    FiPy firmware upgrade failed - Cat M1
    firmwareupdatepytracksqnsupgradecat m1
    32 Posts 6 Posters 5.9k Views 8 Watching
      rskoniec @ArnaudP
      @arnaudp Can you try:
      os.mkfs(sd)
      and then:
      os.mount(sd, '/sd')
      os.listdir('/sd')
        ArnaudP @rskoniec
        @rskoniec Same issue :
        >>> os.mkfs(sd)
          rskoniec @ArnaudP
          @arnaudp So maybe you should try with 8/16 GB SD card. FYI, os.mkfs(sd) is formatting your SD card to the right filesystem for Pycom devices. So after that you should remove SD card from PyTrack, put into your PC, copy files and then insert back again to the PyTrack, reset by button your FiPy and from fresh REPL:
          from machine import SD
          sd = SD()
          os.mount(sd, '/sd')
          os.listdir('/sd')         # to check if the files exist on SD card
          import sqnsupgrade
          sqnsupgrade.run('/sd/CATM1-39529.dup', '/sd/updater.elf')         # for CAT-M1
          sqnsupgrade.run('/sd/NB1-40343.dup', '/sd/updater.elf')             # for CAT-NB1
            ArnaudP @rskoniec
            @rskoniec Ok ! So I have formatted it again and now it works !
            Now here's the new issue :
            Attempting AT wakeup...
            Sending 55498 bytes: [########################################] 100%
            Received ERROR from AT+SMSWBOOT=0,1! Aborting!
            Unable to upgrade bootrom.
            Unable to load updater from /sd/updater.elf
              rskoniec @ArnaudP
              @arnaudp I think you've got incomplete file/files - 55498 bytes is too short (incomplete download from https://software.pycom.io/downloads/sequans2.html ?).
              CATM1-39529.dup is almost 6MB big
              updater.elf is over 400KB big
                ArnaudP @rskoniec
                @rskoniec Yup, that's the file I have on my disk, just checked the size with a freshly dowloaded version. It seems that it's the sending that didn't work. And now it says it won't detect the modem (perhaps because of faulty upgrade). Ok not anymore
                But my files are the right ones on the disk :/
                  ArnaudP @rskoniec
                  @rskoniec
                  With some debug infos. We can see the files are listed with their right size :
                  File /sd/updater.elf has size 429340
                  File /sd/CATM1-39529.dup has size 6059510
                  Here is the complete log :
                  >>> sqnsupgrade.run('/sd/CATM1-39529.dup', '/sd/updater.elf', debug=True)
                  <<< Welcome to the SQN3330 firmware updater [1.2.0] >>>
                  >>> FiPy with firmware version 1.18.1.r4
                  Modem state: 2
                  Checking bootrom & application
                  Checking line
                  Checking line SYSTEM VERSION
                  Checking line ==============
                  Checking line   FIRMWARE VERSION
                  Checking line     Bootloader0* : 5.1.1.0 [33080]
                  old_br: True
                  Checking line     Bootloader1  : NA
                  Checking line     Bootloader2  : NA
                  Checking line     NV Info      : 1.1,0,0
                  Checking line     Software     : 5.1.1.0 [33080] by robot-soft at 2017-10-27 07:49:11
                  old_sw: True
                  Checking line     UE           : Unknown
                  Checking line   COMPONENTS
                  Checking line     ZSP0         : 1.0.98-12323
                  Checking line     ZSP1         : 1.0.98-12295
                  Checking line
                  Checking line OK
                  Checking line
                  Returning: True
                  mirror? False  recover? False  resume? False  direct? False  atneg_only? False bootrom? True load_fff? False
                  Initial prepartion complete...
                  Loading built-in recovery bootrom...
                  b'\r\nOK\r\n'
                  Entering upgrade mode...
                  AT+SMOD? returned 2
                  AT+SMSWBOOT=3,1 returned: b'\r\nOK\r\n'
                  Response after reset: b'\r\nERROR\r\n'
                  Starting STP
                  <<<=== DO NOT DISCONNECT POWER ===>>>
                  Sending AT+SMSTPU="ON_THE_FLY"
                  Starting STP code upload
                  magic=0x74736166, op=0x80, sid=0x0, plen=0x0, tid=0x0, hcrc=0x0, pcrc=0x18
                  Correct SRSP signature: 0x74736166
                  Bootrom updated successfully, switching to recovery mode
                  AT+SMSWBOOT=0,1 returned b'\r\nERROR\r\n'
                  Success1? False
                  Success2? False
                    rskoniec @ArnaudP
                    @arnaudp One more thing just came to my mind - do you have SIM card inserted in your FiPy? I don't know if this is an issue, but all of my FiPy modem f/w updates I've done with SIM card.
                      ArnaudP @rskoniec
                      @rskoniec We haven't received our cat-M1 SIM card yet. Do you think I can try with a regular SIM ?
                      In this video tutorial : https://core-electronics.com.au/tutorials/pycom-gpy-fipy-cellular-lte-firmware-update.html
                      it seems he hasn't put a sim card in it. Weird. Or the video is a bit outdated maybe.
                        rskoniec @ArnaudP
                        @arnaudp I've started a forum chat with you. Can we continue there?
                          ArnaudP @rskoniec
                          @rskoniec Sure, thanks :)
                            rskoniec @ArnaudP
                            @Xykon When I was helping @ArnaudP to resolve the problem with FiPy modem f/w update (sqnsupgrade.run('/sd/CATM1-version.dup', '/sd/updater.elf')) from initial release, we went this path:
                            • upgraded FiPy from 1.10.0.b1 to the latest stable 1.18.1.r4
                            • on FiPy 1.18.1.r4 modem f/w upgrade to the newest CATM1-39529 failed
                            • on FiPy 1.18.1.r4 modem f/w upgrade to previousCATM1-38638 failed
                            • downgraded FiPy from 1.18.1.r4 to 1.18.1.r1
                            • on FiPy 1.18.1.r1 modem f/w upgrade to CATM1-38638 successful
                            • now I'm waiting for @ArnaudP feedback about modem f/w upgrade to CATM1-39529 on FiPy 1.18.1.r4
                            • @ArnaudP has confirmed that after previous step, modem f/w upgrade to CATM1-39529 on FiPy 1.18.1.r4 was successful
                            What I've noticed is that updater.elf file in the previous CAT-M1/NB1 releases is the same and with a size of aprox. 300KB, but for the latest they are different for CAT-M1 (420KB) and NB1 (364KB). I've been told by @ArnaudP that he had already sent you a message.
                            John BairdJ 1 Reply Last reply Reply Quote 2
                              tom.beckingham
                                DDA
                                I am on the same page with version r4:
                                >>> import os
                                >>> sd=SD()
                                >>> os.mount(sd,'/sd')
                                >>> os.listdir('/sd')
                                ['upgdiff_38638-to-39529.dup', 'CATM1-39529.dup', 'upgdiff_33080-to-39529.dup', 'updater.elf']
                                >>> import sqnsupgrade
                                Please advise on how I may be able to downgrade to 1.18.1.r1, so I may be successful....per post below.
                                  rskoniec @DDA
                                  @dda Download 1.18.1.r1 from here https://software.pycom.io/downloads/FiPy-1.18.1.r1.tar.gz and downgrade using Pycom Firmware Upate tool with flash from local file option.
                                  • O Offline
                                    oyarzo-pablo @ArnaudP
                                    @arnaudp I've been attempting to update the modem from UART no SD card. Haven't been able to do it.
                                    • John BairdJ Offline
                                      John Baird @rskoniec
                                      @rskoniec Thanks for these detailed instructions. I've followed them and no longer get the Aborting error, however the process seems to fail:
                                      >>> sqnsupgrade.run('/sd/CATM1-38638.dup','/sd/updater.elf')
                                      <<< Welcome to the SQN3330 firmware updater >>>
                                      Starting STP (DO NOT DISCONNECT POWER!!!)
                                      Sending 54854 bytes: [########################################] 100%
                                      Bootrom updated successfully, switching to upgrade mode
                                      Attempting AT auto-negotiation...
                                      ERROR sending AT command... no response? b''
                                      AT auto-negotiation failed! Exiting.
                                      Any suggestions?
                                        rskoniec @John Baird
                                        @john-baird Can you try this? https://forum.pycom.io/topic/4022/unable-to-update-gpy-modem-firmware/4
                                        • 2 / 2
