  • Announcements regarding our community
    3 Topics
    @jirkakrepl said in New Pybytes firmware 1.18.1.r9 (Experimental LTE support): If your LTE configuration is correct, your device with a Simcard should connect to Pybytes using LTE. Then Terminal and Flash OTA update should work too. Awesome, I'll try it out soon, thanks! LTE OTA was only thing holding us back from a production release.
  • Discussion for Feature Request and Future Additions to Pybytes
    15 Topics
    i am interested in your post, but can you share more detail
  • Discussion for Pybytes Beta Support and Assistance
    158 Topics
    Åke ForslundÅ
    Now it seems to be back up.
  • Minimum wait time between send_signal()
    Hi, I should be 60 messages per 1 minute. You should be able to send two messages after each other.
  • WHat is the deep sleep shield?
    Obviously you didn't look hard enough: lhttps://docs.pycom.io/datasheets/boards/deepsleep/ It's right there in the docs
  • Pymaps pricing
    MarianoM
    Hi Davorin, The 7 cents is the cost per location request. Sorry for the waiting!
  • Send data from IOT platform to WiPy
    it is not possible (yet?) i think pybytes is running on mqtt so it would be quite easy to implement this servers side. mqtt does support 2 way communication and pybytes is still beta so i think in the future it will be possible
  • Pybytes and Gpy CAT-M1
    Hi @Ross-Leamon, at this moment you can manually setup LTE already with Pybytes: https://forum.pycom.io/topic/4185/new-pybytes-firmware-1-18-1-r9-experimental-lte-support
  • 3 Votes
    @eric-waai I tried twice in our office, my device got successfully updated from 1.18.2.r0 -> 1.18.2.r2
  • [solved] Pybytes auto reconnect?
    Moved beta
    @protean WiFi connection should now be much more stable in the new firmware 1.18.2.r2. https://forum.pycom.io/topic/4446/update-to-pybytes-firmware-1-18-2-r2-solving-device-wifi-connectivity-issues Please update your device!
  • pybytes coredump
    beta
    @jirkakrepl i Don't have that exact software version anymore and you couldn't do much with it because it communicates via CAN-bus with some other devices you probably don't have. the sending to pybytes parts looks a lot like the provided example. the time it crashed i didn't update a part i only tried to open the flash tab in pybytes. i get the Error publish [Errno 12] ENOMEM more if i increase the wait time between some data bursts. with 60 seconds almost never but with 600 seconds more often.
  • [solved] How to manage WiFi networks?
    beta
    Hi @nervencid, this table is only for saving wifi credentials in Pybytes. These wifi credentials could be selected (from the combo box) when you create a new device profile in Pybytes. At this moment a device profile is "locked" with one wifi credentials which were selected during that particular device profile creation. After that only when you update your Pycom device with the firmware updater, a Pycom device will receive new wifi credentials from Pybytes.
  • [solved] No data on dash board since update
    beta
    @jirkakrepl Thanks for the response. I updated my code with the new command and it works fine.
  • PyBytes OTA ?
    beta
    Hi, Any news on an update for this? We also are looking to widely deploy Pycom's but this looks like it could be a roadblock for us.
  • Stacked chart option
    beta
    Hi @dnear1 stacked option could create a stacked bar chart if you send an array of a tupple of values with your signal. But at this moment we don't support it, so it does nothing. We're going to refactor this part of UI. We're going to update docs this week.
  • Pycom Firmware Software does not support Pybytes Registration
    beta
    @reidfo Im as confused as you are.. Think the spam bots are leaking.
  • Pybytes dashboard not accepting data
    beta
    Glad you worked it out :) Ill try and get a note added to the documentation so this is more clear.
  • Pybyte and Pymate
    beta
    Hi,SiPy is already supported in Pybytes.
  • Enable PyBytes in Micropython build
    beta
    Hi @brady-aiello, let me know if it still doesn't work and I'll help you out
  • Hidden network issue - not connecting
    beta
    @dan OK, it would be great.
    Hello, zip archive which you can download from Pybytes contains just Pybytes library (python code) which you can flash manually with Pymakr. Tar files are firmware files for Pycom boards.
  • Disable pybytes
    beta
    tobzT
    @jirkakrepl Aha, awesome, thanks
  • Rest API
    beta
    Hi @robmarkcole, we don't have a release date for it yet
