    New firmware release 1.6.7.b1 (LoRaWAN Nano Gateway with TTN example!!)
    firmware
    113 Posts 34 Posters 89.0k Views 32 Watching
      jomifo Pybytes Beta @daniel
      @daniel +1 to see code adapted for US frequencies.
        Colateral
        Hello Daniel,
        You promised weeks ago (around build 1.3.0) that you will enable frozen bytecode. When this will happen?
          johncaipa
          Is there anyone who has tested how many nodes could be received in practice with the nano-gateway?
            Colateral @johncaipa
            @johncaipa So far we tested with 7 nodes .... but not with pycom nano-gw example.
              gerkez
              Hello Daniel,
              The scripts look great, but I don't seem to get them working.
              I have created a gateway in the TTN console, but the gateway doesn't connect.
              I have a WiFi connection to my router, so that is not the problem.
              In your config.py:
              the GATEWAY_ID = '11aa334455bb7788'. Where did you get this ID?
              I created my own ID when I registered a gateway at TTN console.
              Can I leave the LORA_DR = "SF7BW125" # DR_5 unchanged?
              In the nanogateway.py:
              def stop(self):
              # TODO: Check how to stop the NTP sync
              # TODO: Create a cancel method for the alarm
              # TODO: kill the UDP thread
              self.sock.close()
              I have no idea how to handle those TODO's.
              Can you give some examples?
              Hopefully you can help a newbee to get this working.
              GerkeZ
                daniel
                @gerkez you can put there in the Gateway ID that you created when registering it to TTN.
                Yes.
                Don't worry about those TODO's, those will be taken care of on a future update of the nanogateway scripts.
                Cheers,
                Daniel
                  jmarcelino @gerkez
                  @gerkez
                  also make sure you have selected the "packet forwarder" protocol when registering the gateway in TTN. I think your ID question may relate to this.
                    gerkez @daniel
                    @daniel
                    Thanks. I'll try it and let you know
                      gerkez @jmarcelino
                      @jmarcelino
                      Hi. Thanks.
                      I deleted my gateway and registered a new one with the "packet forwarder" protocol.
                      It generates a Gateway ID based on the EUI (eui-70b3d54991ae49e8).
                      I tried both ID's in the config.py.
                      eui-70b3d54991ae49e8: script runs but the console displays "not connected".
                      70b3d54991ae49e8 (without prefix eui-): script runs but restarts all the time.
                      Here is my config.py:
                      GATEWAY_ID = 'eui-70b3d54991ae49e8' (not working)
                      GATEWAY_ID = '70b3d54991ae49e8' (infinite loop, restart)
                      SERVER = 'bridge.eu.thethings.network'
                      PORT = 1883
                      NTP = "pool.ntp.org"
                      NTP_PERIOD_S = 3600
                      WIFI_SSID = 'my ssid'
                      WIFI_PASS = 'my passwd'
                      LORA_FREQUENCY = 868100000
                        daniel
                        The correct gateway ID to use is: 70b3d54991ae49e8
                        These 2 parameters are incorrect:
                        PORT = 1883
                        Please use the same as in the example, which are:
                        SERVER = 'router.eu.thethings.network'
                        PORT = 1700
                        Cheers,
                        Daniel
                          gerkez @daniel
                          @daniel
                          @jmarcelino
                          Hi Guys,
                          Thanks a lot for helping.
                          I have a connection to TTN, but is seems that my lopy reboots all the time (every 30 -60 seconds).
                          I hav put a red led for 3 seconds in main.py and I can see this red led light up all the time and than I lose my connection (wiFi as well).
                          Hope you have an idea what's going wrong
                          L S 2 Replies Last reply Reply Quote 0
                            livius @gerkez
                            @gerkez
                            What you got on UART REPL?
                            Put info here - there can be some usefull info
                            G 2 Replies Last reply Reply Quote 0
                              gerkez @livius
                              @livius
                              Hello Livius,
                              My pymakr doesn't work. Connection errors.
                              So I use Putty. Problem is that the device reboots all the time, so I don't see anything on the UART REPL
                                livius @gerkez
                                @gerkez
                                Try Arduino IDE -> COM port monitor instead
                                • Z Offline
                                  zmrzli @Colateral
                                  @Colateral
                                  My problem was that password was not long enough. Once I changed it, it worked fine. It would be better if some indication was given about a problem from WiPy, but no big deal, once understood...!
                                    gerkez @zmrzli
                                    @zmrzli
                                    Which password do you mean?
                                      Shaun @gerkez
                                      @gerkez Are you using a custom base PCB (your own) or are you using the Pycom expansion PCB?
                                      I ask, as you may be running into the WiPy resetting due to rf reflections issue.
                                        gerkez @Shaun
                                        @Shaun
                                        I am using a pycom expansion board with LoPy
                                          Shaun @gerkez
                                          @gerkez Ok, then you should not be experiance problems from rf reflections, and should be able to rule it out.
                                          I doubt you are working on a conductive table ;-)
                                            gerkez @livius
                                            @livius
                                            Hello Livius.
                                            Here is what I see on my W UART REPL:
                                            I (146522) wifi: mode : sta (24:0a:c4:00:84:44)
                                            I (146523) wifi: sleep disable
                                            I (146650) wifi: n:1 0, o:6 0, ap:255 255, sta:1 0, prof:6
                                            I (147638) wifi: state: init -> auth (b0)
                                            I (147640) wifi: state: auth -> assoc (0)
                                            I (147643) wifi: state: assoc -> run (10)
                                            I (147662) wifi: connected with IANNIS, channel 1
                                            WiFi connected!
                                            Push ack
                                            I (157644) wifi: pm start, type:0
                                            Pull ack
                                            Pull ack
                                            Push ack
                                            Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled.
                                            Register dump:
                                            PC : 0x400f6f9f PS : 0x00060b30 A0 : 0x800d8428 A1 : 0x3ffc5c30
                                            A2 : 0x000330d0 A3 : 0x3ffc666c A4 : 0x00000001 A5 : 0x00000000
                                            A6 : 0x00000000 A7 : 0x00000000 A8 : 0x800f5ed2 A9 : 0x3ffe96c0
                                            A10 : 0x00000001 A11 : 0x00000001 A12 : 0x3ffe21b0 A13 : 0x00000010
                                            A14 : 0x3ffe9830 A15 : 0x3ffe9790 SAR : 0x00000013 EXCCAUSE: 0x0000001c
                                            EXCVADDR: 0x000330d0 LBEG : 0x400f296c LEND : 0x400f2974 LCOUNT : 0x00000000
                                            Backtrace: 0x400f6f9f:0x3ffc5c30 0x400d8428:0x3ffc5c70 0x400d85b8:0x3ffc5c90 0x400d862b:0x3ffc5cb0 0x400d8b38:0x3ffc5ce0 0x400d8d52:0x3ffc5d00 0x400d7eff:0x3ffc5d40
                                            Here is a coredump. I haven't copied it.
                                            Rebooting...
                                            ets Jun 8 2016 00:22:57
                                            rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                                            configsip: 0, SPIWP:0x00
                                            mode:QIO, clock div:2
                                            load:0x3fff9010,len:8
                                            load:0x3fff9018,len:248
                                            load:0x40078000,len:4056
                                            load:0x4009fc00,len:920
                                            entry 0x4009fde4
                                            I (1542) wifi: wifi firmware version: 2a22b2d
                                            I (1558) wifi: pp_task_hdl : 3ffd72f8, prio:23, stack:8192
                                            I (1558) wifi: Init lldesc rx mblock:10
                                            I (1558) wifi: Init lldesc rx ampdu len mblock:7
                                            I (1560) wifi: Init lldesc rx ampdu entry mblock:4
                                            I (1565) wifi: sleep disable
                                            I (2553) wifi: frc2_timer_task_hdl:3ffdd348, prio:22, stack:2048
                                            I (2574) wifi: mode : softAP (24:0a:c4:00:84:45)
                                            MicroPython v1.8.6-493-g99ac80fe on 2017-03-03; LoPy with ESP32
                                            • 1
                                            • 2
                                            • 3
                                            • 4
                                            • 5
                                            • 6
                                            • 4 / 6
