    LoPy Nano-Gateway Extended (Timeout and Retry)
    31 Posts 14 Posters 20.1k Views 17 Watching
      gerkez
      Hello Roberto,
      Where do I change the band?
      I don't see it in your scripts
        Butch @Butch
        @Butch said in LoPy Nano-Gateway Extended (Timeout and Retry):
        I've tried the examples, but I am not having any success. The gateway is not receiving any messages with length > 0. To the best of my knowledge, there are no other LoRa devices in use, and I am using only one gateway and one node.
        Any suggestions on how to debug this?
        Following up on my own post (poor form, I know, but what to do?), I thought I'd provide more information:
        • I am trying to use one LoPy on an expansion board with antenna as a gateway, and one with the same setup as a node.
        • I am running this code on the gateway (http://pastebin.com/PDCnq2gF) and this on the node (http://pastebin.com/Ztf5QMWY).
        • I am seeing constant messages of zero length being received on the gateway:
        Starting LoRaNanoGateway
        Received message, length = 0
        • I am seeing no acknowledgements on the node:
        Starting LoRaNanoNode on device 1
        Sending a message from device 1
        MESSAGE FAILED
        MESSAGE FAILED
        MESSAGE FAILED
        MESSAGE FAILED
        I have tried four different LoPy's in two different physical locations, so I don't think I'm having any RF pollution issues.
        I could really use some help with this.
          bucknall @Butch
          Hi @Butch
          There's previously was a small bug in the gateway and node code where you need to specify the spread factor (e.g. sf=7).
          This has since been patched in the latest firmware release, please try to update your device and your code should now work!
          Cheers!
          Developer Evangelist - Pycom
          B 2 Replies Last reply Reply Quote 0
            Butch @bucknall
            @bucknall said in LoPy Nano-Gateway Extended (Timeout and Retry):
            Hi @Butch
            Cheers!
            It works! Thank you so much!
            Butch
              Colateral @Roberto
              @Roberto Doesn't work anymore with. Simply GW not getting the message.
              (sysname='LoPy', nodename='LoPy', release='1.6.10.b1', version='v1.8.6-556-g989d5ac9 on 2017-03-30', machine='LoPy with ESP32', lorawan='1.0.0')
              Any ideas why?
                Butch @bucknall
                @bucknall Alex, I'll share my current issue here so that hopefully others can benefit from my stupidity. :-)
                I have the sample code above working. The node and gateway properly exchange message/ACK. The message being sent from the node is
                DEVICE 1 HERE
                To make this more useful, I want to change the message to some JSON reporting a temperature:
                {"id": 1, "temperature": -14.3,"unit": "C","time":"14-Apr-2017@21:48:32"}
                However, this fails. But it fails in a completely unexpected way. On the gateway:
                recv_pkg = lora_sock.recv(512)
                constantly receives zero-length packets. All I did was change the message being sent. I did not change the header, nor the struct. If I had a malformed header or payload, I would expect the recv to at least get something with a length greater than zero bytes.
                Complete sample code for gateway:
                # LoRaNanoGateway.py
                import struct
                from network import LoRa
                # A basic package header
                # B: 1 byte for the deviceId
                # B: 1 byte for the pkg size
                # B: 1 byte for the messageId
                # %ds: Formated string for string
                _LORA_PKG_FORMAT = "!BBB%ds"
                # A basic ack package
                # B: 1 byte for the Ok (200) or error messages
                _LORA_PKG_ACK_FORMAT = "BBBB"
                # Let the world know we're starting up.
                print("Starting LoRaNanoGateway")
                # Open a Lora Socket, use rx_iq to avoid listening to our own messages
                lora = LoRa(mode=LoRa.LORA, frequency=915000000, rx_iq=True)
                lora_sock.setblocking(False)
                while (True):
                    # Since the maximum body size in the protocol is 255 the request is limited to 512 bytes
                    print("Received message, length = %d" % len(recv_pkg))
                    # If at least a message with the header is received process it
                    if (len(recv_pkg) > 3):
                        print("<<<<<<<<<<<<< Received VALID message, length = %d" % len(recv_pkg))
                        recv_pkg_len = recv_pkg[1]
                        # If message is corrupted should not continue processing
                        if (not len(recv_pkg) == recv_pkg_len + 3):
                            continue
                        # Unpack the message based on the protocol definition
                        device_id, pkg_len, msg_id, msg = struct.unpack(_LORA_PKG_FORMAT % recv_pkg_len, recv_pkg)
                        # Respond to the device with an acknowledge package
                        # time.sleep(0.15)
                        print("+++ Received a message: %s" % msg)
                        ack_pkg = struct.pack(_LORA_PKG_ACK_FORMAT, device_id, 1, msg_id, 200)
                        print("------ Sending an ACK")
                        lora_sock.send(ack_pkg)
                        # Do any extra processing required for the package. Keep in mind it should be as fast as posible
                        # to make sure that the other clients are not waiting too long for their messages to be acknoleged
                Complete sample code for node:
                # LoRaNanoNode.py
                import struct
                from uos import urandom
                # This device ID, use different device id for each device
                _DEVICE_ID = 0x01
                _MAX_ACK_TIME = 5000
                _RETRY_COUNT = 3
                print("Starting LoRaNanoNode on device %d" % _DEVICE_ID)
                # Open a Lora Socket, use tx_iq to avoid listening to our own messages
                lora = LoRa(mode=LoRa.LORA, frequency=915000000, tx_iq=True)
                # Method to increase message id and keep in between 1 and 255
                msg_id = 0
                def increase_msg_id():
                    global msg_id
                    msg_id = (msg_id + 1) & 0xFF
                # Method for acknoledge waiting time keep
                def check_ack_time(from_time):
                    current_time = time.ticks_ms()
                    return (current_time - from_time > _MAX_ACK_TIME)
                # Method to send messages
                def send_msg(msg):
                    global msg_id
                    retry = _RETRY_COUNT
                    while (retry > 0 and not retry == -1):
                        retry -= 1
                        pkg = struct.pack(_LORA_PKG_FORMAT % len(msg), _DEVICE_ID, len(msg), msg_id, msg)
                        bytes_sent = lora_sock.send(pkg)
                        print(">>>>>>>>>>>>>> Sending package %s, length = %d, bytes sent = %d" % (pkg, len(pkg), bytes_sent))
                        # Wait for the response from the server.
                        start_time = time.ticks_ms()
                        while(not check_ack_time(start_time)):
                            recv_ack = lora_sock.recv(256)
                            # If a message of the size of the acknoledge message is received
                            if (len(recv_ack) == 4):
                                device_id, pkg_len, recv_msg_id, status = struct.unpack(_LORA_PKG_ACK_FORMAT, recv_ack)
                                if (device_id == _DEVICE_ID and recv_msg_id == msg_id):
                                    if (status == 200):
                                        # Do some code if your message arrived at the central
                                        return True
                                        return False
                        time.sleep_ms(urandom(1)[0] << 2)
                    return False
                # Main Loop
                while(True):
                    msg = '{"id": %s, "temperature": -14.3,"unit": "C","time":"14-Apr-2017@21:48:32"}' % _DEVICE_ID
                    # msg = "DEVICE %d HERE" % _DEVICE_ID
                    print("Sending a message: %s, length = %d" % (msg, len(msg)))
                    # success = send_msg("DEVICE %d HERE" % _DEVICE_ID)
                    success = send_msg(msg)
                    if (success):
                        print("ACK RECEIVED: %d" % msg_id)
                        increase_msg_id()
                        print("MESSAGE FAILED")
                        # Manage the error message
                # >>>>>>>>>>>>>> Sending package b'\x01I\x00{"id": 1, "temperature": -14.3,"unit": "C","time":"14-Apr-2017@21:48:32"}', length = 76
                # >>>>>>>>>>>>>> Sending package b'\x01\r\x10DEVICE 1 HERE', length = 16
                You can see that I have dumped the raw packed structure, and that it sure looks like it's properly formed. ASCII '\r' corresponds to 13, which is the length of the payload in the original sample message, and ASCII 'I' corresponds to 73, which is the length of the payload in my new message. The device ID in the header is the same, and the message ID shouldn't matter, right?
                My understanding is that the payload size is limited to 255 bytes, so I don't think I'm running into a space issue.
                I should also add that I'm running 1.6.8b2 on both boards:
                >>> import os
                >>> os.uname()
                (sysname='LoPy', nodename='LoPy', release='1.6.8.b2', version='v1.8.6-530-gca8bdcbb on 2017-03-21', machine='LoPy with ESP32', lorawan='1.0.0')
                Any help anyone can provide would be greatly appreciated.
                  gouao
                  Can a seeeduino lorawan communicate with the lopys ?
                  Can it act as a node, wich is recognized by the lopy nano-gateway ?
                    Butch @Butch
                    Following up on my own post (which seems to be a theme for me), I discovered that it is, indeed, the length of the payload that's causing the problem. If I limit the payload to 61 bytes (plus a three-byte header), it works:
                    Sending a message: 1234567890123456789012345678901234567890123456789012345678901, length = 61
                    >>>>>>>>>>>>>> Sending package b'\x01=\x001234567890123456789012345678901234567890123456789012345678901', length = 64, bytes sent = 64
                    ACK RECEIVED: 0
                    If, however, I increase the length of the payload to 62 bytes (plus a three-byte header), it fails:
                    Sending a message: 12345678901234567890123456789012345678901234567890123456789012, length = 62
                    >>>>>>>>>>>>>> Sending package b'\x01>\x0012345678901234567890123456789012345678901234567890123456789012', length = 65, bytes sent = 65
                    MESSAGE FAILED
                    Any ideas?
                      Butch @Butch
                      And, once again replying to my own post, I understand why:
                      LoRa spec:
                      7.2.6 US902-928 Maximum payload size
                      2 The maximum MACPayload size length (M) is given by the following table. It is derived from
                      3 the maximum allowed transmission time at the PHY layer taking into account a possible
                      4 repeater encapsulation. The maximum application payload length in the absence of the
                      5 optional FOpt MAC control field (N) is also given for information only. The value of N might
                      6 be smaller if the FOpt field is not empty:
                      DataRate       M         N
                      0              19        11
                      1              61        53
                      2              137       129
                      3              250       242
                      4              250       242
                      5:7             Not defined
                      8              41        33
                      9              117       109
                      10             230       222
                      11             230       222
                      12             230       222
                      13             230       222
                      14:15           Not defined
                      So, as you can see, at data rate 1, the maximum payload size is 61 bytes. If I want to send more, I have to increase the data rate.
                      My question now is how do I increase the data rate? Ideally, I'd like to use data rate 3.
                      It looked like I could just do this:
                      lora_sock.setsockopt(socket.SOL_LORA, socket.SO_DR, 3)
                      That code completes with no complaint, but when I make the change on both the node and gateway sides, it does not change the maximum payload size.
                      After playing around with it some more, 4 seems to be the maximum supported, in spite of what the chart above says.
                      Any ideas? Please?
                        Colateral @Butch
                        @Butch Are you using 1.6.11b1? How exactly instantiated lora stack for the GW and the Node? I mean all can yu enumerate all params that you configured for the lora object?
                          Butch @Colateral
                          @Colateral Thanks for your reply. My post below provides all the answers to the questions you asked. Not only does it have the version number of the firmware that I'm using, it also has all the code for both the node and the gateway.
                          • F Offline
                            fbt @Roberto
                            Hi @Roberto , in case i wanted to support more than 2 nodes, i.e 8 nodes, which parameters should i modify on the gateway code?. thanks
                            • F Offline
                              fbt @gouao
                              Hi @gouao, did you get any answer about the compatibility of seeeduino lorawan and lopy? thanks
                                gouao @fbt
                                @fbt hello mate, unfortunately i could't get any informations concerning this..
                                If you find out something please let me know !
                                All the best!
                                • F Offline
                                  fbt @gouao
                                  Thanks @gouao ... any reply about this issue @jmarcelino ? thanks
                                    jmarcelino @fbt
                                    @fbt
                                    For a LoRaWAN device you'd usually want to be using https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway and not the code on the post. This code is for raw LoRa only.
                                    8 devices on the LoRaWAN gateway shouldn't be a problem as long as they don't transmit at the same time.
                                    • H Offline
                                      heut
                                      Hi @Roberto and @Butch
                                      Thank you very much for the interesting discussion. I'm currently trying to get the plain code (node_1.py and nano_gateway.py) working on my LoPy(s), without success so far. I have both updated to the latest Firmware for Switzerland and sitting in an extension board with antennas attached. When running the code respective code on the LoPys, not a single message is delivered and acknowledged. All messages that are received on the gateway node have the size 0.
                                      From time to time the node_1.py LoPy shows a longer LED blink in blue instead of the heartbeat.
                                      Any idea what I might be doing wrong?
                                      Best
                                      heut
                                      • sebS Offline
                                        seb @heut
                                        @heut try adding a delay in your loop, e.g. 50ms, this seemed to vastly improve the situation for me
                                        • H Offline
                                          heut @seb
                                          @seb Thank you for the hint. However, that didn't make a difference in my situation at all. There is still not a single message transmitted. Any other suggestions what it might be?
                                          Just to be sure, here the sources I'm using.
                                          Gateway:
                                          import struct
                                          #lora = LoRa(mode=LoRa.LORA, tx_iq=True, frequency=870000000, sf=7)
                                          lora = LoRa(mode=LoRa.LORA, tx_iq=True)
                                          while (True):
                                                  print("Package received")
                                                  #if (not len(recv_pkg) == recv_pkg_len + 3):
                                                      #continue
                                                  # Respond to the device with an acknoledge package
                                                  # time.sleep(0.15)
                                                  print("sent ack")
                                              time.sleep(0.2)
                                          Node:
                                          import struct
                                          _DEVICE_ID = 0x01
                                          _RETRY_COUNT = 3
                                          msg_id = 0
                                              global msg_id
                                          def send_msg(msg):
                                              print("SEND MSG")
                                              print(msg)
                                              global msg_id
                                                  retry -= 1
                                                  lora_sock.send(pkg)
                                                      #print("RECV_ACK")
                                                          print("SIZE CORRECT")
                                                              if (status == 200):
        return True
        return False
                                              return False
                                          # Main Loop
                                          while(True):
                                              if (success):
                                                  increase_msg_id()
                                          • sebS Offline
                                            seb @heut
                                            @heut I will have a closer look at your code now but in the mean time, a few things that often catch users out:
                                            • Make sure both LoPy modules are running the same firmware
                                            • Please set the frequency to ensure it is the same on both
                                            One thing I have already noticed is you have set tx_iq on both the node and the gateway, it should be rx_iq=True for the gateway and tx_iq=True on the nodes.
