    FiPy trouble with CatM1 AND NBIoT
    18 Posts 4 Posters 261 Views 5 Watching
      barryjump
      Hello all, could use some real help from the community.
      I've been trying for weeks (months maybe) to get my FiPy successfully connected to any LTE network in the US. Have tried numerous combinations of NBIoT with TMobile and Twilio NBIoT as well as CatM with AT&T and even 1oT (https://1ot.mobi) with the same results. Essentially after scouring the forums for the best debugging code, I encounter the same loop where I get this encouraging info:
      | RRC TOP FSM              |CONNECTING          |
      | RRC SEARCH FSM           |CAMPED              |
      | RRC ACTIVE FSM           |WAIT_SMC            |
      | PMM PLMN FSM             |NORM_CAMPED         |
      | EMM MAIN FSM             |REGISTERED_INIT     |
      | EMM AUTH FSM             |KASME_DEFINED       |
      | EMM CONN FSM             |AS_ESTABLISHED      |
      | ESM BEARER FSM           |BEARER_NULL_PENDING_ACTIVE|
      Only to immediately receive:
        | RRC TOP FSM              |SCANNING            |
        | RRC SEARCH FSM           |WAIT_CELL_ID        |
        | RRC ACTIVE FSM           |NULL                |
      It looks like the modem finds a tower, tried to negotiate and then drops and camps.
      Here is a video of the loop I've been seeing for weeks across a miriad of different networks and SIMs.
      Any ideas???
      Really eager to get this working as we're interested in testing cellular as a failover protocol if Lora fails.
      Pycom Console terminal readout video
        claus @barryjump
        @barryjump Have you changed your modem firmware accordingly when switching from Cat-M1 to NB-IoT? I had a similar problem and the cause was that the device came with Cat-M1 firmware shipped, but my SIM was NB-IoT. Also, check the "LTE Troubleshooting guide at https://docs.pycom.io/tutorials/networks/lte/, it gives a few solutions to common cases. I could not see your video, you should describe what the first 2 fields are doing (RRC_TOP_FSM and RRC_SEARCH_FSM).
          barryjump
          Thanks for the reply @claus. I did indeed update the modem firmware. First update was from stock firmware to latest NBIoT (6.0.x etc) and tested with NB specific SIM from Twilio without success. Then recently switched to latest CatM firmware and tested with CatM specific SIM from 1oT.
          Cylce as follows:
          RCC_TOP_FSM: Scanning
          RRC_SEARCH_FSM: Wait cell ID
          RCC_TOP_FSM: Syncing
          RRC_SEARCH_FSM: Wait Sync
          RCC_TOP_FSM: Connecting
          RRC_SEARCH_FSM: Camped
          RCC_TOP_FSM: Camping
          RRC_SEARCH_FSM: Wait SIB1
          RRC_SEARCH_FSM: Wait RSSI
          And on and on.
          It seems to enter Connecting state very quickly after reinitializing modem. But only stays there for a few seconds before bailing to the other states (Syncing, Scanning, etc).
            claus @barryjump
            @barryjump These are the states I get after a lte.reset():
            init lte
            reset lte
            attaching..
             ('SCANNING', 'WAIT_CELL_ID').
             ('CAMPING', 'WAIT_SIB').
             ('CAMPING', 'WAIT_SIBX').
             ('SYNCING', 'WAIT_SYNC')....
             ('CAMPING', 'WAIT_SIBX')...
             ('CONNECTING', 'CAMPED')......
             ('CONNECTED', 'CAMPED')........................attached!
            Your states look exactly like what I had before changing the modem firmware. The docs say
            If the system returns multiple times from SYNCING to CAMPED, check the network availability, simcard placement and / or the firmware version.
            You have checked the other two hints I guess? Has 1oT provided you with the band and apn parameters?
            B 2 Replies Last reply Reply Quote 0
              barryjump @claus
              @claus I did check both, but I'm going to double and triple check now. Will report back.
              Thanks for helping!
                barryjump @claus
                @claus Hey I tripped checked sim card placement and firmware. Regarding signal and network availability, I found this reference elsewhere on this forum.
                https://usatcorp.com/faqs/understanding-lte-signal-strength-values/
                If this reference doc is correct, my results (at the time FSM shows Connecting) show that I while don't have great signal, I should have enough to reach a tower.
                RSRQ (dB) : -10.82 (-3 Excellent to -19 Poor)
                RSRP (dBm) : -104.80 (-44 Excellent to -140 Poor)
                CINR : 10.31 (12.5 Excellent to 7 Poor)
                SYSTEM FSM
                OK
                .Sent to modem: 'AT!="showphy"'
                DL SYNCHRO STATISTICS
                    Synchro state                         : CELL_ACQUIRED
                    PPU SIB1 ACQ watchdog                 : 0
                    Frequency Hypothesis RF  (Hz)         : 0
                    RSRQ  (dB)                            : -10.82
                    Channel estimation state (Cell-spec.) : HIGH CINR
                    Channel estimation state (UE-spec.)   : LOW CINR
                    Channel estimation state (MBSFN)      : LOW CINR
                    Channel estimation CINR               : 10.31
                    Channel length                        : SHORT
                  AGC
                    AGC RX gain (dB)                      : 59.51
                    RX PSD BO (dBFs)                      : -21.19
                    RX PSD (dBm)                          : -107.63
                    Noise level RS (dBm)                  : -114.59
                    Digital gain (dB)                     : 11.53
                    CINR RS (dB)                          : 9.79
                  NARROWBANDS
                    Last DL NB                            : 0
                    Last UL NB                            : N/A
                  AFC
                    Frequency offset RF  (Hz)             : -492
                    Frequency offset BB  (Hz)             : 0
                  PBCH
                    MIB received quantity                 : 49
                    MIB timeout quantity                  : 0
                OK
                Sent to modem: 'AT!="fsm"'
                SYSTEM FSM
                OK
                    Synchro state                         : SIB1_ACQ
                    RSRP (dBm)                            : -104.71
                    RSRQ  (dB)                            : -11.23
                    Channel estimation CINR               : 11.44
                  AGC
                    RX PSD BO (dBFs)                      : -20.95
                    RX PSD (dBm)                          : -107.41
                    Noise level RS (dBm)                  : -114.74
                    Digital gain (dB)                     : 11.31
                    CINR RS (dB)                          : 10.03
                  NARROWBANDS
                    Last DL NB                            : Central
                    Last UL NB                            : N/A
                  AFC
                    Frequency offset RF  (Hz)             : -493
                  PBCH
                    MIB received quantity                 : 56
                OK
                SYSTEM FSM
                    | RRC TOP FSM              |SYNCING             |
                    | RRC SEARCH FSM           |WAIT_SYNC           |
                OK
                    Synchro state                         : FRAME_UPDATE
                    RSRP (dBm)                            : -21474836.00
                    RSRQ  (dB)                            : -11.23
                    Channel estimation CINR               : 7.97
                  AGC
                    RX PSD BO (dBFs)                      : -21.32
                    RX PSD (dBm)                          : -110.56
                    Noise level RS (dBm)                  : -128.24
                    Digital gain (dB)                     : 5.49
                  NARROWBANDS
                    Last UL NB                            : N/A
                  AFC
                    Frequency offset RF  (Hz)             : -483
                  PBCH
                    MIB received quantity                 : 70
                OK
                  So it seems you are connecting (which is good!) but then immediately being rejected by the network because of some settings mismatch probably. There could be several causes for this error (mismatch in APN, simcard, sudden loss of signal etc.)
                    barryjump @Gijs
                    @Gijs this is my code, I've tried several different APNs, but perhaps I've set this up wrong? One thing I may not be handling properly is the band and carrier, but that is a bit strange considering we've been testing MVNOs (like Hologram, Twilio, Soracom, etc.) that hop different carriers with different bands. I've left the band unspecified as a result - perhaps thats incorrect.
                    #           LTE Setup
                    lte = LTE()
                    apn = "terminal"  ## per https://1ot.mobi
                    band = "None"
                    iccid = lte.iccid()
                    imei = lte.imei()
                    def send_at_cmd_pretty(cmd):
                        response = lte.send_at_cmd(cmd).split('\r\n')
                        print('Sent to modem: \'{}\''.format(cmd))
                        for line in response:
                            if line.strip() != '':
                                print(line)
                    # MODEM DEBUG
                    send_at_cmd_pretty('ATI1')                                      # retrieve modem firmware
                    send_at_cmd_pretty('AT!="showver"')                             # retrieve modem firmware
                    send_at_cmd_pretty('AT!="RRC:setDbgPerm full"')
                    send_at_cmd_pretty('AT!="RRC:showcaps"')
                    time.sleep(5)
                    send_at_cmd_pretty('AT+SQNCTM?')
                    def lteconnect():
                        print("Attempting LTE connect with:")
                        print("APN: %s" % apn)
                        print('IMEI ', lte.imei()[:5] + '*' * 9)
                        print('ICCID ', lte.iccid()[:5] + '*' * 14)
                        time.sleep(3)
                        # Initialize the modem
                        lte.init()
                        # Attach the modem
                        lte.attach(apn="terminal")
                        print("attaching..",end='')
                        while not lte.isattached():
                            # JFD time.delay(0.25)
                            pycom.rgbled(0x500000)
                            utime.sleep_ms(25)
                            print('.',end='')
                            send_at_cmd_pretty('AT!="showphy"')
                            send_at_cmd_pretty('AT!="fsm"')
                            #utime.sleep_ms(500)
                            #print(lte.send_at_cmd('print'))
                            utime.sleep_ms(500)
                        pycom.rgbled(0x005000)
                        print("attached!")
                        lte.connect()
                        print("connecting [##",end='')
                        while not lte.isconnected():
                            # JFD time.sleep(0.25)
                            utime.sleep_ms(250)
                            print('#',end='')
                            #print(lte.send_at_cmd('AT!="showphy"'))
                            print(lte.send_at_cmd('AT!="fsm"'))
                            print(lte.send_at_cmd("ATI"))
                        print("] connected!")
                        # JFD Add delay
                        utime.sleep_ms(250)
                        # Ping Google server to test
                        print(usocket.getaddrinfo('google.com', 80))
                        print("Waiting for 60 seconds before disconnecting ...")
                        time.sleep(60)
                        print("OK, disconnecting now.")
                        lte.deinit()
                        #now we can safely machine.deepsleep()
                      barryjump
                      Quick update, I brought my FiPy on the road and parked right beneath a cell tower to see if perhaps my problem originated from poor signal.
                      As I mentioned before, my original signal reported as follows:
                      Underneath the tower I was seeing excellent signal stats:
                      RSRQ (dB) : -6.2 (-3 Excellent to -19 Poor)
                      RSRP (dBm) : -59.02 (-44 Excellent to -140 Poor)
                      CINR : 28.22 (12.5 Excellent to 7 Poor)
                      Unfortunately that did not resolve the issue, so all I can imagine I'm left with is some configuration problems with the Band, APN, or Network settings in lte.init() and lte.attach(). Perhaps @Gijs you have some suggestions?
                        claus @barryjump
                        @barryjump Your signal strength should not be a problem, I have RSRP around -115 and RSRQ at -15 and I can attach. Could you please check the following: Print the output of the AT command "AT+CEREG?" after lte.init(). If the first integer value is different from "2" ( say for example "+CEREG: 0,2" - the first value is "0") then include a "AT+CEREG=2" after lte.init(). Your "AT+CEREG?" should now give "+CEREG: 2,x". Now try to attach.
                          barryjump @claus
                          @claus said in FiPy trouble with CatM1 AND NBIoT:
                          AT+CEREG?
                          Thanks @claus running that check showed the following:
                          Sent to modem: 'AT+CEREG?'
                          +CEREG: 2,0
                          OK
                          Which means it was already configured with that value. I did notice it got to connecting a bit faster than usual this time, but same problem: from connecting to searching almost immediately. :(
                          Pybytes configuration read from /flash/pybytes_config.json
                          Not starting Pybytes as auto-start is disabled
                          Sent to modem: 'ATI1'
                          UE5.0.0.0d
                          LR5.1.1.0-41065
                          OK
                          Sent to modem: 'AT!="showver"'
                          SYSTEM VERSION
                            FIRMWARE VERSION
                              Bootloader0  : 5.1.1.0 [39529]
                              Bootloader1* : 5.1.1.0 [41065]
                              Bootloader2  : 6.0.0.0 [41019]
                              NV Info      : 1.1,0,0
                              Software     : 5.1.1.0 [41065] by robot-soft at 2018-12-17 13:03:40
                              UE           : 5.0.0.0d
                            COMPONENTS
                              ZSP0         : 1.0.99-13616
                              ZSP1         : 1.0.99-12376
                          OK
                          Sent to modem: 'AT!="RRC:setDbgPerm full"'
                          OK
                          Sent to modem: 'AT!="RRC:showcaps"'
                          == CAPS config =============================
                            .Lock UE on SRV band    : false
                            .MFBI support           : true
                            .TM8 TDD support        : false
                          == CAPS ====================================
                            . access stratum: R13
                            . catM          : 1
                            . nb-IoT        : 0
                          -- EUTRA bands --
                            . supported     : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1
                            . board         : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66
                            . admin         :
                            . pending admin :
                          -- EUTRA carriers --
                            . admin         :
                            . pending admin :
                          OK
                          Sent to modem: 'AT+SQNCTM?'
                          +SQNCTM: standard
                          OK
                          Booting up...
                          10
                          9
                          8
                          No user input detected, starting
                          APN: terminal
                          IMEI  35434*********
                          ICCID  89310**************
                          +CEREG: 2,0
                          OK
                          attaching...Sent to modem: 'AT!="showphy"'
                              RSRP (dBm)                            : -108.60
                              RSRQ  (dB)                            : -10.81
                              Channel estimation CINR               : 5.82
                            AGC
                              AGC RX gain (dB)                      : 59.61
                              RX PSD BO (dBFs)                      : -21.00
                              RX PSD (dBm)                          : -110.93
                              Noise level RS (dBm)                  : -114.30
                              Digital gain (dB)                     : 14.73
                              CINR RS (dB)                          : 5.70
                            NARROWBANDS
                              Last DL NB                            : 3
                              Last UL NB                            : N/A
                            AFC
                              Frequency offset RF  (Hz)             : -475
                            PBCH
                              MIB received quantity                 : 66
                          OK
                          SYSTEM FSM
                              | EMM AUTH FSM             |WAITING_SIM_CONFIRM |
                          OK
                              RSRP (dBm)                            : -108.99
                              RSRQ  (dB)                            : -11.66
                              Channel estimation state (Cell-spec.) : LOW CINR
                              Channel estimation CINR               : 5.14
                            AGC
                              RX PSD BO (dBFs)                      : -20.81
                              RX PSD (dBm)                          : -109.95
                              Noise level RS (dBm)                  : -114.09
                              Digital gain (dB)                     : 13.75
                              CINR RS (dB)                          : 5.10
                            NARROWBANDS
                              Last DL NB                            : 3
                              Last UL NB                            : N/A
                            AFC
                            PBCH
                          OK
                          SYSTEM FSM
                          OK
                              Synchro state                         : CELL_SEARCH
                              RSRQ  (dB)                            : -11.97
                              Channel estimation CINR               : 4.30
                            AGC
                              AGC RX gain (dB)                      : 59.59
                              RX PSD BO (dBFs)                      : -20.54
                              RX PSD (dBm)                          : -105.79
                              Digital gain (dB)                     : 5.41
                              CINR RS (dB)                          : -0.01
                            NARROWBANDS
                              Last UL NB                            : 0
                            AFC
                              Frequency offset RF  (Hz)             : -480
                            PBCH
                              MIB received quantity                 : 73
                          OK
                          SYSTEM FSM
                          OK
                              Synchro state                         : RSRP
                              Frequency Hypothesis RF  (Hz)         : -1000
                              RSRQ  (dB)                            : -11.97
                              Channel estimation CINR               : 7.20
                            AGC
                              RX PSD BO (dBFs)                      : -19.92
                              RX PSD (dBm)                          : -103.98
                              Digital gain (dB)                     : 7.80
                            NARROWBANDS
                              Last UL NB                            : 0
                            AFC
                              Frequency offset RF  (Hz)             : 513
                            PBCH
                              MIB received quantity                 : 92
                          OK
                          SYSTEM FSM
                          OK
                              RSRQ  (dB)                            : -11.97
                              Channel estimation CINR               : 1.74
                            AGC
                              AGC RX gain (dB)                      : 55.73
                              RX PSD BO (dBFs)                      : -33.26
                              RX PSD (dBm)                          : -123.33
                              Digital gain (dB)                     : 9.27
                            NARROWBANDS
                              Last UL NB                            : 0
                            AFC
                              Frequency offset RF  (Hz)             : -421
                            PBCH
                              MIB received quantity                 : 116
                          OK
                          SYSTEM FSM
                          OK
                            barryjump @claus
                            @claus Would you be willing to share your main.py here? I'm increasingly thinking that I have the band, apn, or carrier setup wrong.
                              claus @barryjump
                              @barryjump For testing the attach process I use https://github.com/clausdenk/fipy-ltesignal. You should be able to use it directly by commenting the dnsserver calls at the top of the file and adjusting ATTACH_PARAMETERS. It should be ok to only specify the apn, the band should be detected automatically by the modem. If you know the band it probably speeds up the process though. I get outputs similar to
                               ('CAMPING', 'WAIT_SIBX').........
                               ('CONNECTED', 'CAMPED')......attached!
                              rsrp,rsrq,<rsrp>,<rsrq>: -113.33 -15.89 -113.33 -15.89
                              rsrp,rsrq,<rsrp>,<rsrq>: -113.19 -15.96 -113.26 -15.925
                              I just had a problem with the CEREG setting !=2 and setting it to 2 fixed it for me. A pity it does not in your case.
                              B 2 Replies Last reply Reply Quote 2
                                barryjump @claus
                                @claus Thanks for your help! I'll give your code a shot
                                  barryjump @claus
                                  @claus I had high hopes! Unfortunately I'm seeing the same. Thanks for all your help!
                                  Starting ..
                                  rsrp [ -122.8 , -92.80001 ] center: -107.8
                                  rsrq [ -22.2 , -7.2 ] center: -14.7
                                  init lte
                                  reset lte
                                  cereg ['2', '0']
                                  attaching..
                                   ('STOPPED', 'NULL').
                                   ('SCANNING', 'WAIT_CELL_ID')...
                                   ('SYNCING', 'WAIT_SYNC')...........
                                   ('SCANNING', 'WAIT_RSSI')..........................................
                                   ('SCANNING', 'WAIT_CELL_ID').........
                                   ('SCANNING', 'WAIT_CELL_ID')..........
                                   ('CAMPING', 'WAIT_SIB')...
                                   ('CAMPED', 'CAMPED_ANY').........
                                   ('CAMPED', 'CAMPED_ANY')............
                                   ('RESEL', 'WAIT_SIB').
                                   ('RESEL', 'WAIT_CELL_ID')..
                                   ('RESEL', 'WAIT_SYNC').
                                   ('CAMPED', 'CAMPED_ANY').................................
                                  Perhaps there is a deeper issue with the modem firmware that only Pycom can help diagnose. @Gijs or @administrators Can you recommend some next steps to diagnose my problems?
                                    Thanks @claus for the great advice!~
                                    My knowledge of the whole LTE thing only goes as far as the guide in the documentation unfortunately. I know we are working on publishing new LTE modem firmwares (hang tight!) but I'm not sure that will solve the issue here (we did have some succes with a beta NB-IoT firmware for other customers, you could contact me at support@pycom.io and I could send it to you!)
                                      barryjump @Gijs
                                      @Gijs Thanks. Emailed you just now.
                                      Meantime, I don't want to give up hope as this user seems to have made this work somehow:
                                      https://stackoverflow.com/questions/62791167/how-connect-to-lte-cell-network-with-pycom-fipy
                                        razvan
                                        Hi, were you able to resolve this issue? Thanks.
