FiPy firmware upgrade failed - Cat M1
@rskoniec We haven't received our cat-M1 SIM card yet. Do you think I can try with a regular SIM ?
In this video tutorial : https://core-electronics.com.au/tutorials/pycom-gpy-fipy-cellular-lte-firmware-update.html
it seems he hasn't put a sim card in it. Weird. Or the video is a bit outdated maybe. -
@arnaudp I've started a forum chat with you. Can we continue there?
@rskoniec Sure, thanks :)
@Xykon When I was helping @ArnaudP to resolve the problem with FiPy modem f/w update (
sqnsupgrade.run('/sd/CATM1-version.dup', '/sd/updater.elf')) from initial release, we went this path:- upgraded FiPy from
1.10.0.b1to the latest stable1.18.1.r4 - on FiPy
1.18.1.r4modem f/w upgrade to the newestCATM1-39529failed - on FiPy
1.18.1.r4modem f/w upgrade to previousCATM1-38638failed - downgraded FiPy from
1.18.1.r4to1.18.1.r1 - on FiPy
1.18.1.r1modem f/w upgrade toCATM1-38638successful now I'm waiting for @ArnaudP feedback about modem f/w upgrade toCATM1-39529on FiPy1.18.1.r4- @ArnaudP has confirmed that after previous step, modem f/w upgrade to
CATM1-39529on FiPy1.18.1.r4was successful
What I've noticed is that
updater.elffile in the previous CAT-M1/NB1 releases is the same and with a size of aprox. 300KB, but for the latest they are different for CAT-M1 (420KB) and NB1 (364KB). I've been told by @ArnaudP that he had already sent you a message. - upgraded FiPy from
This post is deleted! -
I am on the same page with version r4:
>>> import os >>> from machine import SD >>> sd=SD() >>> os.mount(sd,'/sd') >>> os.listdir('/sd') ['upgdiff_38638-to-39529.dup', 'CATM1-39529.dup', 'upgdiff_33080-to-39529.dup', 'updater.elf'] >>> import sqnsupgrade >>> sqnsupgrade.run('/sd/CATM1-39529.dup', '/sd/updater.elf') <<< Welcome to the SQN3330 firmware updater [1.2.0] >>> >>> FiPy with firmware version 1.18.1.r4 Attempting AT wakeup... Session opened: version 1, max transfer 8192 bytes Sending 55498 bytes: [########################################] 100% Received ERROR from AT+SMSWBOOT=0,1! Aborting! Unable to upgrade bootrom. Unable to load updater from /sd/updater.elfPlease advise on how I may be able to downgrade to 1.18.1.r1, so I may be successful....per post below.
@dda Download 1.18.1.r1 from here https://software.pycom.io/downloads/FiPy-1.18.1.r1.tar.gz and downgrade using Pycom Firmware Upate tool with
flash from local fileoption. -
@arnaudp I've been attempting to update the modem from UART no SD card. Haven't been able to do it.
@rskoniec Thanks for these detailed instructions. I've followed them and no longer get the Aborting error, however the process seems to fail:
>>> sqnsupgrade.run('/sd/CATM1-38638.dup','/sd/updater.elf') <<< Welcome to the SQN3330 firmware updater >>> Attempting AT wakeup... Starting STP (DO NOT DISCONNECT POWER!!!) Session opened: version 1, max transfer 8192 bytes Sending 54854 bytes: [########################################] 100% Bootrom updated successfully, switching to upgrade mode Attempting AT auto-negotiation... ERROR sending AT command... no response? b'' AT auto-negotiation failed! Exiting. Unable to load updater from /sd/updater.elfAny suggestions?
Thanks!
