    SiPy's ID and PAC
    sigfoxsipy
    23 Posts 8 Posters 7.4k Views 7 Watching
      michal.zykov @bucknall
      Hi @bucknall!
      Even if I use the mentioned snippet the same output can be seen, i.e. b'ffffffff'. Any suggestion?
      Mike
        bucknall @michal.zykov
        Hi @michal.zykov! First of all, have you updated your SiPy? And if so are you using Debian (Linux) to update your device?
        Developer Evangelist - Pycom
          Hi @bucknall!
          Yep, I already updated SiPy by using Linux updater (Fedora 25) - SiPy firmware 1.6.7.b1. I'm able to send a print-screen that it was successful.
          Thx,
          Mike
            @michal.zykov, we've identified a problem with the Linux Firmware Updater and are handling it now. If you could use the Windows or Mac OS Firmware Update tool, that should get you up & running for the time being!
            Apologies about this! We're working to get it sorted asap!
              Hi @bucknall!
              I've tried to re-flash SiPy by using MS Windows firmware updater. It works great! Thank you! Hope, you'll be able to fix Linux firmware updater soon.
              Mike
                josep.salom
                I have the same problem. How could I find the right Device ID and PAC?
                I'm using Mac OS X.
                • X Offline
                  Xykon administrators @josep.salom
                  @josep-salom Can you please provide more details? What is the output you get from the commands?
                  Christian Ehlers
                    josep.salom @Xykon
                    @xykon I'm using the procedure as indicated in https://docs.pycom.io/chapter/gettingstarted/registration/sigfox.html, and I got:
                    b'ffffffff'
                    b'ffffffffffffffff'
                    MicroPython v1.8.6-470-gf41d0f27 on 2017-02-22; SiPy with ESP32
                    which are not correct ID and PAC.
                    I'm using SiPy module with Pysense, on a Mac OS X 10.11.6 running Visual Studio Code.
                      josep.salom
                      @xykon I've just upgraded SiPy and still have the problem:
                      b'ffffffff'
                      b'ffffffffffffffff'
                      Pycom MicroPython 1.18.0 [v1.8.6-849-046b350] on 2018-06-01; SiPy with ESP32
                      How could I get the right ID and PAC?
                      • X Offline
                        @josep-salom Sigfox registration requires using the firmware updater in online mode.
                        Christian Ehlers
                          josep.salom @Xykon
                          @xykon So sorry, I'm very new on that. What does it exactly mean? How should I do that?
                          • X Offline
                            @josep-salom You need to solve this problem first so that you can use the firmware updater in online mode. This is required to get your Sigfox ID and PAC allocated. I suggest you email us with your IP address so that we can do some testing.
                            Christian Ehlers
                              Colateral @bucknall
                              @bucknall For SIgfox backend registration I beleive I need to put the ID and and PAC out put from with hexlifiy
                              print("ID ", ubinascii.hexlify(sigfox.id()))
                              print("PAC ", ubinascii.hexlify(sigfox.pac()))
                              in my case is:
                              ID b'004e3d90'
                              PAC b'c957cd18b7848c0'
                              so ID that I typed is '004e3d90' and PAC 'c957cd18b7848c0'
                              The device seems to be registered but on backend device webpage I can not see it online at all. How I do I know when is connected to the (Luxembourg) Sigfox network and will get online?
                              It is done immediately or shall I wait?
