  • Firmware Release v1.20.1
    Locked firmware
    68
    12k Views
    @robert-hh I am using a L01 (4MB SPIRAM + 8MB Flash)
  • PYMESH WORLD ATTEMPT on Saturday 22 September 2019
    pymesh lora marconi
    @Bettina This topic has been silent for a month. It is 6 days to Sep 22nd now, and no activity. May I assume that the attempt is silently canceled?
  • New Firmware Updater version 1.16.0
    In the download page : https://software.pycom.io/downloads/linux-1.16.0.html the version "Generic Linux with GLIBC 2.18 (and higher)" has wrong links, giving "404 Not Found".
  • NEW Jobs at Pycom
    Hey fellow pycomers/pycomista/pycomites. Why don't we lean on someone to apply? Be so nice to have a mole on the inside!
  • Accelerometer wake-up features added to Pytrack and Pysense
    library
    22
    12k Views
    Hi, I have an extra I2C sensor on the Pysense. (water pressure) I would like to wake up my lopy4 if it's above a certain value. Can this be done? And which code should I change/update? Thanks
  • BAND support for GPY and FIPY
    lte lte-m lte nb iot fipy gpy
    @naveen I paid EUR 2.90 for the return postage.
  • Expansion board 3.1 issues
  • New v3.1 Expansion Board Firmware: v0.0.11
    expansionboard update firmware
    v0.0.11 will lock your Expansion Board in DFU mode. Goodbye serial console. https://forum.pycom.io/topic/4684/exit-from-dfu-mode/13
  • Pycom Forum Outage expected for next Tuesday 28th May at 7AM UTC
    Locked
    Update done! Thanks all for your patience.
  • Pycom Forum Outage expected for next Monday at 8AM UTC.
    Cool Thanks!
  • Stable Firmware Release v1.18.2.r4
    firmware sequans
    Are there any release notes for the new sequans firmware? Any indication of feature changes or bug fixes?
  • New Firmware Release Candidate v1.20.0
    Locked firmware
    81
    24k Views
    Was in the watch out for the below upgrades lately. Glad Added support for setting mac addr for STA and AP Added API for sending Raw 80211 messages
  • We will update the forum today March 21st at 5PM UTC
    @alejandro Thanks :-)
  • 3 Votes
    @philwilkinson said in New LTE Firmware release v1.18.1.r3 & CAT-M1 firmware & modem updater: I have just attempted to upgrade a new module to the modem firmware. But I get the error statement, I have no idea what it refers to. any ideas? Do you know the firmware version of the modem when you started the upgrade? Which MicroPython firmware did you use? And which firmware upgrade file / method did you use to upgrade the modem?
  • Stable Firmware Release v1.18.2.r2
    Locked firmware
    That resolved all issues. Thanks.
  • New Stable Firmware Release v1.18.2
    firmware
    @paul-thornton Sorry Paul, I never saw your reply until today. Unfortunately our load is pretty complicated; we have one thread for each I2C bus we configure (1 or 2 depending on the system) and two threads doing socket communication (one for outgoing and one watching for incoming). We're keeping track of resets and will monitor the systems. If it doesn't improve with later firmware releases then I'll have to look at debugging the crash. Do you have instructions on how to go about that? -- Mike
  • Firmware Release Candidate v1.20.0.rc8
    firmware pymesh
    @rfinkers the Pymesh Docs page is under that link : https://docs.pycom.io/firmwareapi/pycom/network/lora/pymesh.html , it will be updated shortly with the Border router documentation.
  • LoRa alliance certification
    lora certificat lorawan certification
    Great news @Paul-Thornton! Congratulations I looked at the lora-alliance website put couldn't find the certification reports -- have you made them available? Obviously we would like to use your certification but need: the certification reports the git hashes or release number of the code which was actually certified Also are you planning on getting AU-915 certified, as it's a supported region in your software? The fixes to the stack and radio drivers that you mention sound great! I had an issue with the LBT in the radio (lack of filtering so that all channels could look busy) and am interested if that was addressed. Looking forward to the certificates and associated code! Regards, Brian
  • New firmware release v1.18.0
    firmware
    24
    @charly86 said in New firmware release v1.18.0: cardgenerator @iwahdan Nice, but that's not my PR so I don't want to get any credit for it ;-) Are you still facing this issue? @charly86 said in New firmware release v1.18.0: @iwahdan Nice, but that's not my PR so I don't want to get any credit for it ;-)
  • Important update regarding LTE modem updates
    lte
    123
    8 Votes
    46k Views
    @xykon having an issue now with modem upgrade lte.attach is stuck, same modem worked with code prior to update
