    FiPy trouble with CatM1 AND NBIoT
    18 Posts 4 Posters 358 Views 5 Watching
      barryjump @Gijs
      @Gijs this is my code, I've tried several different APNs, but perhaps I've set this up wrong? One thing I may not be handling properly is the band and carrier, but that is a bit strange considering we've been testing MVNOs (like Hologram, Twilio, Soracom, etc.) that hop different carriers with different bands. I've left the band unspecified as a result - perhaps thats incorrect.
      #           LTE Setup
      lte = LTE()
      apn = "terminal"  ## per https://1ot.mobi
      band = "None"
      iccid = lte.iccid()
      imei = lte.imei()
      def send_at_cmd_pretty(cmd):
          response = lte.send_at_cmd(cmd).split('\r\n')
          print('Sent to modem: \'{}\''.format(cmd))
          for line in response:
              if line.strip() != '':
                  print(line)
      # MODEM DEBUG
      send_at_cmd_pretty('ATI1')                                      # retrieve modem firmware
      send_at_cmd_pretty('AT!="showver"')                             # retrieve modem firmware
      send_at_cmd_pretty('AT!="RRC:setDbgPerm full"')
      send_at_cmd_pretty('AT!="RRC:showcaps"')
      time.sleep(5)
      send_at_cmd_pretty('AT+SQNCTM?')
      def lteconnect():
          print("Attempting LTE connect with:")
          print("APN: %s" % apn)
          print('IMEI ', lte.imei()[:5] + '*' * 9)
          print('ICCID ', lte.iccid()[:5] + '*' * 14)
          time.sleep(3)
          # Initialize the modem
          lte.init()
          # Attach the modem
          lte.attach(apn="terminal")
          print("attaching..",end='')
          while not lte.isattached():
              # JFD time.delay(0.25)
              pycom.rgbled(0x500000)
              utime.sleep_ms(25)
              print('.',end='')
              send_at_cmd_pretty('AT!="showphy"')
              send_at_cmd_pretty('AT!="fsm"')
              #utime.sleep_ms(500)
              #print(lte.send_at_cmd('print'))
              utime.sleep_ms(500)
          pycom.rgbled(0x005000)
          print("attached!")
          lte.connect()
          print("connecting [##",end='')
          while not lte.isconnected():
              # JFD time.sleep(0.25)
              utime.sleep_ms(250)
              print('#',end='')
              #print(lte.send_at_cmd('AT!="showphy"'))
              print(lte.send_at_cmd('AT!="fsm"'))
              print(lte.send_at_cmd("ATI"))
          print("] connected!")
          # JFD Add delay
          utime.sleep_ms(250)
          # Ping Google server to test
          print(usocket.getaddrinfo('google.com', 80))
          print("Waiting for 60 seconds before disconnecting ...")
          time.sleep(60)
          print("OK, disconnecting now.")
          lte.deinit()
          #now we can safely machine.deepsleep()
        barryjump
        Quick update, I brought my FiPy on the road and parked right beneath a cell tower to see if perhaps my problem originated from poor signal.
        As I mentioned before, my original signal reported as follows:
        RSRQ (dB) : -10.82 (-3 Excellent to -19 Poor)
        RSRP (dBm) : -104.80 (-44 Excellent to -140 Poor)
        CINR : 10.31 (12.5 Excellent to 7 Poor)
        Underneath the tower I was seeing excellent signal stats:
        RSRQ (dB) : -6.2 (-3 Excellent to -19 Poor)
        RSRP (dBm) : -59.02 (-44 Excellent to -140 Poor)
        CINR : 28.22 (12.5 Excellent to 7 Poor)
        Unfortunately that did not resolve the issue, so all I can imagine I'm left with is some configuration problems with the Band, APN, or Network settings in lte.init() and lte.attach(). Perhaps @Gijs you have some suggestions?
          claus @barryjump
          @barryjump Your signal strength should not be a problem, I have RSRP around -115 and RSRQ at -15 and I can attach. Could you please check the following: Print the output of the AT command "AT+CEREG?" after lte.init(). If the first integer value is different from "2" ( say for example "+CEREG: 0,2" - the first value is "0") then include a "AT+CEREG=2" after lte.init(). Your "AT+CEREG?" should now give "+CEREG: 2,x". Now try to attach.
          B 2 Replies Last reply Reply Quote 0
            barryjump @claus
            @claus said in FiPy trouble with CatM1 AND NBIoT:
            AT+CEREG?
            Thanks @claus running that check showed the following:
            Sent to modem: 'AT+CEREG?'
            +CEREG: 2,0
            OK
            Which means it was already configured with that value. I did notice it got to connecting a bit faster than usual this time, but same problem: from connecting to searching almost immediately. :(
            Pybytes configuration read from /flash/pybytes_config.json
            Not starting Pybytes as auto-start is disabled
            Sent to modem: 'ATI1'
            UE5.0.0.0d
            LR5.1.1.0-41065
            OK
            Sent to modem: 'AT!="showver"'
            SYSTEM VERSION
              FIRMWARE VERSION
                Bootloader0  : 5.1.1.0 [39529]
                Bootloader1* : 5.1.1.0 [41065]
                Bootloader2  : 6.0.0.0 [41019]
                NV Info      : 1.1,0,0
                Software     : 5.1.1.0 [41065] by robot-soft at 2018-12-17 13:03:40
                UE           : 5.0.0.0d
              COMPONENTS
                ZSP0         : 1.0.99-13616
                ZSP1         : 1.0.99-12376
            OK
            Sent to modem: 'AT!="RRC:setDbgPerm full"'
            OK
            Sent to modem: 'AT!="RRC:showcaps"'
            == CAPS config =============================
              .Lock UE on SRV band    : false
              .MFBI support           : true
              .TM8 TDD support        : false
            == CAPS ====================================
              . access stratum: R13
              . catM          : 1
              . nb-IoT        : 0
            -- EUTRA bands --
              . supported     : 66/28/26/25/20/19/18/17/14/13/12/8/5/4/3/2/1
              . board         : 1/2/3/4/5/8/12/13/14/17/18/19/20/25/26/28/66
              . admin         :
              . pending admin :
            -- EUTRA carriers --
              . admin         :
              . pending admin :
            OK
            Sent to modem: 'AT+SQNCTM?'
            +SQNCTM: standard
            OK
            Booting up...
            10
            9
            8
            No user input detected, starting
            APN: terminal
            IMEI  35434*********
            ICCID  89310**************
            +CEREG: 2,0
            OK
            attaching...Sent to modem: 'AT!="showphy"'
            DL SYNCHRO STATISTICS
                Synchro state                         : CELL_ACQUIRED
                PPU SIB1 ACQ watchdog                 : 0
                Frequency Hypothesis RF  (Hz)         : 0
                RSRP (dBm)                            : -108.60
                RSRQ  (dB)                            : -10.81
                Channel estimation state (Cell-spec.) : HIGH CINR
                Channel estimation state (UE-spec.)   : LOW CINR
                Channel estimation state (MBSFN)      : LOW CINR
                Channel estimation CINR               : 5.82
                Channel length                        : SHORT
              AGC
                AGC RX gain (dB)                      : 59.61
                RX PSD BO (dBFs)                      : -21.00
                RX PSD (dBm)                          : -110.93
                Noise level RS (dBm)                  : -114.30
                Digital gain (dB)                     : 14.73
                CINR RS (dB)                          : 5.70
              NARROWBANDS
                Last DL NB                            : 3
                Last UL NB                            : N/A
              AFC
                Frequency offset RF  (Hz)             : -475
                Frequency offset BB  (Hz)             : 0
              PBCH
                MIB received quantity                 : 66
                MIB timeout quantity                  : 0
            OK
            Sent to modem: 'AT!="fsm"'
            SYSTEM FSM
                | RRC TOP FSM              |CONNECTING          |
                | RRC SEARCH FSM           |CAMPED              |
                | RRC ACTIVE FSM           |WAIT_SMC            |
                | PMM PLMN FSM             |NORM_CAMPED         |
                | EMM MAIN FSM             |REGISTERED_INIT     |
                | EMM AUTH FSM             |WAITING_SIM_CONFIRM |
                | EMM CONN FSM             |AS_ESTABLISHED      |
                | ESM BEARER FSM           |BEARER_NULL_PENDING_ACTIVE|
            OK
                RSRP (dBm)                            : -108.99
                RSRQ  (dB)                            : -11.66
                Channel estimation state (Cell-spec.) : LOW CINR
                Channel estimation CINR               : 5.14
              AGC
                RX PSD BO (dBFs)                      : -20.81
                RX PSD (dBm)                          : -109.95
                Noise level RS (dBm)                  : -114.09
                Digital gain (dB)                     : 13.75
                CINR RS (dB)                          : 5.10
              NARROWBANDS
                Last DL NB                            : 3
                Last UL NB                            : N/A
              AFC
                Frequency offset RF  (Hz)             : -492
              PBCH
            OK
            SYSTEM FSM
                | EMM AUTH FSM             |KASME_DEFINED       |
            OK
                Synchro state                         : CELL_SEARCH
                RSRP (dBm)                            : -21474836.00
                RSRQ  (dB)                            : -11.97
                Channel estimation CINR               : 4.30
              AGC
                AGC RX gain (dB)                      : 59.59
                RX PSD BO (dBFs)                      : -20.54
                RX PSD (dBm)                          : -105.79
                Noise level RS (dBm)                  : -128.24
                Digital gain (dB)                     : 5.41
                CINR RS (dB)                          : -0.01
              NARROWBANDS
                Last DL NB                            : Central
                Last UL NB                            : 0
              AFC
                Frequency offset RF  (Hz)             : -480
              PBCH
                MIB received quantity                 : 73
            OK
            SYSTEM FSM
                | RRC TOP FSM              |SYNCING             |
                | RRC SEARCH FSM           |WAIT_SYNC           |
                | RRC ACTIVE FSM           |NULL                |
            OK
                Synchro state                         : RSRP
                Frequency Hypothesis RF  (Hz)         : -1000
                RSRQ  (dB)                            : -11.97
                Channel estimation CINR               : 7.20
              AGC
                RX PSD BO (dBFs)                      : -19.92
                RX PSD (dBm)                          : -103.98
                Digital gain (dB)                     : 7.80
              NARROWBANDS
                Last UL NB                            : 0
              AFC
                Frequency offset RF  (Hz)             : 513
              PBCH
                MIB received quantity                 : 92
            OK
            SYSTEM FSM
                | RRC TOP FSM              |SCANNING            |
                | RRC SEARCH FSM           |WAIT_CELL_ID        |
            OK
                RSRQ  (dB)                            : -11.97
                Channel estimation CINR               : 1.74
              AGC
                AGC RX gain (dB)                      : 55.73
                RX PSD BO (dBFs)                      : -33.26
                RX PSD (dBm)                          : -123.33
                Digital gain (dB)                     : 9.27
              NARROWBANDS
                Last UL NB                            : 0
              AFC
                Frequency offset RF  (Hz)             : -421
              PBCH
                MIB received quantity                 : 116
            OK
            SYSTEM FSM
            OK
              barryjump @claus
              @claus Would you be willing to share your main.py here? I'm increasingly thinking that I have the band, apn, or carrier setup wrong.
                claus @barryjump
                @barryjump For testing the attach process I use https://github.com/clausdenk/fipy-ltesignal. You should be able to use it directly by commenting the dnsserver calls at the top of the file and adjusting ATTACH_PARAMETERS. It should be ok to only specify the apn, the band should be detected automatically by the modem. If you know the band it probably speeds up the process though. I get outputs similar to
                 ('SCANNING', 'WAIT_CELL_ID').
                 ('CAMPING', 'WAIT_SIBX')..
                 ('CAMPING', 'WAIT_SIB').
                 ('SYNCING', 'WAIT_SYNC').
                 ('CAMPING', 'WAIT_SIBX').........
                 ('CONNECTING', 'CAMPED')...
                 ('CONNECTED', 'CAMPED')......attached!
                rsrp,rsrq,<rsrp>,<rsrq>: -113.33 -15.89 -113.33 -15.89
                rsrp,rsrq,<rsrp>,<rsrq>: -113.19 -15.96 -113.26 -15.925
                I just had a problem with the CEREG setting !=2 and setting it to 2 fixed it for me. A pity it does not in your case.
                B 2 Replies Last reply Reply Quote 2
                  barryjump @claus
                  @claus Thanks for your help! I'll give your code a shot
                    barryjump @claus
                    @claus I had high hopes! Unfortunately I'm seeing the same. Thanks for all your help!
                    Starting ..
                    rsrp [ -122.8 , -92.80001 ] center: -107.8
                    rsrq [ -22.2 , -7.2 ] center: -14.7
                    init lte
                    reset lte
                    cereg ['2', '0']
                    attaching..
                     ('STOPPED', 'NULL').
                     ('SCANNING', 'WAIT_CELL_ID')...
                     ('SYNCING', 'WAIT_SYNC')...........
                     ('CONNECTING', 'CAMPED').....
                     ('SCANNING', 'WAIT_RSSI')..........................................
                     ('SCANNING', 'WAIT_CELL_ID').........
                     ('CONNECTING', 'CAMPED')......
                     ('SCANNING', 'WAIT_CELL_ID')..........
                     ('CAMPING', 'WAIT_SIB')...
                     ('CAMPED', 'CAMPED_ANY').........
                     ('CAMPED', 'CAMPED_ANY')............
                     ('RESEL', 'WAIT_SIB').
                     ('RESEL', 'WAIT_CELL_ID')..
                     ('RESEL', 'WAIT_SYNC').
                     ('CAMPED', 'CAMPED_ANY').................................
                    Perhaps there is a deeper issue with the modem firmware that only Pycom can help diagnose. @Gijs or @administrators Can you recommend some next steps to diagnose my problems?
                      Thanks @claus for the great advice!~
                      My knowledge of the whole LTE thing only goes as far as the guide in the documentation unfortunately. I know we are working on publishing new LTE modem firmwares (hang tight!) but I'm not sure that will solve the issue here (we did have some succes with a beta NB-IoT firmware for other customers, you could contact me at support@pycom.io and I could send it to you!)
                        barryjump @Gijs
                        @Gijs Thanks. Emailed you just now.
                        Meantime, I don't want to give up hope as this user seems to have made this work somehow:
                        https://stackoverflow.com/questions/62791167/how-connect-to-lte-cell-network-with-pycom-fipy
                          razvan
                          Hi, were you able to resolve this issue? Thanks.
