    FiPy firmware upgrade failed - Cat M1
    firmwareupdatepytracksqnsupgradecat m1
    32 Posts 6 Posters 6.2k Views 8 Watching
      rskoniec @ArnaudP
      @arnaudp I think you've got incomplete file/files - 55498 bytes is too short (incomplete download from https://software.pycom.io/downloads/sequans2.html ?).
      CATM1-39529.dup is almost 6MB big
      updater.elf is over 400KB big
        ArnaudP @rskoniec
        @rskoniec Yup, that's the file I have on my disk, just checked the size with a freshly dowloaded version. It seems that it's the sending that didn't work. And now it says it won't detect the modem (perhaps because of faulty upgrade). Ok not anymore
        But my files are the right ones on the disk :/
          ArnaudP @rskoniec
          @rskoniec
          With some debug infos. We can see the files are listed with their right size :
          File /sd/updater.elf has size 429340
          File /sd/CATM1-39529.dup has size 6059510
          Here is the complete log :
          >>> sqnsupgrade.run('/sd/CATM1-39529.dup', '/sd/updater.elf', debug=True)
          <<< Welcome to the SQN3330 firmware updater [1.2.0] >>>
          >>> FiPy with firmware version 1.18.1.r4
          Modem state: 2
          Checking bootrom & application
          Checking line
          Checking line SYSTEM VERSION
          Checking line ==============
          Checking line   FIRMWARE VERSION
          Checking line     Bootloader0* : 5.1.1.0 [33080]
          old_br: True
          Checking line     Bootloader1  : NA
          Checking line     Bootloader2  : NA
          Checking line     NV Info      : 1.1,0,0
          Checking line     Software     : 5.1.1.0 [33080] by robot-soft at 2017-10-27 07:49:11
          old_sw: True
          Checking line     UE           : Unknown
          Checking line   COMPONENTS
          Checking line     ZSP0         : 1.0.98-12323
          Checking line     ZSP1         : 1.0.98-12295
          Checking line
          Checking line OK
          Checking line
          Returning: True
          mirror? False  recover? False  resume? False  direct? False  atneg_only? False bootrom? True load_fff? False
          Initial prepartion complete...
          Loading built-in recovery bootrom...
          Attempting AT wakeup...
          b'\r\nOK\r\n'
          Entering upgrade mode...
          AT+SMOD? returned 2
          AT+SMSWBOOT=3,1 returned: b'\r\nOK\r\n'
          Response after reset: b'\r\nERROR\r\n'
          Starting STP
          <<<=== DO NOT DISCONNECT POWER ===>>>
          Sending AT+SMSTPU="ON_THE_FLY"
          Starting STP code upload
          magic=0x74736166, op=0x80, sid=0x0, plen=0x0, tid=0x0, hcrc=0x0, pcrc=0x18
          Correct SRSP signature: 0x74736166
          Sending 55498 bytes: [########################################] 100%
          Bootrom updated successfully, switching to recovery mode
          AT+SMSWBOOT=0,1 returned b'\r\nERROR\r\n'
          Received ERROR from AT+SMSWBOOT=0,1! Aborting!
          Success1? False
          Unable to upgrade bootrom.
          Success2? False
          Unable to load updater from /sd/updater.elf
            rskoniec @ArnaudP
            @arnaudp One more thing just came to my mind - do you have SIM card inserted in your FiPy? I don't know if this is an issue, but all of my FiPy modem f/w updates I've done with SIM card.
              ArnaudP @rskoniec
              @rskoniec We haven't received our cat-M1 SIM card yet. Do you think I can try with a regular SIM ?
              In this video tutorial : https://core-electronics.com.au/tutorials/pycom-gpy-fipy-cellular-lte-firmware-update.html
              it seems he hasn't put a sim card in it. Weird. Or the video is a bit outdated maybe.
                rskoniec @ArnaudP
                @arnaudp I've started a forum chat with you. Can we continue there?
                  ArnaudP @rskoniec
                  @rskoniec Sure, thanks :)
                    rskoniec @ArnaudP
                    @Xykon When I was helping @ArnaudP to resolve the problem with FiPy modem f/w update (sqnsupgrade.run('/sd/CATM1-version.dup', '/sd/updater.elf')) from initial release, we went this path:
                    • upgraded FiPy from 1.10.0.b1 to the latest stable 1.18.1.r4
                    • on FiPy 1.18.1.r4 modem f/w upgrade to the newest CATM1-39529 failed
                    • on FiPy 1.18.1.r4 modem f/w upgrade to previousCATM1-38638 failed
                    • downgraded FiPy from 1.18.1.r4 to 1.18.1.r1
                    • on FiPy 1.18.1.r1 modem f/w upgrade to CATM1-38638 successful
                    • now I'm waiting for @ArnaudP feedback about modem f/w upgrade to CATM1-39529 on FiPy 1.18.1.r4
                    • @ArnaudP has confirmed that after previous step, modem f/w upgrade to CATM1-39529 on FiPy 1.18.1.r4 was successful
                    What I've noticed is that updater.elf file in the previous CAT-M1/NB1 releases is the same and with a size of aprox. 300KB, but for the latest they are different for CAT-M1 (420KB) and NB1 (364KB). I've been told by @ArnaudP that he had already sent you a message.
                    John BairdJ 1 Reply Last reply Reply Quote 2
                      tom.beckingham
                        DDA
                        I am on the same page with version r4:
                        >>> import os
                        >>> from machine import SD
                        >>> sd=SD()
                        >>> os.mount(sd,'/sd')
                        >>> os.listdir('/sd')
                        ['upgdiff_38638-to-39529.dup', 'CATM1-39529.dup', 'upgdiff_33080-to-39529.dup', 'updater.elf']
                        >>> import sqnsupgrade
                        >>> sqnsupgrade.run('/sd/CATM1-39529.dup', '/sd/updater.elf')
                        Please advise on how I may be able to downgrade to 1.18.1.r1, so I may be successful....per post below.
                          rskoniec @DDA
                          @dda Download 1.18.1.r1 from here https://software.pycom.io/downloads/FiPy-1.18.1.r1.tar.gz and downgrade using Pycom Firmware Upate tool with flash from local file option.
                          • O Offline
                            oyarzo-pablo @ArnaudP
                            @arnaudp I've been attempting to update the modem from UART no SD card. Haven't been able to do it.
                            • John BairdJ Offline
                              John Baird @rskoniec
                              @rskoniec Thanks for these detailed instructions. I've followed them and no longer get the Aborting error, however the process seems to fail:
                              >>> sqnsupgrade.run('/sd/CATM1-38638.dup','/sd/updater.elf')
                              <<< Welcome to the SQN3330 firmware updater >>>
                              Starting STP (DO NOT DISCONNECT POWER!!!)
                              Sending 54854 bytes: [########################################] 100%
                              Bootrom updated successfully, switching to upgrade mode
                              Attempting AT auto-negotiation...
                              ERROR sending AT command... no response? b''
                              AT auto-negotiation failed! Exiting.
                              Any suggestions?
                                rskoniec @John Baird
                                @john-baird Can you try this? https://forum.pycom.io/topic/4022/unable-to-update-gpy-modem-firmware/4
                                • 2 / 2
