FiPy firmware upgrade failed - Cat M1
@rskoniec Same issue :
>>> os.mkfs(sd) Traceback (most recent call last): File "<stdin>", line 1, in <module> OSError: the requested operation failed -
@arnaudp So maybe you should try with 8/16 GB SD card. FYI,
os.mkfs(sd)is formatting your SD card to the right filesystem for Pycom devices. So after that you should remove SD card from PyTrack, put into your PC, copy files and then insert back again to the PyTrack, reset by button your FiPy and from fresh REPL:from machine import SD sd = SD() os.mount(sd, '/sd') os.listdir('/sd') # to check if the files exist on SD card import sqnsupgrade sqnsupgrade.run('/sd/CATM1-39529.dup', '/sd/updater.elf') # for CAT-M1 sqnsupgrade.run('/sd/NB1-40343.dup', '/sd/updater.elf') # for CAT-NB1 -
@rskoniec Ok ! So I have formatted it again and now it works !
Now here's the new issue :
Attempting AT wakeup... Session opened: version 1, max transfer 8192 bytes Sending 55498 bytes: [########################################] 100% Received ERROR from AT+SMSWBOOT=0,1! Aborting! Unable to upgrade bootrom. Unable to load updater from /sd/updater.elf -
@arnaudp I think you've got incomplete file/files - 55498 bytes is too short (incomplete download from https://software.pycom.io/downloads/sequans2.html ?).
CATM1-39529.dupis almost 6MB big
updater.elfis over 400KB big -
@rskoniec Yup, that's the file I have on my disk, just checked the size with a freshly dowloaded version. It seems that it's the sending that didn't work.
And now it says it won't detect the modem (perhaps because of faulty upgrade).Ok not anymore
But my files are the right ones on the disk :/ -
@rskoniec
With some debug infos. We can see the files are listed with their right size :File /sd/updater.elf has size 429340 File /sd/CATM1-39529.dup has size 6059510Here is the complete log :
>>> sqnsupgrade.run('/sd/CATM1-39529.dup', '/sd/updater.elf', debug=True) <<< Welcome to the SQN3330 firmware updater [1.2.0] >>> >>> FiPy with firmware version 1.18.1.r4 File /sd/updater.elf has size 429340 File /sd/CATM1-39529.dup has size 6059510 Modem state: 2 Checking bootrom & application Checking line Checking line SYSTEM VERSION Checking line ============== Checking line FIRMWARE VERSION Checking line Bootloader0* : 5.1.1.0 [33080] old_br: True Checking line Bootloader1 : NA Checking line Bootloader2 : NA Checking line NV Info : 1.1,0,0 Checking line Software : 5.1.1.0 [33080] by robot-soft at 2017-10-27 07:49:11 old_sw: True Checking line UE : Unknown Checking line COMPONENTS Checking line ZSP0 : 1.0.98-12323 Checking line ZSP1 : 1.0.98-12295 Checking line Checking line OK Checking line Returning: True mirror? False recover? False resume? False direct? False atneg_only? False bootrom? True load_fff? False Initial prepartion complete... Loading built-in recovery bootrom... Attempting AT wakeup... b'\r\nOK\r\n' Entering upgrade mode... AT+SMOD? returned 2 AT+SMSWBOOT=3,1 returned: b'\r\nOK\r\n' Response after reset: b'\r\nERROR\r\n' Starting STP <<<=== DO NOT DISCONNECT POWER ===>>> Sending AT+SMSTPU="ON_THE_FLY" Starting STP code upload magic=0x74736166, op=0x80, sid=0x0, plen=0x0, tid=0x0, hcrc=0x0, pcrc=0x18 Correct SRSP signature: 0x74736166 Session opened: version 1, max transfer 8192 bytes Sending 55498 bytes: [########################################] 100% Bootrom updated successfully, switching to recovery mode AT+SMSWBOOT=0,1 returned b'\r\nERROR\r\n' Received ERROR from AT+SMSWBOOT=0,1! Aborting! Success1? False Unable to upgrade bootrom. Success2? False Unable to load updater from /sd/updater.elf -
@arnaudp One more thing just came to my mind - do you have SIM card inserted in your FiPy? I don't know if this is an issue, but all of my FiPy modem f/w updates I've done with SIM card.
@rskoniec We haven't received our cat-M1 SIM card yet. Do you think I can try with a regular SIM ?
In this video tutorial : https://core-electronics.com.au/tutorials/pycom-gpy-fipy-cellular-lte-firmware-update.html
it seems he hasn't put a sim card in it. Weird. Or the video is a bit outdated maybe. -
@arnaudp I've started a forum chat with you. Can we continue there?
@rskoniec Sure, thanks :)
@Xykon When I was helping @ArnaudP to resolve the problem with FiPy modem f/w update (
sqnsupgrade.run('/sd/CATM1-version.dup', '/sd/updater.elf')) from initial release, we went this path:- upgraded FiPy from
1.10.0.b1to the latest stable1.18.1.r4 - on FiPy
1.18.1.r4modem f/w upgrade to the newestCATM1-39529failed - on FiPy
1.18.1.r4modem f/w upgrade to previousCATM1-38638failed - downgraded FiPy from
1.18.1.r4to1.18.1.r1 - on FiPy
1.18.1.r1modem f/w upgrade toCATM1-38638successful now I'm waiting for @ArnaudP feedback about modem f/w upgrade toCATM1-39529on FiPy1.18.1.r4- @ArnaudP has confirmed that after previous step, modem f/w upgrade to
CATM1-39529on FiPy1.18.1.r4was successful
What I've noticed is that
updater.elffile in the previous CAT-M1/NB1 releases is the same and with a size of aprox. 300KB, but for the latest they are different for CAT-M1 (420KB) and NB1 (364KB). I've been told by @ArnaudP that he had already sent you a message. - upgraded FiPy from
This post is deleted! -
I am on the same page with version r4:
>>> import os >>> from machine import SD >>> sd=SD() >>> os.mount(sd,'/sd') >>> os.listdir('/sd') ['upgdiff_38638-to-39529.dup', 'CATM1-39529.dup', 'upgdiff_33080-to-39529.dup', 'updater.elf'] >>> import sqnsupgrade >>> sqnsupgrade.run('/sd/CATM1-39529.dup', '/sd/updater.elf') <<< Welcome to the SQN3330 firmware updater [1.2.0] >>> >>> FiPy with firmware version 1.18.1.r4 Attempting AT wakeup... Session opened: version 1, max transfer 8192 bytes Sending 55498 bytes: [########################################] 100% Received ERROR from AT+SMSWBOOT=0,1! Aborting! Unable to upgrade bootrom. Unable to load updater from /sd/updater.elfPlease advise on how I may be able to downgrade to 1.18.1.r1, so I may be successful....per post below.
@dda Download 1.18.1.r1 from here https://software.pycom.io/downloads/FiPy-1.18.1.r1.tar.gz and downgrade using Pycom Firmware Upate tool with
flash from local fileoption. -
@arnaudp I've been attempting to update the modem from UART no SD card. Haven't been able to do it.
@rskoniec Thanks for these detailed instructions. I've followed them and no longer get the Aborting error, however the process seems to fail:
>>> sqnsupgrade.run('/sd/CATM1-38638.dup','/sd/updater.elf') <<< Welcome to the SQN3330 firmware updater >>> Attempting AT wakeup... Starting STP (DO NOT DISCONNECT POWER!!!) Session opened: version 1, max transfer 8192 bytes Sending 54854 bytes: [########################################] 100% Bootrom updated successfully, switching to upgrade mode Attempting AT auto-negotiation... ERROR sending AT command... no response? b'' AT auto-negotiation failed! Exiting. Unable to load updater from /sd/updater.elfAny suggestions?
