  • Announcements regarding our community
    3 Topics
    @jirkakrepl said in New Pybytes firmware 1.18.1.r9 (Experimental LTE support): If your LTE configuration is correct, your device with a Simcard should connect to Pybytes using LTE. Then Terminal and Flash OTA update should work too. Awesome, I'll try it out soon, thanks! LTE OTA was only thing holding us back from a production release.
  • Discussion for Feature Request and Future Additions to Pybytes
    15 Topics
    i am interested in your post, but can you share more detail
  • Discussion for Pybytes Beta Support and Assistance
    158 Topics
    Åke ForslundÅ
    Now it seems to be back up.
  • Move devices between projects
    @jirkakrepl Thank you very much! This will be really helpful.
  • OTA custom firmware
  • Accessing SD card via Pybytes?
    Great, thank you for your response. I'm glad to hear you're working on it! We currently do a lot of event logging to the SD card so it would be very useful to be able to grab those files remotely, or possibly even tail the last 100 lines or something on them.
  • Pybytes Token and data visualization
    @andreas said in Pybytes Token and data visualization: Data can be shipped en bloc using JSON or in a discrete way. See also [1] and [2]. [1] https://getkotori.org/docs/handbook/acquisition/protocol/mqtt.html#single-readings [2] https://getkotori.org/docs/handbook/acquisition/protocol/mqtt.html#multiple-readings
  • Building/Compiling MicroPython with Pybytes
  • Pybytes error publish 118
    @JeanJean Hi, can you send us the whole output you got from Pymakr (when device boots up and send a signal), please? It's possible that your device got disconnected from Pybytes, but then if you restart your device, won't that work?
    @iarakis said in LoPy4 can not connect to Pybytes. Exception: Board not detected: I2C bus error: Exception: Board not detected: I2C bus error The previous one is if I connect my LoPy4 to Makr board. If I connect to the Pysense board, I get the following: ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8028,len:8 load:0x3fff8030,len:1688 load:0x4009fa00,len:0 load:0x4009fa00,len:14592 entry 0x400a059c WMAC: 30AEA4EC88DC Firmware: 1.18.2.r6 Pybytes: 0.9.12 Pybytes configuration read from /flash/pybytes_config.json Initialized watchdog for WiFi and LTE connection with timeout 660000 ms WiFi connection established WARNING: consider enabling TLS by using pybytes.enable_ssl() Connected to MQTT mqtt.pybytes.pycom.io Pybytes connected successfully (using the built-in pybytes library) Now starting user code in main.py Connected to Wifi
  • Hidden network issue - Update?
    @robi90 Hello, great work! I will implement your solution, test and report. Many thanks. If I found a smoother way i will tell you. But for a workaround - great work! 👍
  • can't access pybytes.pycom.io - "connecting to pybytes"...
    It's back online now. Looks like they were pushing some major updates to the system and left us all hanging in the wind!
  • Pybytes custom app
  • PyBytes + EXT_ANT
    @robert-hh Thanks , I ll test asap, and add in my code P12 as Pin.OUT. Br
  • Pybytes LoraWan, How it works ?
    @jirkakrepl Autocomplete fail, I suppose.
  • Can't delete WiFi setting
    Hi, thank you for reporting this. It's the old issue that we fixed.
  • Pybytes - can't delete device file
    On a device, you can call os.mkfs('/flash') this will delete all the files in the /flash directory
  • Launching pybytes (pybytes autostart set to off)
    Hi, there is, we have function pybytes.start() You will need to instantiate pybytes object manually. Basically do the steps that this code is doing, when pybytes_autostart is True. https://github.com/pycom/pycom-micropython-sigfox/blob/pybytes-master/esp32/frozen/Base/_main.py#L21-L45 >>> from _pybytes_config import PybytesConfig >>> pybytes_config = PybytesConfig().read_config() >>> from _pybytes import Pybytes >>> pybytes = Pybytes(pybytes_config) this is how the full output if pybytes_autostart was false and how I manually connected to Pybytes later. (you can see the message: Not starting Pybytes as auto-start is disabled) rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8028,len:8 load:0x3fff8030,len:1688 load:0x4009fa00,len:0 load:0x4009fa00,len:14592 entry 0x400a059c Pybytes configuration read from /flash/pybytes_config.json Not starting Pybytes as auto-start is disabled Pycom MicroPython 1.18.2.r6 [v1.8.6-849-a210e85] on 2019-05-13; WiPy with ESP32 Type "help()" for more information. >>> from _pybytes_config import PybytesConfig >>> pybytes_config = PybytesConfig().read_config() >>> from _pybytes import Pybytes >>> pybytes = Pybytes(pybytes_config) WMAC: 240AC40B3A1C Firmware: 1.18.2.r6 Pybytes: 0.9.12 >>> pybytes.connect() Initialized watchdog for WiFi and LTE connection with timeout 660000 ms WiFi connection established WARNING: consider enabling TLS by using pybytes.enable_ssl() Connected to MQTT 10.0.0.66 Pybytes connected successfully (using the built-in pybytes library) >>>
