• TTN join accept not handled properly
    Pinned Moved lopy network nano gateway ttn
    20
    10k Views
    I know this is a quite old topic, but I have the same issue. It seems like the issue does still persists.
  • How to use "characteristic.write(value)"
    Pinned Moved ble send data
    @jmarcelino Thank you,it works now. The lightBlue get the reply in reads.
  • LoPy Pin Out
    Pinned
    Ok I got it. One of the class Pin methods is exp_board method. So inputting Pin.exp_board.G16 into the REPL will output Pin('P9', mode=Pin.OUT, pull=None, drive=Pin.MED_POWER, alt=-1) Meaning G16 on the expansion board is P9 on the chip.
  • Compression lib
    library compression
    I am facing a challenge when attempting to decompress data compressed using the miniz library on the ESP32 platform. My objective is to compress data using miniz library in flasher_stub compoment of esp-idf and then decompress the data on the cloud side using some python script that can be compatible with miniz decompression style like zlib. As per the documentation and information available, the miniz library is described as a "lossless, high-performance data compression library" that implements the zlib (RFC 1950) and Deflate (RFC 1951) compressed data format specification standards. However, I am encountering difficulties when attempting to decompress the compressed data using Python. Specifically, when using the Python zlib module, which should be compatible with the zlib and Deflate formats, I am receiving an "unknown compression method" error. I have verified that the file and data are correct, and they were compressed using the miniz library on the ESP32. Despite this, I am unable to successfully decompress the data. I would greatly appreciate any help or any insights that you can provide regarding how to properly decompress data that has been compressed with the miniz library using Python.
  • Connect to wifi
    @ErickM said in Connect to wifi: VS say missing imports VS do not know pycom libraries at all, so do not worry.
  • Connection between pycom and arduino
    @Andres-Ortega You can set up the lopy4 as WiFi AP and connect it with the Arduino. Then you can do socket level data exchange. That's easy with the LoPy4, and some more work with the Arduino. But there should be many examples to go for. You could as well set up a MQTT server in your network (any PC, RPi, etc will do) and use it by both the LoPy4 and Arduino for data exchange.
  • Lorawan ABP problems L04
  • Cannot connect BLE in LoPy
    It says OSError: connection refused after trying to connect with connect(adv.mac)
  • light sleep and uart
    @Alessandro-Cortese There is no way implemented to stop machine.sleep().
  • L04 Lorawan ABP
  • L04 ABP LoraWan problems
    @Pedro-Almeida I can replicate this behavior. But there is little that canbe done in the uftpd code, since it does not get noticed. For uftpd, the session continues to exist.
  • uart 1 and 2 L04 module
    @Alessandro-Cortese That's how it is implemented. It is not the init call, it is the constructor. if you call: uart2 = UART(2, 115200) # init with given baudrate the default pins for UART 2 are used. These are P3 and P4, which are then deassigned from UART 1. Putting all settings into the constructor call avoids that pitfall, and it is shorter code.
  • Cannot access LoPy4 after connecting using UART, which has not enable
    @Jorge-Romero So that's the configuration for COM4, which seems to be used with the LoPy4. If you say "without expansion board", you must have used another USB/UART converter.
  • Dead pygo2
  • Connect to BLE device using random adddress type
    ble connect random
    @jmarcelino Just checking if this is resolved. I am still not able to connect to BLE device when using Bluetooth.RANDOM_ADDR.
    @balefire I agree - the PyCom user experience is terrible. So many gaps in the documentation, the main effort is reverse engineering what to do from everyone's failures - no clear "how to" guidance that is actually accurate / complete. Its a shame - gut feel; pycom could have been a game changer, but will die a slow death due to too closely guarded "secrets" which only serve to hinder the developers and product users.
  • LoPy4 change uplink channels by itself?
    31
    Gusti Made Arya WijayaG
    @robert-hh Okay thanks, I will try this firmware, and test lora.remove_channel(i), then add channel AS923-2 freqs (921.4MHz & 921.6MHz ).
  • Nice method to check if SD-card is removed
    @Steven-Boonstoppel said in Nice method to check if SD-card is removed: Expansion Board v3 I do not use Expansion Board so cannot help
  • Difficulties finding microSD card (Expansion Board v3)
    @robert-hh thanks! I had read that somewhere momentarily and disconnected pin 23, but it was still pulled from software as a deepsleep wakeup pin. So removing the jumper was not enough. Moved the pin and it works now, thanks!
