    gpy camera?
    10 Posts 4 Posters 224 Views 6 Watching
    • K Offline
      kjm
      In my rpi days if I needed to grab the occasional still frame from a remote site it was as simple as plugging in a usb web cam, and uploading a 640x480 pic over 4G was no problem.
      Solutions for the gpy seem a bit scarce? https://forum.pycom.io/topic/5650/connecting-camera-to-fipy-new-findings-of-non-ee has opted for an idea that uses 2 different buses but that looks complicated. Is there an easy way to get a usb cam connected to a gpy via a usb-to-uart adapter or is the gpy uart not fast enough?
        crumble
        You can try to use an rs232 camera module.
        • K Offline
          kjm
          Do you know of a micropython lib that can tickle a serial webcam to regurgitate an image? I was hoping for something as easy as os.system('fswebcam -r 640x480 -S10 image.jpg') on the pi?
          C J 2 Replies Last reply Reply Quote 0
            crumble @kjm
            @kjm
            No. I don't know if there is a standard for simple image download. Some serial cameras have features for private robotics or industrial usage. So they can detect/trace objects or QR codes and tell you their special data. So I guess you have to implement the download by your own.
            The adafruit and Pixy2 CMUCam5 have python examples. May be a start for you.
              jcaron @kjm
              @kjm The most common camera for ESP32 projects and other MCUs seems to be the OV2640 mentioned in the link above. Note that the "raw" camera seems to have a pretty nasty interface, you probably want the Arducam SPI or some equivalent, which has SPI and I2C interfaces.
              There's a micropython driver for it, though it was targeted at the ESP8266 Arduino boards. I don't think it should be very difficult to adapt to a Pycom board. There's a long discussion here and it seems someone managed to get it to run on a GPy.
              Once you get things sorted it's just as simple as:
              import ov2640
              cam = ov2640.ov2640()
              nbytes = cam.capture_to_file("/image.jpg")
              From what I understand performance is pretty bad, but for a single picture it should work out OK I suppose.
                grpatt
                I was able to get the Arducam working on the gpy.
                https://github.com/grahamPatico/micropython-ov2640-Pycom?organization=grahamPatico&organization=grahamPatico
                K 1 Reply Last reply Reply Quote 3
                • K Offline
                  kjm @grpatt
                  @grpatt I'm impressed and envious because the chances of me getting something that uses 2 busses to work are low. I don't understand why there isn't any uart based code for serial cams in micropython.
                    jcaron @kjm
                    @kjm Seeed’s VC0703-based serial cam has a protocol so simple that it shouldn’t take long to write a driver. Adafruit’s VC0706-based serial camera has CircuitPython drivers, I suppose that should be easy to port to micropython.
                    I suspect performance may be quite lower than the other cams, though, and the cost higher.
                    Remember that I2C and SPI can be shared (via addressing or chip select), though.
                      grpatt
                      I am working with a Spinel 1.3MP WDR Serial JPEG Color Camera Module TTL/UART Output. I got most of photo working but I am not familiar with hex to jpg. I translate hex to the picture of my dog using https://codepen.io/abdhass/full/jdRNd.
                      from machine import UART
                      from machine import SD
                      import os
                      import gc
                      import ubinascii
                      is_sd_mounted = False
                      uart = UART(1, baudrate=115200) #default baud of camera, this uses the UART_1 default pins for TXD and RXD (``P3`` and ``P4``)
                      gc.collect()
                      print(" ")
                      print("Free Memory:")
                      print(gc.mem_free())
                      print(" ")
                      LOG_PATH = '/sd'
                      def mount_sd():
                          global sd
                          global is_sd_mounted
                          try:    # try: again, we're preparing for a crash. If something goes wrong in the try: section, we'll jump to 'except Exception:' and do that instead of crashing.
                              os.mount(sd, LOG_PATH)
                              print("SD mounted OK")
                              is_sd_mounted = True
                          except Exception:   # Failed to mount SD
                              print("ERROR: Can't mount SD card")
                              sd = None
                      def reset():
                          uart.write(b'\x56\x00\x26\x00') #Send reset command
                          time.sleep(4)
                          recv=uart.read() # read up to 5 bytes
                          print("Version:")
                          print(recv)
                          print(" ")
                      def takephoto():
                          uart.write(b'\x56\x00\x36\x01\x00') #Send take photo command
                          time.sleep(4)
                          print("Take Photo:")
                          print(recv)
                          print(" ")
                      def changesize():
                          uart.write(b'\x56\x00\x31\x05\x04\x01\x00\x19\x11') #Send take photo command
                          time.sleep(4)
                          print("Size:")
                          print(recv)
                          print(" ")
                      def compress():
                          uart.write(b'\x56\x00\x31\x05\x01\x01\x12\x04\x72') #Send take photo command
                          time.sleep(4)
                          print("Compression:")
                          print(recv)
                          print(" ")
                      mount_sd()
                      time.sleep(3)
                      reset()
                      changesize()
                      compress()
                      takephoto()
                      uart.write(b'\x56\x00\x34\x01\x00') #Send get image length command
                      time.sleep(2)
                      print("READ IMAGE DATA LENGTH")
                      print(recv)
                      print("Image Size: "+str(int(ubinascii.hexlify(recv[5:9]),16)/1024)+" KB")
                      print("READ IMAGE DATA")
                      uart.write(b'\x56\x00\x32\x0C\x00\x0A\x00\x00\x00\x00')
                      uart.write(recv[5:9])
                      uart.write(b'\x00\xFF') #Send get image length command
                      #count=0
                      pic=ubinascii.hexlify(uart.read(500))
                      time.sleep(2)
                      while uart.any()>0:
                          pic=pic+ubinascii.hexlify(uart.read(500))
                          time.sleep(.01)
                      #print(pic)
                      #print(type(pic))
                      uart.write(b'\x56\x00\x36\x01\x03') #STOP CAPTURE
                      #print("uartany")
                      #print(uart.any())
                      pic=pic[10:-10]
                      data = pic
                      print(data)
                      file='/sd/image122o23.txt'
                      print(file)
                      f = open(file, 'wb') # open for writing
                      f.write(data)
                      time.sleep(2)
                      f.close()
                      gc.collect()
                      print(" ")
                      if is_sd_mounted:
                          try:
                              os.unmount(LOG_PATH)
                              print("SD unmounted")
                          except Exception:
                              print("Failed to unmount {}".format(LOG_PATH))
                          print("Unmount SD not required")
                        grpatt
                        https://forum.pycom.io/topic/6835/camera-uart-reading-pycom?_=1613190557153
                        I did get a better camera working.
