    FiPy trouble with CatM1 AND NBIoT
    18 Posts 4 Posters 261 Views 5 Watching
      barryjump @claus
      @claus Hey I tripped checked sim card placement and firmware. Regarding signal and network availability, I found this reference elsewhere on this forum.
      https://usatcorp.com/faqs/understanding-lte-signal-strength-values/
      If this reference doc is correct, my results (at the time FSM shows Connecting) show that I while don't have great signal, I should have enough to reach a tower.
      RSRQ (dB) : -10.82 (-3 Excellent to -19 Poor)
      RSRP (dBm) : -104.80 (-44 Excellent to -140 Poor)
      CINR : 10.31 (12.5 Excellent to 7 Poor)
      SYSTEM FSM
          | RRC TOP FSM              |CONNECTING          |
          | RRC SEARCH FSM           |CAMPED              |
          | RRC ACTIVE FSM           |WAIT_SMC            |
          | PMM PLMN FSM             |NORM_CAMPED         |
          | EMM MAIN FSM             |REGISTERED_INIT     |
          | EMM CONN FSM             |AS_ESTABLISHED      |
          | ESM BEARER FSM           |BEARER_NULL_PENDING_ACTIVE|
      OK
      .Sent to modem: 'AT!="showphy"'
      DL SYNCHRO STATISTICS
          Synchro state                         : CELL_ACQUIRED
          PPU SIB1 ACQ watchdog                 : 0
          Frequency Hypothesis RF  (Hz)         : 0
          RSRQ  (dB)                            : -10.82
          Channel estimation state (Cell-spec.) : HIGH CINR
          Channel estimation state (UE-spec.)   : LOW CINR
          Channel estimation state (MBSFN)      : LOW CINR
          Channel estimation CINR               : 10.31
          Channel length                        : SHORT
        AGC
          AGC RX gain (dB)                      : 59.51
          RX PSD BO (dBFs)                      : -21.19
          RX PSD (dBm)                          : -107.63
          Noise level RS (dBm)                  : -114.59
          Digital gain (dB)                     : 11.53
          CINR RS (dB)                          : 9.79
        NARROWBANDS
          Last DL NB                            : 0
          Last UL NB                            : N/A
        AFC
          Frequency offset RF  (Hz)             : -492
          Frequency offset BB  (Hz)             : 0
        PBCH
          MIB received quantity                 : 49
          MIB timeout quantity                  : 0
      OK
      Sent to modem: 'AT!="fsm"'
      SYSTEM FSM
          | EMM AUTH FSM             |KASME_DEFINED       |
      OK
          Synchro state                         : SIB1_ACQ
          RSRP (dBm)                            : -104.71
          RSRQ  (dB)                            : -11.23
          Channel estimation CINR               : 11.44
        AGC
          RX PSD BO (dBFs)                      : -20.95
          RX PSD (dBm)                          : -107.41
          Noise level RS (dBm)                  : -114.74
          Digital gain (dB)                     : 11.31
          CINR RS (dB)                          : 10.03
        NARROWBANDS
          Last DL NB                            : Central
          Last UL NB                            : N/A
        AFC
          Frequency offset RF  (Hz)             : -493
        PBCH
          MIB received quantity                 : 56
      OK
      SYSTEM FSM
          | RRC TOP FSM              |SYNCING             |
          | RRC SEARCH FSM           |WAIT_SYNC           |
          | RRC ACTIVE FSM           |NULL                |
      OK
          Synchro state                         : FRAME_UPDATE
          RSRP (dBm)                            : -21474836.00
          RSRQ  (dB)                            : -11.23
          Channel estimation CINR               : 7.97
        AGC
          RX PSD BO (dBFs)                      : -21.32
          RX PSD (dBm)                          : -110.56
          Noise level RS (dBm)                  : -128.24
          Digital gain (dB)                     : 5.49
        NARROWBANDS
          Last UL NB                            : N/A
        AFC
          Frequency offset RF  (Hz)             : -483
        PBCH
          MIB received quantity                 : 70
      OK
        So it seems you are connecting (which is good!) but then immediately being rejected by the network because of some settings mismatch probably. There could be several causes for this error (mismatch in APN, simcard, sudden loss of signal etc.)
          barryjump @Gijs
          @Gijs this is my code, I've tried several different APNs, but perhaps I've set this up wrong? One thing I may not be handling properly is the band and carrier, but that is a bit strange considering we've been testing MVNOs (like Hologram, Twilio, Soracom, etc.) that hop different carriers with different bands. I've left the band unspecified as a result - perhaps thats incorrect.
          #           LTE Setup
          lte = LTE()
          apn = "terminal"  ## per https://1ot.mobi
          band = "None"
          iccid = lte.iccid()
          imei = lte.imei()
          def send_at_cmd_pretty(cmd):
              response = lte.send_at_cmd(cmd).split('\r\n')
              print('Sent to modem: \'{}\''.format(cmd))
              for line in response:
                  if line.strip() != '':
                      print(line)
          # MODEM DEBUG
          send_at_cmd_pretty('ATI1')                                      # retrieve modem firmware
          send_at_cmd_pretty('AT!="showver"')                             # retrieve modem firmware
          send_at_cmd_pretty('AT!="RRC:setDbgPerm full"')
          send_at_cmd_pretty('AT!="RRC:showcaps"')
          time.sleep(5)
          send_at_cmd_pretty('AT+SQNCTM?')
          def lteconnect():
              print("Attempting LTE connect with:")
              print("APN: %s" % apn)
              print('IMEI ', lte.imei()[:5] + '*' * 9)
              print('ICCID ', lte.iccid()[:5] + '*' * 14)
              time.sleep(3)
              # Initialize the modem
              lte.init()
              # Attach the modem
              lte.attach(apn="terminal")
              print("attaching..",end='')
              while not lte.isattached():
                  # JFD time.delay(0.25)
                  pycom.rgbled(0x500000)
                  utime.sleep_ms(25)
                  print('.',end='')
                  send_at_cmd_pretty('AT!="showphy"')
                  send_at_cmd_pretty('AT!="fsm"')
                  #utime.sleep_ms(500)
                  #print(lte.send_at_cmd('print'))
                  utime.sleep_ms(500)
              pycom.rgbled(0x005000)
              print("attached!")
              lte.connect()
              print("connecting [##",end='')
              while not lte.isconnected():
                  # JFD time.sleep(0.25)
                  utime.sleep_ms(250)
                  print('#',end='')
                  #print(lte.send_at_cmd('AT!="showphy"'))
                  print(lte.send_at_cmd('AT!="fsm"'))
                  print(lte.send_at_cmd("ATI"))
              print("] connected!")
              # JFD Add delay
              utime.sleep_ms(250)
              # Ping Google server to test
              print(usocket.getaddrinfo('google.com', 80))
              print("Waiting for 60 seconds before disconnecting ...")
              time.sleep(60)
              print("OK, disconnecting now.")
              lte.deinit()
              #now we can safely machine.deepsleep()
            barryjump
            Quick update, I brought my FiPy on the road and parked right beneath a cell tower to see if perhaps my problem originated from poor signal.
            As I mentioned before, my original signal reported as follows:
            Underneath the tower I was seeing excellent signal stats:
            RSRQ (dB) : -6.2 (-3 Excellent to -19 Poor)
            RSRP (dBm) : -59.02 (-44 Excellent to -140 Poor)
            CINR : 28.22 (12.5 Excellent to 7 Poor)
            Unfortunately that did not resolve the issue, so all I can imagine I'm left with is some configuration problems with the Band, APN, or Network settings in lte.init() and lte.attach(). Perhaps @Gijs you have some suggestions?
              claus @barryjump
              @barryjump Your signal strength should not be a problem, I have RSRP around -115 and RSRQ at -15 and I can attach. Could you please check the following: Print the output of the AT command "AT+CEREG?" after lte.init(). If the first integer value is different from "2" ( say for example "+CEREG: 0,2" - the first value is "0") then include a "AT+CEREG=2" after lte.init(). Your "AT+CEREG?" should now give "+CEREG: 2,x". Now try to attach.
              B 2 Replies Last reply Reply Quote 0
                barryjump @claus
                @claus said in FiPy trouble with CatM1 AND NBIoT:
                AT+CEREG?
                Thanks @claus running that check showed the following:
                Sent to modem: 'AT+CEREG?'
                +CEREG: 2,0
                OK
                Which means it was already configured with that value. I did notice it got to connecting a bit faster than usual this time, but same problem: from connecting to searching almost immediately. :(
                Pybytes configuration read from /flash/pybytes_config.json
                Not starting Pybytes as auto-start is disabled
                Sent to modem: 'ATI1'
                UE5.0.0.0d
                LR5.1.1.0-41065
                OK
                Sent to modem: 'AT!="showver"'
                SYSTEM VERSION
                  FIRMWARE VERSION
                    Bootloader0  : 5.1.1.0 [39529]
                    Bootloader1* : 5.1.1.0 [41065]
                    Bootloader2  : 6.0.0.0 [41019]
                    NV Info      : 1.1,0,0
                    Software     : 5.1.1.0 [41065] by robot-soft at 2018-12-17 13:03:40
                    UE           : 5.0.0.0d
                  COMPONENTS
                    ZSP0         : 1.0.99-13616
                    ZSP1         : 1.0.99-12376
                OK
                Sent to modem: 'AT!="RRC:setDbgPerm full"'
                OK
                Sent to modem: 'AT!="RRC:showcaps"'
                == CAPS config =============================
                  .Lock UE on SRV band    : false
                  .MFBI support           : true
                  .TM8 TDD support        : false
                == CAPS ====================================
                  . access stratum: R13
                  . catM          : 1
                  . nb-IoT        : 0
                -- EUTRA bands --
                  . supported     : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1
                  . board         : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66
                  . admin         :
                  . pending admin :
                -- EUTRA carriers --
                  . admin         :
                  . pending admin :
                OK
                Sent to modem: 'AT+SQNCTM?'
                +SQNCTM: standard
                OK
                Booting up...
                10
                9
                8
                No user input detected, starting
                APN: terminal
                IMEI  35434*********
                ICCID  89310**************
                +CEREG: 2,0
                OK
                attaching...Sent to modem: 'AT!="showphy"'
                    RSRP (dBm)                            : -108.60
                    RSRQ  (dB)                            : -10.81
                    Channel estimation CINR               : 5.82
                  AGC
                    AGC RX gain (dB)                      : 59.61
                    RX PSD BO (dBFs)                      : -21.00
                    RX PSD (dBm)                          : -110.93
                    Noise level RS (dBm)                  : -114.30
                    Digital gain (dB)                     : 14.73
                    CINR RS (dB)                          : 5.70
                  NARROWBANDS
                    Last DL NB                            : 3
                    Last UL NB                            : N/A
                  AFC
                    Frequency offset RF  (Hz)             : -475
                  PBCH
                    MIB received quantity                 : 66
                OK
                SYSTEM FSM
                    | EMM AUTH FSM             |WAITING_SIM_CONFIRM |
                OK
                    RSRP (dBm)                            : -108.99
                    RSRQ  (dB)                            : -11.66
                    Channel estimation state (Cell-spec.) : LOW CINR
                    Channel estimation CINR               : 5.14
                  AGC
                    RX PSD BO (dBFs)                      : -20.81
                    RX PSD (dBm)                          : -109.95
                    Noise level RS (dBm)                  : -114.09
                    Digital gain (dB)                     : 13.75
                    CINR RS (dB)                          : 5.10
                  NARROWBANDS
                    Last DL NB                            : 3
                    Last UL NB                            : N/A
                  AFC
                  PBCH
                OK
                SYSTEM FSM
                OK
                    Synchro state                         : CELL_SEARCH
                    RSRQ  (dB)                            : -11.97
                    Channel estimation CINR               : 4.30
                  AGC
                    AGC RX gain (dB)                      : 59.59
                    RX PSD BO (dBFs)                      : -20.54
                    RX PSD (dBm)                          : -105.79
                    Digital gain (dB)                     : 5.41
                    CINR RS (dB)                          : -0.01
                  NARROWBANDS
                    Last UL NB                            : 0
                  AFC
                    Frequency offset RF  (Hz)             : -480
                  PBCH
                    MIB received quantity                 : 73
                OK
                SYSTEM FSM
                OK
                    Synchro state                         : RSRP
                    Frequency Hypothesis RF  (Hz)         : -1000
                    RSRQ  (dB)                            : -11.97
                    Channel estimation CINR               : 7.20
                  AGC
                    RX PSD BO (dBFs)                      : -19.92
                    RX PSD (dBm)                          : -103.98
                    Digital gain (dB)                     : 7.80
                  NARROWBANDS
                    Last UL NB                            : 0
                  AFC
                    Frequency offset RF  (Hz)             : 513
                  PBCH
                    MIB received quantity                 : 92
                OK
                SYSTEM FSM
                    | RRC TOP FSM              |SCANNING            |
                    | RRC SEARCH FSM           |WAIT_CELL_ID        |
                OK
                    RSRQ  (dB)                            : -11.97
                    Channel estimation CINR               : 1.74
                  AGC
                    AGC RX gain (dB)                      : 55.73
                    RX PSD BO (dBFs)                      : -33.26
                    RX PSD (dBm)                          : -123.33
                    Digital gain (dB)                     : 9.27
                  NARROWBANDS
                    Last UL NB                            : 0
                  AFC
                    Frequency offset RF  (Hz)             : -421
                  PBCH
                    MIB received quantity                 : 116
                OK
                SYSTEM FSM
                OK
                  barryjump @claus
                  @claus Would you be willing to share your main.py here? I'm increasingly thinking that I have the band, apn, or carrier setup wrong.
                    claus @barryjump
                    @barryjump For testing the attach process I use https://github.com/clausdenk/fipy-ltesignal. You should be able to use it directly by commenting the dnsserver calls at the top of the file and adjusting ATTACH_PARAMETERS. It should be ok to only specify the apn, the band should be detected automatically by the modem. If you know the band it probably speeds up the process though. I get outputs similar to
                     ('SCANNING', 'WAIT_CELL_ID').
                     ('CAMPING', 'WAIT_SIBX')..
                     ('CAMPING', 'WAIT_SIB').
                     ('SYNCING', 'WAIT_SYNC').
                     ('CAMPING', 'WAIT_SIBX').........
                     ('CONNECTING', 'CAMPED')...
                     ('CONNECTED', 'CAMPED')......attached!
                    rsrp,rsrq,<rsrp>,<rsrq>: -113.33 -15.89 -113.33 -15.89
                    rsrp,rsrq,<rsrp>,<rsrq>: -113.19 -15.96 -113.26 -15.925
                    I just had a problem with the CEREG setting !=2 and setting it to 2 fixed it for me. A pity it does not in your case.
                    B 2 Replies Last reply Reply Quote 2
                      barryjump @claus
                      @claus Thanks for your help! I'll give your code a shot
                        barryjump @claus
                        @claus I had high hopes! Unfortunately I'm seeing the same. Thanks for all your help!
                        Starting ..
                        rsrp [ -122.8 , -92.80001 ] center: -107.8
                        rsrq [ -22.2 , -7.2 ] center: -14.7
                        init lte
                        reset lte
                        cereg ['2', '0']
                        attaching..
                         ('STOPPED', 'NULL').
                         ('SCANNING', 'WAIT_CELL_ID')...
                         ('SYNCING', 'WAIT_SYNC')...........
                         ('CONNECTING', 'CAMPED').....
                         ('SCANNING', 'WAIT_RSSI')..........................................
                         ('SCANNING', 'WAIT_CELL_ID').........
                         ('CONNECTING', 'CAMPED')......
                         ('SCANNING', 'WAIT_CELL_ID')..........
                         ('CAMPING', 'WAIT_SIB')...
                         ('CAMPED', 'CAMPED_ANY').........
                         ('CAMPED', 'CAMPED_ANY')............
                         ('RESEL', 'WAIT_SIB').
                         ('RESEL', 'WAIT_CELL_ID')..
                         ('RESEL', 'WAIT_SYNC').
                         ('CAMPED', 'CAMPED_ANY').................................
                        Perhaps there is a deeper issue with the modem firmware that only Pycom can help diagnose. @Gijs or @administrators Can you recommend some next steps to diagnose my problems?
                          Thanks @claus for the great advice!~
                          My knowledge of the whole LTE thing only goes as far as the guide in the documentation unfortunately. I know we are working on publishing new LTE modem firmwares (hang tight!) but I'm not sure that will solve the issue here (we did have some succes with a beta NB-IoT firmware for other customers, you could contact me at support@pycom.io and I could send it to you!)
                            barryjump @Gijs
                            @Gijs Thanks. Emailed you just now.
                            Meantime, I don't want to give up hope as this user seems to have made this work somehow:
                            https://stackoverflow.com/questions/62791167/how-connect-to-lte-cell-network-with-pycom-fipy
                              razvan
                              Hi, were you able to resolve this issue? Thanks.
