    Sensor JSON Post stops after a few hours
    jsonuartpost
    14 Posts 3 Posters 2.5k Views 3 Watching
      jimpower
      Re: Serial to UART POST JSON
      My sensor runs for a few hours and stops with following error.
      0_1522053912470_7c3b39d0-4fd8-4c9f-b4b1-4261824a4a98-image.png ![alt text](image url)
      Could anyone please direct me as to where I might be going wrong please find code below
      import network
      import gc
      import urequests
      from network import WLAN
      execfile('/flash/Wi-Fi/Wi-Fi.py')
      f_device = open('/flash/Config/Device_Details.txt', 'r')
      device_setting = f_device.readline()
      device_strings = [i.strip() for i in device_setting.split(',')]
      f_device.close()
      gc.enable()
      uart1 = machine.UART(1, baudrate=9600, bits=8, parity=None, stop=1)
      time.sleep(2)
          tmp = uart1.readall()
          res = urequests.post('https://mywebsite', json={'Weight': str(tmp)})
          res.close()
          if (res.status_code - 200) < 100: # check that response code is in the 200 range
              print("Weight POST Successful")
              print('there was some error')
          gc.collect()
          print(gc.mem_free())
          time.sleep(57)
      • sebS Offline
        seb @jimpower
        @jimpower
        You can see here that EBADF means bad file number which would suggest an issue with sockets.
        I tried to match the error above to the code you posted by line 35 is gc.collect(), is the code you posted the same code that causes the issue?
        Edit: And line 112 in urequests is the get function which I dont see anywhere in your code, this is certainly not the same code
        J 2 Replies Last reply Reply Quote 0
          jimpower @seb
            jimpower @seb
            RS232 Weigh Sensor [Rinstrum_2100]
            import network
            import gc
            import urequests
            #INITIALISE LAN
            execfile('/flash/Wi-Fi/Wi-Fi.py') # connect to wifi
            #INITIALISE DEVICE DETAILS
            f_device = open('/flash/Config/Device_Details.txt', 'r') # read device details from file
            # file format is: Device Type, Device Location ie Fridge, Workshop A, Damp Pump
            f_device.close()
            #INITIALISE LIBRARIES
            gc.enable()
            time.sleep(2)
            #INITIALISE VARIABLES
            res = urequests.post('mywebsite', json={'Weight': str(tmp)})
            res.close()
            print("Weight POST Successful - " + str(tmp))
            gc.collect()
            time.sleep(57)
            • sebS Offline
              seb @jimpower
              @jimpower
              Are you using urequests from here? https://github.com/micropython/micropython-lib/blob/master/urequests/urequests.py
                jimpower @seb
                @seb
                This seems like a different version to mine there were only 122 lines in mine, so I updated to this version and got the following error.
                  jimpower @seb
                  @seb
                  I used latest urequests.py and changed line 53 to
                  ai = usocket.getaddrinfo(host, port)
                  I still get the same error
                    timh @jimpower
                    @jimpower I would suggest you wrap that call in a try/except block. Catch the exception.
                    At that point (line 53, you are trying to resolve an address). My guess is wifi might have dropped out.
                    It might be worth in the exception handler checking to see if wifi is still connected, and potentially checking you can resolve the name. If all is good retry, or reconnect wifi etc..
                    My feeling is you should expect the link to fail at some point and your code be able to deal with it.
                    J T 2 Replies Last reply Reply Quote 0
                      jimpower @timh
                      @timh
                      I was leaning towards this however I'm not sure how to go about the try/except block. Would you be able to help me understand how to check if wifi is still connected and also if I can resolve name as wifi could be good without active internet access.
                        timh @timh
                        @timh This is very rough (and to be honest not well structured) but for instance you could implement a check for connectivity, and if you get an error then try reconnecting.
                        def linkup()
                                if wlan.isconnected():
                                     try:
                                          usocket.getaddrinfo("someaddress.com", someport, 0, usocket.SOCK_STREAM)
                                     except OSError as e:
                                          return False
                                     return True
                                return False
                        Then in your main loop
                        try:
                            res.close()
                            if linkup():
                                continue
                                do_something_to_reconnect()
                                # if this fails then may be machine.reset()
                          jimpower @timh
                          @timh
                          I have tried to emulate what you have done but get an error could you help me to identify
                          def linkup():
                                   try:
                                        usocket.getaddrinfo("https://my.website.io", 8082, 0, usocket.SOCK_STREAM)
                                        return False
                                   return True
                              return False
                          try:
                              res = urequests.post('https://my.website', json={'Weight': str(tmp)})
                              res.close()
                              print(str(tmp))
                              if linkup():
                                  continue
                              wlan = WLAN(mode=WLAN.STA)
                              wlan.connect(wifi_strings[0],  auth=(WLAN.WPA2, wifi_strings[2]), timeout = 5000)
                              print('Wi-Fi Connecting To :', wifi_strings[0],)
                              while not wlan.isconnected():
                              	machine.idle()
                          gc.collect()
                          time.sleep(50)
                          getting following error
                            timh @jimpower
                            @jimpower Umm your earlier sample code shows it being imported.
                            Make sure you still have
                             import urequests
                            somewhere, and it's in your deployed code.
                              jimpower @timh
                              @timh
                              yes
                              import network
                              import gc
                              import urequests as requests
                              #INITIALISE LAN
                              f_device.close()
                              gc.enable()
                              time.sleep(2)
                              is above the I just didn't include it in previous post
                                timh @jimpower
                                @jimpower ok, so why do you get no module found when you call urequests.post now when you didn't before.
                                I can't see all your code, just snippets. The vaious sample bits of code are being changed.
                                Oh I see now what the problem is, when you import urequests you are importing as requests hence the module not found error.
                                You will need to change the sample to requests.post
                                Also as an aside why do you execfile('/flash/Wi-Fi/Wi-Fi.py') rather than importing. This seems odd thing to do.
