Pymesh updates
@catalin had a lot of issues with 1.20.0.rc7 almost all nodes were corrupted with guru meditation error on lora.mesh. the mesh seemed to be the issue, The error did not seem to be on previous versions, (although it wasn't run very long on previous version prior to update), I am hoping with rc8 this problem is fixed....
Hi Jordan,
Yes, please try the RC8 release, I did not had any issue with RC7, either.
Now I am running the Pymesh with ~30 micropython scripts (sending data to the Cloud, using Wifi and BLE), also creating Pymesh with 20+ nodes(lopy4 and Fipy), no Error found. -
@catalin with both deployed is orignial lopy, not lopy4 would this be any difference with about 12 nodes. it was running for a bit and then would crash, but we weren't getting stable communication either, some were more consistent then others.
@catalin deployed rc8 upon boot up nodes hit (outside With Line of sight ) and they are suppose to respond every ten seconds, some responsive more than others but after some time they do not send data anymore. Sometimes it lasts an hour sometimes a day but it is not reliable. What is environment you are running your set upon. We are covering about 2.25-2.5 km.
@jordan-reyes I did not properly tested Pymesh on Lopy1, mainly because the scripts that I use, occupy lots of RAM.
What LoRa params are you using, spreading-factor, bandwidth? I would start tests with fastest datarate (SF7, BW 250). Are you printing the RSSI values, if they are at the border (for that SF, for ex: lower than -115), there could be corrupted packets, that Node could exit/re-enter the Mesh.
10 seconds is a small waiting time; Mesh internally sends, every 32 seconds, sends a keepalive between each pair of neighbours (last communication is in theagefield fromMesh.neighbors()andMesh.routers()). -
@catalin SF is 7, Bandwidth is 125. The RssI values were not being printed.
Hi community 🙌,
I've been busy lately making Pymesh application protocol more robust ⚙.
I've just released a relatively large 🐘 micropy project using Pymesh: https://github.com/pycom/pycom-libraries/tree/master/lib/pymesh
It was tested on a 20+ Mesh network on Lopy4 and Fipy (sorry Lopy1 can't work with these scripts, due to scripts size and RAM requirements).
I am really waiting for your comments and PRs, I foresee tons of improvements 🤓.Heads-up, I am working on a visual tool, like a Pymesh viewer to actually click buttons and follow Pymesh evolution. Most probably connecting Pymesh to Pybytes 🌥.
Just a small note, the v1.20.0.rc8 for Fipy and Pybytes scripts doesn't have Mesh class inside LoRa (so no Pymesh feature included).
Due to an error, Pymesh was excluded on Lopy4 rc8 builds, too; this is about to be fixed as I speak. -
@catalin said in Pymesh updates:
Does it work on the L01? It has the same amount of RAM and flash as the Lopy4.
@rfinkers yes, it should work fine with L01, due to increased RAM+Flash.
Hi community,
I've released a beta version of the Pymesh mobile app:
- iOS(>v12.1, TestFlight app from Apple is required): https://testflight.apple.com/join/PIxwbTKp
- Android(>v4.4): https://github.com/pycom/pymesh_apps/tree/master/mobile_app/android
In this repo there are firmware binaries (but latest development should work too), and micropy scripts (but https://github.com/pycom/pycom-libraries/tree/master/lib/pymesh should be also fine).
Any news about pymesh ? Any example how the border router can connect to the internet and provide it to the rest of the network ?
Hi @ricardolima,
Here is the example of the Border Router: https://docs.pycom.io/tutorials/lora/pymesh-br/, more precisely at this line
rcv_datacontains the info to be sent to Internet.In class WLAN and socket you can see how to send data on Wifi.
Similar examples are on NBIoT/CatM1/BLE/Sigfox/LoRaWAN.Does this answers your question?
On a side note, I am working on some micropython scripts on which any Pymesh node can connect to Pybytes, if connection is done then they declared itself as Border Router, the other nodes see they have a BR in network (as a new IPv6 appears on them). Probably I'll release these in the next couple of weeks.
Also, a separate Pymesh firmware binary release will be done next week (separate from already existing flavours development/stable/pybytes).
@catalin Thank you for your quick answer. I will wait a bit to see what that news firmwares brings :D
Small update, the Pymesh iOS app was rebuilt, and it's available again in TestFlight, using the same link: https://testflight.apple.com/join/PIxwbTKp
The Pymesh Android app is in this repo.
Also builds with Pymesh included are here, the binaries include micropython scripts. -
@catalin So I installed these images https://github.com/pycom/pymesh_apps/tree/master/custom_fw_bin on two LoPy4's and a FiPy. They run, see each other, declare themselves as leader, router, and child, and have chats. But what else? Are these sample images good for anything beyond that?
And yes: they all seem to have a fixed location in Eindhoven. Using a pytrack does not change that. -
hi @robert-hh,
I think, there is the flow of sending pictures across Pymesh also implemented; by sending messagedoga 12KB picture of a dog is sent.More features are to come:
- binary release with
Pymeshflavour - having included frozen scripts, so a mesh can be started using 3-4 lines of micropython
- any node can be declared as
Border Routerand it can be connected toPybytes, or other IoT platform - any node accepts BLE connections, so using Pymesh mobile app, one can see diagnostics info within the Mesh.
And, of course, we're waiting for more suggestions on Pymesh wishlist.
@catalin My question was more, what to do with the actual pymesh firmware images you pubished. They run and connect, but I see no path to use it for other purposes. There is a single > prompt. If I push Ctrl-D at it, I get the message:
Unhandled exception in thread started by <bound_method> Traceback (most recent call last): File "cli.py", line 36, in process EOFError:So there is a function cli.py, which seems to wait for commands. But which one?
@catalin Onother issue:
I had one LoPy4 with your pymesh image running over night. This morning it was in a reboot loop with messages like these:Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled. Core 0 register dump: PC : 0x400966f0 PS : 0x00060033 A0 : 0x80094c5a A1 : 0x3ffc09c0 A2 : 0x3ffc1910 A3 : 0x00000000 A4 : 0x3ffc56f4 A5 : 0x000005ab A6 : 0x3ffc5914 A7 : 0x00000000 A8 : 0x3ffe3964 A9 : 0x3ffc0990 A10 : 0x00000001 A11 : 0x00060021 A12 : 0x3ffdc468 A13 : 0x00000001 A14 : 0x000000fe A15 : 0x00060023 SAR : 0x0000001f EXCCAUSE: 0x0000001c EXCVADDR: 0x00000008 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000 Core 0 was running in ISR context: EPC1 : 0x400966f0 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008b8b4 Backtrace: 0x400966f0:0x3ffc09c0 0x40094c57:0x3ffc09e0 0x40097675:0x3ffc0a00 0x40083b16:0x3ffc0a10 0x40201af3:0x3ffdc3b0 0x400965b5:0x3ffdc3d0No clue what happened. Re-flashing it brought it back to normal operation. This is new, because normally these devices are very reliable.
@robert-hh, the micropython scripts which are frozen in those binaries is in the same repo: https://github.com/pycom/pymesh_apps/tree/master/pymesh_micropy_scripts
The
clicommands can be seen in the code, sorry for not having then documented:
https://github.com/pycom/pymesh_apps/blob/0063271c910c78d0d4832286494eb49f96242eca/pymesh_micropy_scripts/lib/cli.py#L43
Nicer is to install the Android or iOS mobile app(link opened by TestFlight mobile app).Regarding the crush, I've pushed the memory heap usage to the max in those binaries, this is solved by the newest IDF_v3.2 from development.
