQueueGenericSend (xQueue=0x3ffc3f0c <vflash_mem+1840>, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
          13   process 12        xQueueGenericSend (xQueue=0x3ffb75fc, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
          12   process 11        0x4000bff0 in ?? ()
          11   process 10        xQueueGenericSend (xQueue=0x3ffbac44, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
          10   process 9         xQueueGenericSend (xQueue=0x3ffb7bc8, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
          9    process 8         xQueueGenericSend (xQueue=0x3ffdab60, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
          8    process 7         0x4000bff0 in ?? ()
          7    process 6         0x40092b55 in vTaskNotifyGiveFromISR (xTaskToNotify=0x0, pxHigherPriorityTaskWoken=0x0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:5044
          6    process 5         0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x8484, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
          5    process 4         xQueueGenericSend (xQueue=0x3ffbd494, pvItemToQueue=<optimized out>, xTicksToWait=100, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
          4    process 3         0x40206db2 in littleFsErrorToErrno (littleFsError=393251) at littlefs/vfs_littlefs.c:175
          3    process 2         xQueueGenericSend (xQueue=0x3ffbdab4, pvItemToQueue=<optimized out>, xTicksToWait=4294967295, xCopyPosition=0) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/queue.c:780
          2    process 1         0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
        * 1    <main task>       0x4009192e in prvAddNewTaskToReadyList (pxNewTCB=0x844a, xCoreID=1073476968, pxTaskCode=<optimized out>) at /Users/iwahdan/esp/pycom-esp-idf/components/freertos/tasks.c:1175
        Looking at
        here.
          andreas @sita
          @sita said in Guru Meditation Error:
            f = open('/sd/A_3001SF8.txt', 'a+')
            f.write(message)
            f.write(' ')
            f.write('\n')
            f.close()
          Could you stop opening and closing the file within such a tight loop? You might want to time.sleep_ms() for at least some milliseconds between iterations. To be safe, try to use longer intervals first and get shorter if things might become more stable.
          When being at it, you might also want to think about optimizing things using a single write call like f.write(message + ' \n').
            sita @andreas
            Hello @andreas,
            Thanks for the information. I kept time.sleep_ms(10) in the loop and will change f.write as you said.I will do the the experiment again and let you know if i got same again.
            Thanks once again.
            Have a nice day
              sita @andreas
              Hello @andreas ,
              I have changed the firmware to LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz. I will do the experiment again and let you know if i got same issue again.
              Thanks once again & have a nice day
                sita @andreas
                Hello @andreas ,
                I have now flashed the latest firmware (LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz). I got a new problem.When i try to upload my project, it gets struck while uploading the additional library files required. I attached the screenshot below.
                As far i understood, it is trying to compress the library files before uploading and it gets struck with that. I haven't observed this phenomenon with earlier firmware versions. Please have a look
                Thanks & Best regards,
                Have a nice weekend
                  sita @andreas
                  Hello all,
                  I got an issue regarding uploading the project and connecting the port after updating new firmware LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel.tar.gz, the respective problem screenshots shown in the below.
                  My doubt is, Is it related to new firmware update or any change in ATOM editor settings ??
                  Could anyone please suggest me how to resolve this problem ?
                  Uploading project (main folder)...
                  Safe booting device... (see settings for more info)
                  Safe boot failed, uploading anyway.
                  Upload failed: timeout. Please reboot your device manually.
                  Connecting to COM12...
                  Connection error: Error: timeout
                  Thanks in advance & Have a nice day
                    andreas @sita
                    Dear @sita,
                    sorry to hear that this didn't work out well. While I have to admit I haven't tested the firmware on a LoPy4 device, I just compiled it like any other Dragonfly builds I have done before.
                    I haven't seen the error you are observing anytime before.
                    So, to be better safe than sorry, downgrading to any other former release from [1] might help. If it doesn't you might want to downgrade to a regular release from Pycom using the regular firmware installer.
                    Sorry for the hassle!
                    With kind regards,
                    Andreas.
                    [1] https://packages.hiveeyes.org/hiveeyes/foss/pycom/vanilla/
                      sita @andreas
                      Hello @andreas ,
                      I have tested my devices all the versions in the [1] but in every version i observed the Guru meditation error. Is there any permanent solution for this problem ? It would be very helpful if i know exact reason behind issue ,if you know the reason could you please let me know..
                      Thanks in advance & have a nice day
                        andreas @sita
                        Dear @sita,
                        just a short question: Have you been able to run your MicroPython program successfully with LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel until the Guru Meditation error happened again? I am asking because it looked like you had other problems with this the other day.
                        With kind regards,
                        Andreas.
                          sita @andreas
                          Hello @andreas,
                          The other problems are still there, for temporarily i am running [1] in cmd so that error not coming.
                          [1]pycom-fwtool-cli.exe --verbose --port COM12 erase_all
                            andreas @sita
                            Thanks. So, to make sure we are on the same page...
                            • Invoking erase_all once before uploading a new firmware image is considered good practice. Thanks for letting me know.
                            • After that, you are able to invoke your MicroPython program using the LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel firmware?
                            • However, Guru Meditation errors still occur?
                            Now, are you able to submit another core dump when running this firmware build? I have saved a local copy of lopy4-0.8.0-vanilla-squirrel.elf on my workstation in order to decode core dumps produced by this build.
                              sita @andreas
                              @andreas Now i got an issue with the atom editor :( :(
                              i have updated the ATOM editor evening and now i it is not showing REPL console. I will check with this and send you the core dump (LoPy4-1.20.1.r3-0.8.0-vanilla-squirrel).
                                peterp
                                @sita can you try again with 1.20.2.rc3
                                @pigamonte same advice to you, but in case it doesn't solve it for you, I suggest to open your own thread. Otherwise we end up mixing different issues. Just because it shows a Guru Meditation Error, doesn't necessarily mean the issues are related.
                                  sita @peterp
                                  Hello @peterp,
                                  I have tried with new firmware version (1.20.2.rc3) but same error is coming again. I will open new thread to avoid mixing of different issues.
                                  Thanks & Have a nice day
                                  A 1 Reply Last reply Reply Quote 1
                                    andreas @sita
                                    Dear @sita,
                                    Either with the original Pycom's 1.20.2.rc3 and/or with the corresponding/updated LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz, I will be happy to receive respective core dumps. I have now kept the definitive .elf files around for decoding the core dumps appropriately.
                                    Thanks and with kind regards,
                                    Andreas.
                                      sita @andreas
                                      Hello @andreas ,
                                      This is the core dump of the updated LoPy4-1.20.2.rc3-0.8.0-vanilla-squirrel.tar.gz
                                      Guru Meditation Error: Core  1 panic'ed (IllegalInstruction). Exception was unhandled.
                                      Memory dump at 0x4010abc8: 10180108 00000044 00000000
                                      Core 1 register dump:
                                      PC      : 0x4010abcf  PS      : 0x00060130  A0      : 0x801024b3  A1      : 0x3ffd8280
                                      A2      : 0x3ffc93fc  A3      : 0x00000000  A4      : 0x3f94ef00  A5      : 0xffffff30
                                      A6      : 0x3f9502b3  A7      : 0x00007e00  A8      : 0x40109f79  A9      : 0x3ffd8260
                                      A10     : 0x3f40eed0  A11     : 0x00000000  A12     : 0x3f94ef04  A13     : 0x3f94ef08
                                      A14     : 0x00000048  A15     : 0x400ff4ea  SAR     : 0x0000001e  EXCCAUSE: 0x00000000
                                      EXCVADDR: 0x00000000  LBEG    : 0x40094de0  LEND    : 0x40094dfc  LCOUNT  : 0xffffffff
                                      Backtrace: 0x4010abcf:0x3ffd8280 0x401024b0:0x3ffd8320 0x400fe7c1:0x3ffd8350 0x400fe7ee:0x3ffd8370 0x400e208d:0x3ffd8390 0x400e231d:0x3ffd8430 0x400e0d81:0x3ffd8450
                                      0DgAAAEAAAARAAAAbAEAAA==
                                      9EX8P8CB/T98hv0/
                                      AIH9PxCG/T/ztQIADEP8PwxD/D/0Rfw/BEP8Pw4AAAC4N/4/uDf+P/RF/D8AAAAA
                                      CwAAAIBW/T9NaWNyb1B5AAAAAAAAAAAAAQAAAHyG/T8AAAAAIAsGAAsAAAABAAAA
                                      +DT7P/yT/D8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                      l4dAPwAAAAD4WwlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==
                                      oCMQgM+rEEAwAQYAsyQQgICC/T/8k/w/AAAAAADvlD8w////swKVPwB+AAB5nxBA
                                      YIL9P9DuQD8AAAAABO+UPwjvlD9IAAAA6vQPQB4AAAAAAAAAAAAAAOBNCUD8TQlA
                                      /////wTvlD8I75Q/gDYIQLRp+j8AAAAAAAAAAAEAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAATvlD8I75Q/SAAAAOr0D0DE5w+AIIP9P1CU/D9QlPw/
                                      kIP9PwMAAACzJBCAgIL9PwgAAABQ75Q/TO+UP0TvlD8AAAAAEwAAACsBAAAgAAAA
                                      5DYIQFsjDkDE5w+AIIP9P1CU/D9QlPw/TpoQgMyKCUAIAAAARO+UPwAAAAATAAAA
                                      AAAAAPDulD9Q75Q/TO+UPwAAAAAAAAAAAAAAAAAAAAAE75Q/MP////cDlT8CAAAA
                                      8ecPgFCD/T9g7ZQ/AAAAAAAAAAAAAAAAAwAAACMABgDw7pQ/AAAAAEwAAAAgg/0/
                                      kCAOgHCD/T9g7ZQ/AAAAAAAAAAAAAAAAAQAAAAAAAAAgIw6AkIP9P2DtlD8gAAAA
                                      AAAAAAAAAAAAAAAAKPCUP4QNDoAwhP0/pu2UP2YDAAAAAAAAAAAAACAjDoCQg/0/
                                      DE/8PwAAAAAgAAAAEDNBPwgzQT8IAAAAsg0OgCCE/T+PM0E/ZgMAAIQNDoAwhP0/
                                      pu2UP2YDAAAMIA6AvACVP6D+lD8BAAAAZ0FJTgAIAAAIAAAAcDNBP3juAAABAAAA
                                      IAAAAKbtlD/D7gAAAQAAACAAAAAQM0E/CDNBPwgAAAAAAAAAUIT9PwYWAAABAAAA
                                      mDH+PwAAAAABAAAAAAAAAAAAAAAQhv0/AAAAAAAAAAABAAAApaWlpaWlpaWlpaWl
                                      AAAAAAAAAaXoAAAA6QAAAAEAAAAABAAA+P8f0AAAAAD//////////6WlpaWlpaWl
                                      AQAIAAAAAAClpaWlpaWlpaWlpaWlpaWlpaWlpQAAAADIXEA/paWlpaWlpaWlpaWl
                                      paWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWlpaWl
                                      5DYIQPQIDkAwAAUAAAAAABCG/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAAAAAACQmxkA
                                      AAAAAP/////////////////////7O9mUAAAAAAAAAAAAAAAAAPAfAFCE/T8AAAAA
                                      AAAoAAAAAAAAAAAAAAAAAM0XQD+sR/w/AAAAAFUXQD8AAAAAAAAAAAAAAAAAAAAA
                                      AQAAAAAAAAAchv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAA
                                      ZP39P6Ak/T+UJv0/
                                      oCT9PzAm/T/ztQIAqEL8P6hC/D9k/f0/oEL8PxMAAAB8/f0/AAAAAGT9/T8AAAAA
                                      BgAAAJgW/T9Mb1JhAAAAAAAAAAAAUFkAAQAAAJQm/T8AAAAAIQAGAAYAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP79Pw==
                                      5DYIQE53CUAwCwYAjDMRgGAl/T/ztQIAQN37Pxgh/j8AAAAAAAAAAAAAAABOdwmA
                                      QCX9PwEAAADztQIAZP39PwEAAAD+AAAAEAAAAA4AAACLAAYAq6sAAE4+CUBZPglA
                                      AAAAAOQ4CEABAAAAzIoJQNQJ+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAIBB/D8BAAAA/gAAAAEAAAAAAAAAgCX9P8SZ/D9Ymvw/
                                      3GL7P/////8AAAACzGL7PwAAAAAwJv0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                                      AAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAAAAAMyKCUDUCfo/AAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAABKFhQoAAAAAAAAAAAAAAADMNkE/eAT8P1ia/D+V////
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPCb9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAA=
                                      HLP7PyCx/T+Isv0/
                                      ILH9PyCy/T/ztQIAlEL8P5RC/D8cs/s/jEL8PxQAAAAwOv4/MDr+Pxyz+z8AAAAA
                                      BQAAAIyi/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAIiy/T8AAAAAIQAGAAUAAAAAAAAA
                                      9H/7PwAAAAAAAAAAAAAAAAsAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
                                      5DYIQE53CUAwCwYAyA4OgOCx/T/ztQIAQN37PwsAAAAA/wAAAAD/AAAAAP9OdwmA
                                      wLH9PwEAAADztQIAHLP7PwEAAAD+AAAAIwAGAAAAAADEVg+AoLH9P+BNCUD8TQlA
                                      /////+Q4CEABAAAAzIoJQMSV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAsv0/MPj7PwAAAAAAAAAAALL9PwAAAAAAAAAA
                                      AgAAAAD/AAAAAP8AAAAA/wAAAAAgsv0/AAAAAAAAAAAAAAAAAQAAAGpK/D8AAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALLL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      QLn7P6C3+z84ufs/
                                      oLf7P9C4+z9Tlb0vvL77PzBC/D9Aufs/KEL8PxkAAAC8SVUVuUNvUUC5+z8AAAAA
                                      AAAAADy1+z9JRExFMABG0Bmj0zv92E4AAAAAADi5+z8AAAAAIwAGAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEXqHw==
                                      5DYIQLZoIUAwDwYAdmgXgGC4+z8AAAAAAAAAAAAAAACQt/s/AwAAACMABgD4kfw/
                                      AAAAAPyxAgAAAAAAAAAAAAkAAAAAgAAA//8AgAoAAACguPs/AAAAANDYDkAT2Q5A
                                      AAAAAOQ4CEAJAAAAzIoJQHSc+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAPPr8P8yKCUAseQmAgLj7PyAAAAABAAAA
                                      //8/swAAAAAAAAAAAAAAAAAAAACguPs/AAAAALhB/D8AAAAAPPr8PxxE/D8AAAAA
                                      AAAAANC4+z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAAAAAAAAQAAAAQAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3Lj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      tL77PxC9+z+svvs/
                                      EL37P0C++z/MtOISMEL8P0i5+z+0vvs/KEL8PxkAAACFM0nahGdmZbS++z8AAAAA
                                      AAAAALC6+z9JRExFMQDLX/9qno4QORUAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAI8mOg==
                                      5DYIQLZoIUAwCQYAdmgXgNC9+z8AAAAAMEL8P4XGAgCoBfw/K6oCACMABgAjAAYA
                                      /////5BB/D8wQvw/6M8CAKgF/D81rwIAIwAGAAAAAADQvfs/AAAAAAAAAAAAAAAA
                                      AAAAAOQ4CECoBfw/zIoJQOSh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAseQmA8L37PyAAAAABAAAA
                                      //8/swAAAAAAAAAAAAAAAAAAAAAQvvs/AAAAALhB/D8gAAAAPPr8PyBE/D8AAAAA
                                      AAAAAEC++z8AAAAAAAAAAEDd+z8AAAAAAAAAAAAAAAABAAAAAQAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATL77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      tJ/7P9Ct+z/Er/s/
                                      0K37P2Cv+z8xtgIAHEL8PxxC/T+0n/s/FEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/
                                      EgAAAMih+z90aVQAcEH8P7x9+z/EffsAAAAAAMSv+z8AAAAAIQAGABIAAAAAAAAA
                                      5DYIQLBmCUAwDwYAaf8YgJCu+z/cnvs/MK/7Pyif+z8AAAAAMJ/7PwAAAACwZgmA
                                      cK77PwAAAABiAAAAQN37PxxE/D/+AAAAAAAAABAAAAABAAAA/gAAAPHrGED66xhA
                                      AAAAAOQ4CEAcRPw/zIoJQAST+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAEQ2GICgrvs/cAtCP6Cu+z//NxiA0K77P/////8wr/s/
                                      AAAAAM+1AgBkAAAAUDcYQGIAAACQrvs//gAAAAAAAABIOBiA4K77P7wMQj+YAJQ/
                                      rwEYgACv+z88+/w/MK/7P68BGIAAr/s/PPv8PzCv+z9iAAAA/////8+1AgAAAAAA
                                      AAAAADCv+z88ZxhAAAAAAFA3GEC8DEI/PGcYQAAAAACo//w/qP/8P6T//D+k//w/
                                      AAAAAGCv+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAbK/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      FEL9PwBA/T8MQv0/
                                      AED9P6BB/T/0tQIAvJ/7PxxC/D8UQv0/FEL8PxMAAAAAAAAAAAAAABRC/T8AAAAA
                                      BgAAABA0/T9TaWdmb3gAQLDKH0AwAAUAAAAAAAxC/T8AAAAAIQAGAAYAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKWlpQ==
                                      5DYIQE53CUAwAQYAysofgMBA/T/0tQIAQN37PyD//T8AAAAAAAAAAAAAAABOdwmA
                                      oED9PwAAAAD0tQIAFEL9PwEAAAD+AAAAIwAGABEAAABEJfo/AAAAAAAAAAAAAAAA
                                      AAAAAOQ4CEABAAAAzIoJQEQl+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4ED9P9gU/T/UFP0/
                                      IP/9PwAAAAAAAAAAAAAAAAAAAACgQf0/AAAAAAAAAADkNghAsMofQDAABQAAAAAA
                                      oEH9PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      RCX6PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      FwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKxB/T8AAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
                                      IMv7P8DJ+z8Yy/s/
                                      wMn7P7DK+z8AAAAACEL8PwhC/D8gy/s/AEL8Pw8AAABQwPs/UMD7PyDL+z9IwPs/
                                      CgAAABzB+z9UbXIgU3ZjAA5cTdTiH3QAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMCU9g==
                                      5DYIQGGICUAwAAYAAAAAAIDK+z8AAAAAAAAAAAAAAAAsRPw/JET8PwEAAABhiAmA
                                      YMr7PwAAAABA3fs/gEH8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAOQ4CEAAAAAAzIoJQFSu+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAFSu+D8AAAAAAAAAAAAAAAAAAAAAsMr7PwAAAAAAAAAA
                                      AAAAAAAAAAC8yvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAA=
                                      7MP9P1DC/T/kw/0/
                                      UML9P4DD/T/JRKlVCMr9P7Sx+z/sw/0/pEH8PxQAAABziUhuF1Dt2OzD/T8AAAAA
                                      BQAAAOiz/T9Tb2NrZXQgT3BlcmF0aW8AAQAAAOTD/T8AAAAAIQAGAAUAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAACNJw==
                                      5DYIQPC/AEAwAAYAWnIJgBDD/T8AAAAAIwAGACAABgDQg/0/VQAAAPCh/T///z+z
                                      q6sAAOzc+z8jAAYA7MP9PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                                      AAAAAOQ4CEABAAAAzIoJQCSn+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACigwmAIMP9P0Dd+z8GAAAA
                                      3moOgEDD/T8BAAAAIET8P+zD/T8BAAAA/gAAALCd+z8AAAAAYMP9PwAAAAAAAAAA
                                      HET8P0Dd+z+QQfw/lEL8PwAAAACAw/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAjMP9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AMr9P1Dp/T9s6/0/
                                      UOn9PwDr/T8Ayv0/OHz7P/TD/T8Ayv0/pEH8Pw4AAAC8sv0/vLL9PwDK/T+0sv0/
                                      CwAAAHDL/T9JUlFzAAAAAAAAAAAASYIAAQAAAGzr/T8AAAAAIQAGAAsAAAAAAAAA
                                      AAAAAJzq/T8AAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApv6CQ==
                                      5DYIQLBmCUAwBQYASEsPgBDq/T+Qsv0/sOr9P9yy/T8AAAAA5LL9PwAAAACwZgmA
                                      8On9PwEAAAD/////QN37PxxE/D/+AAAAAAAAAAAAAABQ6v0/sJX8PwAAAAAAAAAA
                                      AAAAAOQ4CEAcRPw/zIoJQKTO+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAQAAAMyKCUB8FA6AUOr9P4CS/D+w6v0/
                                      AAAAAFQAAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAAAAAAAAQAAAHSS/D8wAPw/
                                      AAAAAODq/T90kvw/AAAAAADr/T8AAAAAAAAAAAAAAAAAAAAAdJL8PwAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACw6v0/
                                      ABwAAFCU/D9QlPw/AAAAAKTO+j8AAAAAAAAAAAAAAABQlPw/CgAAAJBB/D8MQ/w/
                                      AAAAAADr/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAM6/0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAA
                                      MHz7P7Cc+z84nvs/
                                      sJz7P9Cd+z8sCBnhmNn7PwjK/T8wfPs/pEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                                      GAAAADya+z9pcGMxAH0Q8VnobXH5p5QAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKE5jA==
                                      5DYIQLBmCUAwBwYAlDQIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACwZgmA
                                      UJ37PwEAAAD/////QN37PxxE/D/+AAAAIAMGABwAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAOQ4CEAcRPw/zIoJQHSB+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAADB8+z8BAAAA/gAAACMABgAAAAAAsJ37PzhB/D8AAAAA
                                      AAAAAGQEAAD+AAAAIAMGAP////8AAAAAOEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                                      AAAAANCd+z8AAAAAAAAAALh+CEABAAAAAAAAAAAAAAB9FAiAgH3+PwABAADoDQBA
                                      AAAAAAAAAADcnfs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAA=
                                      kNn7P9CQ/T+Akv0/
                                      0JD9PyCS/T8L+VfXqDL9Pzh8+z+Q2fs/pEH8PwUAAABk0/s/ZNP7P5DZ+z9c0/s/
                                      FAAAAISG/T9ldmVudFRhc2sADM8yC4kAAAAAAICS/T8AAAAAIQAGABQAAAAAAAAA
                                      KDX7PwAAAAAAAAAAAAAAAAAAAADUZPs/PGX7P6Rl+z8AAAAAAAAAAAEAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHiJeQ==
                                      5DYIQLBmCUAwAgYALGkXgJCR/T840/s/0JH9P4TT+z8AAAAAjNP7PwAAAACwZgmA
                                      cJH9PwAAAAD/////QN37PxxE/D/+AAAAIAAGAAAAAABwkf0/fJH9P+BNCUD8TQlA
                                      /////+Q4CEAcRPw/zIoJQMR1+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAMCoBAH///8AwKgEATxxv4cAAAAA0JH9P4z6/D8AAAAA
                                      AAAAAL0EAAD+AAAAIAAGAP/////Qkf0/jPr8PwAAAACE0/s/AAAAAFzZ+z8BAAAA
                                      AAAAACCS/T8AAAAAAAAAAA4AAAACAAAAfML8PwEAAAAIBvw//gAAAAEAAAAbchOA
                                      8EH7PwAAAAAAAAAAcQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAskv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      oDL9P9Aw/T+YMv0/
                                      0DD9PzAy/T8AAAAAcHr7P5jZ+z+gMv0/pEH8PxEAAAB4Yvs/eGL7P6Ay/T9wYvs/
                                      CAAAAJwm/T9Mb1JhX1RpbWVyX2NhbGwAAQAAAJgy/T8AAAAAIQAGAAgAAAAAAAAA
                                      5DYIQPC/AEAwAAYAWnIJgJAx/T8AAAAAIwAGACAABgABAAAA/gAAAAAAQAD//z+z
                                      q6sAAEDd+z//////IAoGAIDslD8AAP8AAAAA/wAAAAClpaWlpaWlpQAAAAAAAAAA
                                      AAAAAOQ4CECA7JQ/zIoJQNQV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP////+nZgmAoDH9P5hi+z//////
                                      mB4RgMAx/T9MYvs/ADL9P0Dd+z8cRPw//gAAACMABgAAAAAAADL9P4Cb/D8AAAAA
                                      AAAAAIAIAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACYYvs/AAAAAKBi+z8AAAAA
                                      AAAAADAy/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPDL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      aHr7P+B4+z9gevs/
                                      4Hj7PwB6+z+HrjGXTEP7P6gy/T9oevs/pEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                                      GAAAAGR2+z9pcGMwAPHSUYYL2UPLt7EAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANj60g==
                                      5DYIQLBmCUAwBwYAlDQIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACwZgmA
                                      gHn7PwAAAAD/////QN37PxxE/D/+AAAAUQYAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
                                      AAAAAOQ4CEAcRPw/zIoJQKRd+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4Hn7PzRB/D8AAAAA
                                      AAAAADQKAAD+AAAAUQYAAP/////gefs/NEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                                      AAAAAAB6+z8AAAAAAAAAALh+CEAAAAAAAAAAAAAAAADpEwiAIDz+P4xB/D+PaUA/
                                      AAAAAAAAAAAMevs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      REP7P3BB+z88Q/s/
                                      cEH7P9BC+z8TIhymhHL7P3B6+z9EQ/s/pEH8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                                      FwAAAEA1+z93aWZpAL6bfa7+shKU8Z4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPm3Q==
                                      5DYIQLBmCUAwCQYArVwXgDBC+z9QLvs/oEL7P5wu+z8AAAAApC77PwAAAACwZgmA
                                      EEL7PwAAAAD/////QN37PxxE/D/+AAAAAAAAAB4AAAD1NBSAUEL7P+BNCUD8TQlA
                                      /////+Q4CEAcRPw/zIoJQHQm+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAB41/w/GwAAAAAAAAAZeRWAcEL7P1Au+z+gQvs/
                                      AAAAAPK1AgAAAAAAUPr9P/////9wQvs/AAAAABT6/T8JAAAA4Aj8P6AI/D8BAAAA
                                      AAAAAJBC+z/YBfw/dAv8P/////+AAAAAxAAAAHAL/D8AAAAA0EL7PwAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaOb8PxoAAABoCPw/
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3EL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      fHL7P+Bw+z90cvs/
                                      4HD7PxBy+z+XlaRrrEH8P0xD+z98cvs/pEH8PwMAAABwQPw/cED8P3xy+z9oQPw/
                                      FgAAAHhm+z9lc3BfdGltZXIA30u6hkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJcfvg==
                                      5DYIQLBmCUAwAQYA/SwNgKBx+z9EQPw/AAAAAJBA/D8AAAAARED8PwAAAACwZgmA
                                      gHH7PwAAAAD/////QN37PxxE/D/+AAAA/T4CAAAAAAAKAAAAAAAAAOBNCUD8TQlA
                                      /////+Q4CEAcRPw/zIoJQLRV+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAKEaCICgcfs//Nz7P/9zq34AAAAA4HH7P5hA/D+gQPw/
                                      AAAAAPO1AgBQLvs//T4CAP/////gcfs/AAAAAKBA/D/YBfw/AAAAACRw9D8AAAAA
                                      AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKBA/D/L5pYK
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHL7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      rLH7P/Cg/T+Eov0/
                                      8KD9PyCi/T/gAAAA9MP9P6xB/D+ssfs/pEH8PxQAAAD8TQlAAAAAAKyx+z8AAAAA
                                      BQAAAIiS/T9TbWFydENvbmZpZwD//z8AAQAAAISi/T8AAAAAIQAGAAUAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAAAAAA==
                                      5DYIQPC/AEAwAAYAWnIJgLCh/T8AAAAAIwAGACAABgAAnfs/AwAAACMDBgD//z+z
                                      q6sAAOzc+z8jAAYArLH7PwEAAAD+AAAAmAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                                      AAAAAOQ4CEABAAAAzIoJQMSF+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACigwmAwKH9P0Dd+z8FAAAA
                                      B3oOgOCh/T8BAAAAIET8P6yx+z8BAAAA/gAAACADBgAAAAAAAKL9PwAAAAAAAAAA
                                      HET8P0Dd+z+QQfw/lEL8PwAAAAAgov0/AAAAAAAAAABET/w/AAAAAAAAAAAAAAAA
                                      AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALKL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
                                      Rebooting...
                                      ets Jun  8 2016 00:22:57
                                      rst:0xc (SW_CPU_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
                                      configsip: 0, SPIWP:0xee
                                      mode:DIO, clock div:1
                                      load:0x3fff8020,len:8
                                      load:0x3fff8028,len:2176
                                      load:0x4009fa00,len:19740
                                      entry 0x400a05bc
                                        andreas @sita
                                        Thanks! Decoding this yields
                                        #0  mp_execute_bytecode (code_state=0x3f94eef0, inject_exc=0x0) at ../py/vm.c:1306
                                        #1  0x401024b3 in fun_bc_call (self_in=<optimized out>, n_args=<optimized out>, n_kw=0, args=0x3ffd8280) at ../py/objfun.c:287
                                        #2  0x400fe7c4 in mp_call_function_n_kw (fun_in=0x3f94ed60, n_args=0, n_kw=0, args=0x0) at ../py/runtime.c:624
                                        #3  0x400fe7f1 in mp_call_function_0 (fun=0x3f94ed60) at ../py/runtime.c:598
                                        #4  0x400e2090 in parse_compile_execute (source=0x3f94eda6, input_kind=MP_PARSE_FILE_INPUT, exec_flags=32) at ../lib/utils/pyexec.c:103
                                        #5  0x400e2320 in pyexec_file (filename=0x3f94eda6 <error: Cannot access memory at address 0x3f94eda6>) at ../lib/utils/pyexec.c:550
                                        #6  0x400e0d84 in TASK_Micropython (pvParameters=<optimized out>) at mptask.c:320
                                          Id   Target Id         Frame
                                          17   process 16        0x4000bff0 in ?? ()
                                          16   process 15        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffc4044 <s_timer_semaphore_memory>, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                          15   process 14        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb2e50, pvBuffer=0x3ffb42a0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                          14   process 13        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb760c, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                          13   process 12        0x4000bff0 in ?? ()
                                          12   process 11        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffbd338, pvBuffer=0x3ffd91d0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                          11   process 10        0x400966b0 in xQueueGenericReceive (xQueue=0x3ffb7bd8, pvBuffer=0x0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                          10   process 9         0x400966b0 in xQueueGenericReceive (xQueue=0x3ffdb290, pvBuffer=0x3ffdeab0, xTicksToWait=4294967295, xJustPeeking=0) at /home/gezahusi/Work/Repositories/pycom-esp-idf/components/freertos/queue.c:1592
                                          9    process 8         0x4000bff0 in ?? ()
                                          8    process 7         /builds/idf/crosstool-NG/.build/src/gdb-7.10/gdb/inline-frame.c:171: internal-error: inline_frame_this_id: Assertion `!frame_id_eq (*this_id, outer_frame_id)' failed.
                                        So, the core dump seems to happen right away after system start while executing the Python file
                                        I have never seen that before! The file might be corrupted somehow.
                                        • Is this the core dump which is happening immediately after uploading the MicroPython file to the system?
                                        • Can you get another core dump which is coming from the system after a short run time i.e. after hitting the reset button?
                                        • Can you show your current MicroPython code again?
                                        • You might also want to try yet another erase_all [1] / erase_flash procedure first.
                                        [1] Please don't miss the corresponding installation notes when invoking erase_all on LoPy devices.
                                        A S 2 Replies Last reply Reply Quote 0
                                          andreas @andreas
                                          Regarding the MicroPython code, I would suggest trying to invoke your program without any interaction on the filesystem and see whether it still crashes.
                                            sita @andreas
                                            Hello @andreas,
                                            I have attached the core dump which is observed after a short run.
                                            Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
                                            PC      : 0x40098fbb  PS      : 0x00060033  A0      : 0x80097e99  A1      : 0x3ffbf0c0
                                            A2      : 0x3ffbb95c  A3      : 0x00060023  A4      : 0x3ffc45f4  A5      : 0x00000001
                                            A6      : 0x000000fe  A7      : 0x3f95038a  A8      : 0x00000000  A9      : 0x3ffbb95c
                                            A10     : 0x3ffbb95c  A11     : 0x00000000  A12     : 0x8010a802  A13     : 0x3ffd8260
                                            A14     : 0x00000001  A15     : 0x00000000  SAR     : 0x00000003  EXCCAUSE: 0x0000001c
                                            EXCVADDR: 0x00000004  LBEG    : 0x400ed8d0  LEND    : 0x400ed913  LCOUNT  : 0x00000000
                                            Core 1 was running in ISR context:
                                            EPC1    : 0x40098fbb  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x00000000
                                            Backtrace: 0x40098fbb:0x3ffbf0c0 0x40097e96:0x3ffbf0e0 0x4009656d:0x3ffbf100 0x400890bb:0x3ffbf120 0x40083949:0x3ffbf160 0x400e7009:0x3ffd81f0 0x401023ba:0x3ffd8220 0x400fe7c1:0x3ffd8240 0x400fe851:0x3ffd8260 0x4010a7ff:0x3ffd8280 0x401024b0:0x3ffd8320 0x400fe7c1:0x3ffd8350 0x400fe7ee:0x3ffd8370 0x400e208d:0x3ffd8390 0x400e231d:0x3ffd8430 0x400e0d81:0x3ffd8450
                                            pDQAAAEAAAAQAAAAbAEAAA==
                                            ZP39P6Ak/T+UJv0/
                                            oCT9PzAm/T/I5AEAqEL8P6hC/D9k/f0/oEL8PxMAAAB8/f0/AAAAAGT9/T8AAAAA
                                            BgAAAJgW/T9Mb1JhAAAAAAQAAAAAUFkAAQAAAJQm/T8AAAAAIQAGAAYAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADD+Pw==
                                            5DYIQE53CUAwDQYAjDMRgGAl/T/I5AEAQN37Pxgh/j8AAAAAAAAAAAAAAABOdwmA
                                            QCX9PwEAAADI5AEAZP39PwEAAAD+AAAAEAAAAA4AAADUCfo/AAAAAE4+CUBZPglA
                                            GCH+PwAAAAAAAAAAAAAAAAAAAAAwJv0/AAAAAAAAAAAIAAAAAAAAAAAAAAABAAAA
                                            AAAAAAAAAAAAAAAAAAAAAKUNQgcAAAAAAAAAAAAAAADMNkE/eAT8P1ia/D+W////
                                            HLP7PyCx/T+Isv0/
                                            ILH9PyCy/T/I5AEAlEL8P5RC/D8cs/s/jEL8PxQAAAAwOv4/MDr+Pxyz+z8AAAAA
                                            5DYIQE53CUAwDQYAyA4OgOCx/T/I5AEAQN37PwsAAAAA/wAAAAD/AAAAAP9OdwmA
                                            wLH9PwEAAADI5AEAHLP7PwEAAAD+AAAAIwAGAAAAAADEVg+AoLH9P+BNCUD8TQlA
                                            QLn7PxC3+z84ufs/
                                            ELf7P9C4+z9RFb1vvL77PzBC/D9Aufs/KEL8PxkAAABcufs/XLn7P0C5+z8AAAAA
                                            AAAAADy1+z9JRExFMABWwAmj07v92E4AAAAAADi5+z8AAAAAIAcGAAAAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEX5Fw==
                                            5DYIQLBmCUAwDwYApBQXgNC3+z/ktPs/AAAAADC1+z8AAAAA5LT7PwEAAACwZgmA
                                            sLf7PwAAAAD/////QN37PxxE/D/+AAAAqQ28PwoAAADkNghAsl4hQNDYDkAT2Q5A
                                            AAAAAOQ4CEAcRPw/zIoJQHSc+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAGC4+z8AAAAAAAAAAAAAAAAl2Q6AELj7PwEAAABAAAAA
                                            AAAAAAPlAQAAAAAAAAAAAP////8AgAAA//8AgAoAAACguPs/AAAAANDYDkAT2Q5A
                                            WEgPgEC4+z8AAAAAAQAAAHSc+D8Qkvw/AAAAAAAAAAAYAAAAAAAAAHTr/T8BAAAA
                                            ZGgXgGC4+z/4kfw/AQAAAAAAAAAJAAAAAIAAAP//AIAseQmAgLj7PwAAAAABAAAA
                                            AAAAALA//T8DAAAAIwAGAAAAAACguPs/AAAAALhB/D8AAAAAPPr8PxxE/D8AAAAA
                                            tL77PxC9+z+svvs/
                                            EL37P0C++z/MkOIQMEL8P0i5+z+0vvs/KEL8PxkAAACNMdnalEdm5bS++z8AAAAA
                                            AAAAALC6+z9JRExFMQDrX/9+n4oQORUAAQAAAKy++z8AAAAAIwAGAAAAAAAAAAAA
                                            5DYIQLZoIUAwCwYAdmgXgNC9+z8AAAAAMEL8PwtqCYDQsP0/AwAAACMABgAjAAYA
                                            gLH9P+zc+z8gDwYA//8/s6urAAD+AAAAAAAAAAAAAAAQvvs/AAAAAAAAAAAAAAAA
                                            AAAAAOQ4CECrqwAAzIoJQOSh+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAPPr8P8yKCUAseQmA8L37PyAAAAABAAAA
                                            tJ/7P9Ct+z/Er/s/
                                            0K37P2Cv+z805QEAHEL8PxxC/T+0n/s/FEL8PwcAAAAIn/s/CJ/7P7Sf+z8An/s/
                                            cK77PwAAAABgAAAAQN37PxxE/D/+AAAAAAAAABAAAADkNghANDYYQPHrGED66xhA
                                            AAAAANTkAQBkAAAAUDcYQGAAAACQrvs//gAAAAAAAABIOBiA4K77P7wMQj+YAJQ/
                                            rwEYgACv+z88+/w/MK/7P68BGIAAr/s/PPv8PzCv+z9gAAAA/////9TkAQAAAAAA
                                            FEL9PwBA/T8MQv0/
                                            AED9P6BB/T8E5QEAvJ/7PxxC/D8UQv0/FEL8PxMAAAAFAAAAkEH8PxRC/T8AAAAA
                                            5DYIQE53CUAwAQYAysofgMBA/T8E5QEAQN37PyD//T8AAAAAAAAAAAAAAABOdwmA
                                            oED9PwAAAAAE5QEAFEL9PwEAAAD+AAAAIwAGABEAAABEJfo/AAAAAAAAAAAAAAAA
                                            IMv7P8DJ+z8Yy/s/
                                            CgAAABzB+z9UbXIgU3ZjAA4cTdTiG3QAAAAAABjL+z8AAAAAIQAGAAoAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMCU8g==
                                            AAAAAAAAAAA=
                                            7MP9P1DC/T/kw/0/
                                            UML9P4DD/T/LQKlVCMr9P7Sx+z/sw/0/pEH8PxQAAABRiUhuVnTv3ezD/T8AAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAABAAAAAACBBw==
                                            5DYIQPC/AEAwAAYAWnIJgBDD/T8AAAAAIwAGACAABgCYzfs/VQAAAPCh/T///z+z
                                            3moOgEDD/T8BAAAAIET8P+zD/T8BAAAA/gAAAICD/T8AAAAAYMP9PwAAAAAAAAAA
                                            AMr9P1Dp/T9s6/0/
                                            CwAAAHDL/T9JUlFzAAAAAAAAAAAASa4AAQAAAGzr/T8AAAAAIQAGAAsAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAArv6CA==
                                            8On9PwEAAAD/////QN37PxxE/D/+AAAAAAAAAAAAAACkzvo/AAAAAAAAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAAyAAAApaWlpaWlpaV8FA6AUOr9P4CS/D+w6v0/
                                            AAAAAFQAAAClpaWlpaWlpf////9Q6v0/sJX8P7Dq/T8AAAAAAQAAAHSS/D8wAPw/
                                            AAAAAAAAAAAAAAAA
                                            MHz7P7Cc+z84nvs/
                                            sJz7P9Cd+z8sSBnimNn7PwjK/T8wfPs/pEH8PwEAAAAEfPs/BHz7PzB8+z/8e/s/
                                            GAAAADya+z9pcGMxAH1w+UnobXH5p5QAAQAAADie+z8AAAAAIQAGABgAAAAAAAAA
                                            5DYIQLBmCUAwBQYAlDQIgHCd+z/Ye/s/AAAAACR8+z8AAAAA2Hv7PwAAAACwZgmA
                                            UJ37PwEAAAD/////QN37PxxE/D/+AAAAIwAGABwAAACwnfs/OEH8PwAAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAADkOAhAAAAAAMyKCUAAAAAAsJ37PzhB/D8AAAAA
                                            AAAAAGQEAAAAAAAAAAAAAP////8AAAAAOEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                                            AAAAAAAAAAA=
                                            kNn7P9CQ/T+Akv0/
                                            0JD9PyCS/T9w2fs/qDL9Pzh8+z+Q2fs/pEH8PwUAAABk0/s/ZNP7P5DZ+z9c0/s/
                                            FAAAAISG/T9ldmVudFRhc2sA+z8AAAAAAAAAAICS/T8AAAAAIQAGABQAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHjBWQ==
                                            AAAAALwEAAD+AAAAIAAGAP/////Qkf0/jPr8PwAAAACE0/s/AAAAAFzZ+z8BAAAA
                                            AAAAACCS/T8AAAAAAAAAAA4AAADAQfs/AQEAAHzB/D8GAAAAogm8P///AABQBgAA
                                            KHNBPzwAAAACAAAAGMf8PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
                                            oDL9P9Aw/T+YMv0/
                                            0DD9PzAy/T8AEAAAcHr7P5jZ+z+gMv0/pEH8PxEAAAB4Yvs/eGL7P6Ay/T9wYvs/
                                            5DYIQPC/AEAwAAYAWnIJgJAx/T8AAAAAIwAGACAABgABAAAA/gAAACMABgD//z+z
                                            q6sAAEDd+z////////8/s6urAAD+AAAAAABAAAAAAAAAAAAAkEH8PwAAAAAAAAAA
                                            AAAAAOQ4CECrqwAAzIoJQNQV+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAANQV+j8AAAAAAAAAAAAAAACnZgmAoDH9P5hi+z//////
                                            AAAAAL8GAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAACYYvs/AAAAAKBi+z8AAAAA
                                            aHr7P+B4+z9gevs/
                                            4Hj7PwB6+z+XrzCfTEP7P6gy/T9oevs/pEH8PwEAAAA4dvs/OHb7P2h6+z8wdvs/
                                            GAAAAGR2+z9pcGMwAPHWUYaKWUfbt7EAAAAAAGB6+z8AAAAAIQAGABgAAAAAAAAA
                                            5DYIQLBmCUAwAQYAlDQIgKB5+z8Mdvs/AAAAAFh2+z8AAAAADHb7PwAAAACwZgmA
                                            gHn7PwAAAAD/////QN37PxxE/D/+AAAAHEL9PwAAAAAAAAAAAQAAAAAAAAAAAAAA
                                            AAAAADAKAAD+AAAAHEL9P//////gefs/NEH8PyRB/D8Advs/AAAAAAEAAAAAAAAA
                                            REP7P3BB+z88Q/s/
                                            cEH7P9BC+z8BIhymhHL7P3B6+z9EQ/s/pEH8PwIAAAB8Lvs/fC77P0RD+z90Lvs/
                                            FwAAAEA1+z93aWZpADqbfer+shKU8Z4AAAAAADxD+z8AAAAAIQAGABcAAAABAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANPmnQ==
                                            EEL7PwAAAAD/////QN37PxxE/D/+AAAAAAAAABwAAAD1NBSAUEL7P+BNCUD8TQlA
                                            AAAAAAAAAAAAAAAAAAAAAN9SFYBAQvs/AAAAAOiVCEAZeRWAcEL7P1Au+z+gQvs/
                                            AAAAAPPkAQDwIgzAACAMAP////9wQvs/uL4AQAAAAABEQ/s/4Av8P+AL/D8BAAAA
                                            AAAAAJBC+z/YBfw/dAv8P/////8AAAAAxAAAAHAL/D8AAAAA0EL7PwAAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAsAAACUDbw/AAAAAAAAAAAAAAAAaOb8PxoAAABoCPw/
                                            fHL7P+Bw+z90cvs/
                                            4HD7PxBy+z8HlaRrrEH8P0xD+z98cvs/pEH8PwMAAABwQPw/cED8P3xy+z9oQPw/
                                            FgAAAHhm+z9lc3BfdGltZXIA30u4hkQAAAAAAHRy+z8AAAAAIQAGABYAAAAAAAAA
                                            AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAJZbvA==
                                            gHH7PwAAAAD/////QN37PxxE/D/+AAAAJLP7PwAAAAAKAAAAAAAAAOBNCUD8TQlA
                                            AAAAAAAAAAAAAAAAAAAAAEDd+z8cRPw//gAAACSz+z8AAAAA4HH7P5hA/D+gQPw/
                                            AAAAAPPkAQBQLvs/JLP7P//////gcfs/AAAAAKBA/D8AAAAAAAAAACRw9D8AAAAA
                                            AAAAABBy+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKBA/D/6gGYH
                                            rLH7P/Cg/T+Eov0/
                                            8KD9PyCi/T/Gxsjt9MP9P6xB/D+ssfs/pEH8PxQAAAD7mJIwA0gB/6yx+z8AAAAA
                                            BQAAAIiS/T9TbWFydENvbmZpZwBUAAAAAQAAAISi/T8AAAAAIQAGAAUAAAAAAAAA
                                            5DYIQPC/AEAwAAYAWnIJgLCh/T8AAAAAIwAGACAABgDg8Ps/AwAAACMABgD//z+z
                                            q6sAAOzc+z8jAAYArLH7PwEAAAD+AAAAAAAAAAAAAAClpaWlpaWlpQAAAAAAAAAA
                                            B3oOgOCh/T8BAAAAIET8P6yx+z8BAAAA/gAAACAAAAAAAAAAAKL9PwAAAAAAAAAA
                                            Rebooting...
                                            rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                                            entry 0x400a05bc
                                            • 1
                                            • 2
                                            • 3
                                            • 2 / 3
