@Roberto-Duca yes, you need to use only the frequency chosen on the gateway.
Note that the network may (and probably will) send it’s on list of channels and frequencies after the join, so ideally you should configure the network to only send that single frequency (don’t know if you can do that on TTN), or you will have to reset the list of channels after the join (or rather before each transmit).
Also I believe the nano-gateway only listen on a single DR, so likewise, you should restrict your node to that single DR (both for join and subsequent traffic).
Remember that a nano-gateway is just there for a bit of testing, it’s by far not a real LoRaWAN-compliant gateway.
