    BME280 on the LoPy
    bme280lopyi2c
    41 Posts 12 Posters 16.3k Views 12 Watching
    • B Offline
      binux
      I'm currently trying to get the Adafruit BME280 sensor running with my LoPy.
      And I came across pretty much the same issue as michal in this post Wipy 2.0 and BME280 sensor.
      However my issue is looking a little different:
        File "<stdin>", line 9, in <module>
        File "bme280.py", line 185, in __init__
        File "bme280.py", line 191, in _load_calibration
        File "bme280.py", line 151, in readU16LE
        File "bme280.py", line 134, in readU16
      OSError: I2C bus error
      I'm very new to the LoPy and as far as I read from the specs he has pretty much the same hardware as the WiPy. So I ask myself what could cause this issue. The original library: https://bitbucket.org/oscarBravo/wipy_bme280
      I initialized my BME like this:
      >>> from machine import I2C
      >>> import bme280
      >>> i2c = I2C(0, I2C.MASTER, baudrate=100000)
      >>> bme = bme280.BME280(i2c=i2c)
      Do you have any suggestions how to solve this?
      Thanks already in advance!
      L B 2 Replies Last reply Reply Quote 0
        livius @binux
        @binux
        if your firmware
        os.uname()
        is 1.6.8.b1
        then it not work at all - you must wait for new firmware or downgrade it to 1.6.7 or 1.6.6
        B S 2 Replies Last reply Reply Quote 0
        • B Offline
          binux
          • B Offline
            binux @livius
            @livius Okay, tell me why - I'm running the latest firmware. Which was i think 1.6.8b1 - just updated today...
            Anyhow, would this library work with the fix propsed on the other thread or would I still have to change something?
              livius @binux
              @binux
              As i say - current firmware (1.6.8.b1) introduce some bug with I2C or bring it more visible then previously.
              You must downgrade firmware to 1.6.7 or wait for new firmware release.
                sakis @livius
                @livius
                Hi Livius,
                Can you give an example of the minimum code to reproduce this issue (preferably on GitHub)?
                L 2 Replies Last reply Reply Quote 0
                  livius @sakis
                  @sakis
                  I will try to minimize code but i can't promise that this will be today
                  but you can try @binux sample (i did not tried it self) - maybe this is minimal code to reproduce.
                    livius @sakis
                    @sakis
                    I see that I2C work back in 1.6.9 :)
                    • B Offline
                      Butch @binux
                      @binux I am seeing exactly the same problem with 1.6.10b1. I have Vin on the BME280 tied to 3.3v on the LoPy, I have ground on the BME280 tied to gnd on the LoPy, I have SDA on the BME280 tied to pin P9 on the LoPy, and I have SCL on the BME280 tied to pin P10 on the LoPy.
                      >>> import bme280
                      >>> i2c.scan()
                      [118]
                        File "bme280.py", line 186, in __init__
                        File "bme280.py", line 192, in _load_calibration
                        File "bme280.py", line 152, in readU16LE
                        File "bme280.py", line 135, in readU16
                      As you can see, the I2C bus has something on it at hex address 0x76 (118 decimal). However, initializing the BME280 fails.
                      Any help, anyone? Please?
                      Thanks!
                      • RobTuDelftR Offline
                        RobTuDelft
                        You have to specifiy the address when creating the sensor object:
                        def __init__(self, address, i2c):. I don't see the address getting the default address assigned here, maybe that's your issue?
                        edit:
                        I was looking at the wrong class
                        address=BME280_I2CADDR
                        It gets the default address from there
                        self._device = Device(address, i2c)
                        Without data you're just another person with an opinion.
                        Hackster | About me
                        • ledbelly2142L Offline
                          ledbelly2142
                          I am trying to use the same library with a BME280 and am experienceing the exact same issue with firmware version 1.7.4.b1
                          same error:
                            File "main.py", line 9, in <module>
                            File "bme280.py", line 198, in init
                            File "bme280.py", line 204, in _load_calibration
                            File "bme280.py", line 164, in readU16LE
                            File "bme280.py", line 147, in readU16
                          Did anyone get this to work?
                          Friends don't let friends run with scissors
                          • B Offline
                            Butch @ledbelly2142
                            @ledbelly2142 said in BME280 on the LoPy:
                            same error:
                            Try my fork of the library: https://github.com/ButchAnton/LoPy_BME280
                            ledbelly2142L 1 Reply Last reply Reply Quote 0
                              ledbelly2142 @Butch
                              @Butch
                              yup, thats what I'm using. I forked it. Why the init.py file?
                              • B Offline
                                Butch @ledbelly2142
                                @ledbelly2142 That makes it into a package: https://docs.python.org/2/tutorial/modules.html#packages
                                  ledbelly2142 @Butch
                                  @Butch
                                  I still have the same issue, just updated to the latest firmware 1.7.5.b2
                                  In the main.py I'm just trying to print out values in the console, I have:
                                  import bme280 # from bme280
                                  i2c.scan()
                                  #i2c = machine.I2C(0, pins=('GP11', 'GP10'))
                                  temp = BME280.temperature()
                                  humid = BME280.humidity()
                                  press = BME280.pressure()
                                  alti = BME280.altitude()
                                  #for cycles in range(10): # stop after 10 cycles
                                  while(true):
                                      print(temp) # read temperature
                                      time.sleep(2)
                                      print(humid) # read humidity
                                      time.sleep(2)
                                      print(press) # read Pressure
                                      time.sleep(2)
                                      print(alti) # read altitude
                                      time.sleep(2)
                                  • B Offline
                                    Butch @ledbelly2142
                                    @ledbelly2142 Try following the line of logic I tried in the python REPL: import, instantiate, and initialize:
                                    >>> import bme280
                                    See where that takes you.
                                    The original problem I ran into and ultimate fixed was that the 8- and 16-bit writes needed the value to be written to be a bytearray, not the raw value. Beyond that, all I added was a wrapper for altitude.
                                      ledbelly2142 @Butch
                                      @Butch
                                      For me, the issue comes up from :
                                      Thats where I get the errors indicating an I2C bus error.
                                      I SDA on pin 9 and SCL on pin 10.
                                      Could it be a bad sensor?
                                      So I unplugged the BME280 sensor and got the same error.
                                      • B Offline
                                        Butch @ledbelly2142
                                        @ledbelly2142 It's possible that it's a bad sensor. Do you have another one to try? You might also check to make sure that i2c.scan() is returning the same address that is used in the BME280 library. If it isn't, you'll have to change the address in the library.
                                          ledbelly2142 @Butch
                                          @Butch
                                          That looks to be it. The I2C address was 77, not 76... weird. I did not think to check the I2C address.
                                          Thanks!
                                            Devang Sharma
                                            Hello Everyone,
                                            I'm using LoPy and I've got the similar type of error as @binux got.
                                            I'm getting the following error:
                                            This is my code:
                                            Please guide me solving this!
                                            Thank You.
                                            • 1
                                            • 2
                                            • 3
                                            • 1 / 3
