    Method To Take Control of Cell Modem
    41 Posts 10 Posters 923 Views 14 Watching
      tlanier
      Here's some of the higher level code that uses the modem module.
      import globals as g
      import modem
      from poll import poll
      import sys
      import uos
      import util
      from util import log
      from utime import sleep_ms
      import wifi
      #                         Communication Task
      def com_task():
          try:
              sleep_ms(500)
              log("com_task: started")
              wifi.deinit()
              modem.reset_modem()
              modem.init_modem()
              g.poll_host = True      # triggers poll at startup
          except Exception as ex:
              sys.print_exception(ex)
              try:
                  if modem_ready():
                      if ready_to_poll():
                          modem.set_apn()
                          transmit()
                  sleep_ms(2000)
      #                           Modem Ready
      def modem_ready():
          try:
              log("** check for modem ready")
              # get modem signal strength
              g.oStatus.cell_signal = modem.signal_strength()
              # check modem registration
              r = modem.check_registration()
              if (r == 1) or (r == 5):
                  # registered
                  g.com_secs = 0
                  # handle SMS messages
                  r = modem.sms_read()
                  if len(r) > 1:
                      modem.sms_process(r)
                      modem.sms_delete()
                  return True
              reset = False
              if g.com_secs > (10*60):
                  # unable to attach in 10 mins, try resetting modem
                  reset = True
              if modem.restarted():
                  # modem has crashed / restarted, try resetting modem
                  reset = True
              if reset:
                  modem.reset_modem()
                  modem.init_modem()
                  g.com_secs = 0
              return False
          return False
        tlanier @peterp
        @peterp Sorry to take so long to respond. I wanted to finish updating my posts showing the new code that seems to be working well. Soon I should be able to post the entire refined code. Maybe it will help others with the same problems we have had.
        The reason I went down this development path was as described originally:
        "I currently have a program working in production using Pycom MicroPython V1.20.0.rc13 on many units. When I try to run the same program on a newly purchased GPy running Pycom MicroPython 1.20.2.r3, the program crashes (20 sec watchdog timeout) when I do an AT command ('AT+CEREG?') after disconnecting from a successful transmission. How do I troubleshoot such a crash?"
        Our original reason for picking Pycom and GPy was the thinking that all the modem complexity would be handled by the high level LTE module. It's only a guess but our thinking that since the crashes always happened during times communicating with the modem, the LTE module was the likely source of the problem.
        The new method seems to be superior from the standpoint of interference with multiple tasks. Since we always call non-blocking uart commands, the code should never get hung in the C code for any period. A simple example of the LTE module code freezing multi-tasking is to do a simple modem reset. Reading and writing to the file storage also has a minor affect. The real reason for the development was to try to eliminate program crashes. Only longer term testing will show whether we have achieved that goal.
        One concern I do have is whether I am properly initializing the cell modem. Any input from anybody out there that is more familiar with properly setting up the LTE modem would be appreciated. It seems to work fine at this point; however, I'm not sure whether it's working because the GPy I'm testing with has run the LTE initialization at some point in the past and that has possibly setup the non-volatile memory of the modem to the proper settings that are needed.
        One drawback of using this method of transmission is it is not compatible with WIFI connections. That is not an issue for us at this time. Maybe later we can research how to do some form of communication that is compatible with both WIFI and direct AT commands. I assume that involves using the socket commands of the modem, but this is an area I'm not sure about at this time.
        • K Offline
          kjm @tlanier
          @tlanier Admire your efforts squire. I've been struggling with lte for a year or so now. It's not perfect (the lte.isattached() gets confused sometimes) but I got it robust enough to be usable. I use the requests library for data transfer & my main complaint is that it can't be timed out. I modified it with machine.WDT so that I can abort in a timely manner but I'd like a better solution. Am I right in thinking your wait_rx(n, 10000) allows you to quit if http post/get times out after 10s?
          T 3 Replies Last reply Reply Quote 0
            tlanier @kjm
            @kjm I think I remember having to modify urequests also. Here's what I currently use in my old version that is working.
            import usocket
            import util
            class Response:
                def __init__(self, f):
                    self.raw = f
                    self.encoding = "utf-8"
                    self._cached = None
                def close(self):
                    if self.raw:
                        self.raw.close()
                        self.raw = None
                    self._cached = None
                @property
                def content(self):
                    if self._cached is None:
                        try:
                            self._cached = self.raw.read()
                        finally:
                            self.raw.close()
                            self.raw = None
                    return self._cached
                @property
                def text(self):
                    return str(self.content, self.encoding)
                def json(self):
                    import ujson
                    return ujson.loads(self.content)
            def request(method, url, data=None, json=None, headers={}, stream=None):
                try:
                    proto, dummy, host, path = url.split("/", 3)
                except ValueError:
                    proto, dummy, host = url.split("/", 2)
                    path = ""
                if proto == "http:":
                    port = 80
                elif proto == "https:":
                    import ussl
                    port = 443
                    raise ValueError("Unsupported protocol: " + proto)
                if ":" in host:
                    host, port = host.split(":", 1)
                    port = int(port)
                # ai = usocket.getaddrinfo(host, port, 0, usocket.SOCK_STREAM)  # PATCH
                ai = usocket.getaddrinfo(host, port)
                ai = ai[0]
                s = usocket.socket(ai[0], ai[1], ai[2])
                try:
                    s.settimeout(20)
                    s.connect(ai[-1])
                        s = ussl.wrap_socket(s, server_hostname=host)
                    s.write(b"%s /%s HTTP/1.0\r\n" % (method, path))
                    if not "Host" in headers:
                        s.write(b"Host: %s\r\n" % host)
                    # Iterate over keys to avoid tuple alloc
                    for k in headers:
                        s.write(k)
                        s.write(b": ")
                        s.write(headers[k])
                        s.write(b"\r\n")
                    if json is not None:
                        assert data is None
                        import ujson
                        data = ujson.dumps(json)
                        s.write(b"Content-Type: application/json\r\n")
                    if data:
                        s.write(b"Content-Length: %d\r\n" % len(data))
                    s.write(b"\r\n")
                    if data:
                        s.write(data)
                    l = s.readline()
                    #print(l)
                    l = l.split(None, 2)
                    status = int(l[1])
                    reason = ""
                    if len(l) > 2:
                        reason = l[2].rstrip()
                        l = s.readline()
                        if not l or l == b"\r\n":
                            break
                        #print(l)
                        if l.startswith(b"Transfer-Encoding:"):
                            if b"chunked" in l:
                                raise ValueError("Unsupported " + l)
                        elif l.startswith(b"Location:") and not 200 <= status <= 299:
                            raise NotImplementedError("Redirects not yet supported")
            #   except OSError:     # PATCH
                except:
                    s.close()
                    raise
                resp = Response(s)
                resp.status_code = status
                resp.reason = reason
                return resp
            def head(url, **kw):
                return request("HEAD", url, **kw)
            def get(url, **kw):
                return request("GET", url, **kw)
            def post(url, **kw):
                return request("POST", url, **kw)
            def put(url, **kw):
                return request("PUT", url, **kw)
            def patch(url, **kw):
                return request("PATCH", url, **kw)
            def delete(url, **kw):
                return request("DELETE", url, **kw)
              tlanier @kjm
              @kjm Thanks for the comment. The intention of wait_rx(n, timeout=10000) is to be a non-blocking call that waits for N chars to come into the uart or to timeout after 10,000 msecs by default. N should be less than the buffer size of the uart which is currently set to 512 bytes.
              In looking at my current code, I see a bug. I should have had a sleep command in the while loop to make multi-tasking more efficient. Here's the corrected code. Thanks again!
              #                       Wait For N Received Chars
              def wait_rx(n, timeout=10000):
                  # timeout in msecs
                  t0 = ticks_ms()
                      if uart.any() >= n:
                          break
                      t1 = ticks_ms()
                      tx = ticks_diff(t1, t0)
                      if tx > timeout:
                          return False
                      sleep_ms(10)
                  return True
                tlanier @kjm
                @kjm What would really be neat is if we could learn how to put the modem in a mode that allowed the urequests/usockets libraries to work using just AT commands!
                I suspect it has to do with the AT+CGDCONT parameter named PDP_type. The manual shows the following values:
                X.25 ITU-T/CCITT X.25 layer 3 (Obsolete)
                IP Internet Protocol (IETF STD 5 [103])
                IPV6 Internet Protocol, version 6 (see RFC 2460 [106])
                IPV4V6 Virtual <PDP_type> introduced to handle dual IP stack UE capability. (See
                3GPP TS 24.301 [83])
                OSPIH Internet Hosted Octect Stream Protocol (Obsolete)
                PPP Point to Point Protocol (IETF STD 51 [104])
                Non-IP Transfer of Non-IP data to external packet data network (see 3GPP TS 23.401
                This is an area I'm unsure about. I would welcome comments from others about what would need to be done.
                  tlanier
                  Here's updated code that is now running on two units overnight with good success. The code handles unsolicited responses gracefully. The code is non-intrusive to other multi-tasking threads. The code has not crashed (more testing to be done for sure). The code is easy to understand; everything is there to see and improve (no hidden commands being sent to the modem).
                  # MODEM.PY Module
                  import globals as g
                  from machine import UART
                  import micropython
                  import sys
                  import util
                  from utime import sleep_ms, ticks_ms, ticks_diff
                  uart = None
                  #                     Send AT Command To Modem
                  def at(cmd, filterx=""):
                      try:
                          if uart.any() > 0:
                              # get unsolicited modem response
                              a = at_response()
                              for s in a:
                                  at_process(s)
                          log("  modem command: {}".format(cmd))
                          # send command to modem
                          n = uart.write(cmd + '\r')
                          if n != len(cmd) + 1:
                              log("error sending command to modem: n = {}".format(n))
                              return []
                          a = at_response(filterx)
                          return a
                          a = []
                      return a    # return modem response lines in array
                  #                     Filter Modem Response
                  def at_filter(a, filterx):
                      # a is passed as reference value
                      if filterx == "":
                          return
                      # filter response
                      n = len(filterx)
                      i = len(a)
                      while i > 0:
                          i = i - 1
                          if a[i][0:n] != filterx:
                              # remove lines that do not start with filter value
                              at_process(a[i])
                              a.pop(i)
                  #                     Process Unsolicited Response
                  def at_process(s):
                      if s == 'OK':
                          pass
                          log("unsolicited modem response: {}".format(s))
                      return
                  #                       Get AT Command Response
                  def at_response(filterx=""):
                      try:
                          t0 = ticks_ms()
                              if uart.any() > 0:
                                  # insure entire response has been received
                                  sleep_ms(50)
                                  break
                              t1 = ticks_ms()
                              if tx > 10000:
                                  log("timeout error - no modem response after 10 secs")
                                  return []
                              sleep_ms(100)
                          b = uart.read()
                          s = str(b, 'utf-8')
                          a = s.split('\r\n')
                          a = list(filter(None, a))
                          log("  modem response: {}".format(a))
                          a = []
                  #             Attach Cellular Modem To Packet Domain Service
                  def attach():
                      try:
                          log("attach modem to packet domain service")
                          a = at('AT+CGATT=1','OK')
                          if len(a) == 0:
                              log("error attaching modem")
                  #                       Check Registration
                  def check_registration():
                      # return 0-5, 99-unknown
                      # response: ['+CEREG: 2,4', 'OK']
                      # response: ['+CEREG: 2,1,"2C29","0B54400F",7', 'OK']
                      # 2,0 - not registered, not searching
                      # 2,1 - registered, home network
                      # 2,2 - not registered, searching
                      # 2,3 - registration denied
                      # 2,4 - unknown (out of coverage)
                      # 2,5 - registered, roaming
                      try:
                              log("check registration")
                              a = at('AT+CEREG?','+CEREG:')
                              if len(a) == 0:
                                  break
                              a = a[0].split(",")
                              if (a[0] != "+CEREG: 2"):
                                  break
                              reg = int(a[1])
                              if reg == 1:
                                  log("registered - home network")
                              elif reg == 5:
                                  log("registered - roaming")
                                  log("not registered")
                              return reg
                          log("check registration exception")
                      # unknown registration
                      log("error checking registration")
                      return 99
                  #             Detach Cellular Modem From Packet Domain Service
                  def detach():
                      # modem does not get SMS messages while the modem is detached
                      # old messages received while detached are only received when a new message is sent while attached
                      try:
                          log("detach modem from packet domain service")
                          a = at('AT+CGATT=0','OK')
                          if len(a) == 0:
                              log("error detaching modem")
                  #                       Disable LTE Modem
                  def disable_modem():
                      try:
                          log("disable modem")
                          a = at('AT+CFUN=0','OK')     # minimum functionality
                          if len(a) == 0:
                              log("error disabling modem")
                  #                       Enable Modem
                  def enable_modem():
                      try:
                          log("enabling modem")
                          a = at('AT+CFUN=1','OK')     # full functionality
                          if len(a) == 0:
                              log("error enabling modem")
                  #                Get CFUN - Modem Level of Functionality
                  def get_cfun():
                      # 0 - minimum functionality
                      # 1 - full functionality
                      # 4 - radios disabled but access to SIM allowed
                      # -1 - unknown
                      # note: if modem does +SHUTDOWN/+SYSSTART, CFUN will be reset to 0
                      try:
                              a = at('AT+CFUN?','+CFUN:')
                              # response: ['+CFUN: 1', 'OK']
                              if len(a) == 0:
                                  break
                              cfun = int(a[0][7])
                              return cfun
                      return -1
                  #                           Get SMS Mode
                  def get_sms_mode():
                      # return 0-PDU mode or unknown, 1-text mode
                      try:
                          log("get SMS mode")
                          a = at('AT+CMGF?','+CMGF:')
                          # response: ['+CMGF: 1', 'OK']
                          if len(a) == 0:
                              return 0    # mode unknown
                          mode = int(a[0][7])
                          return mode
                  #                            HTTP Post
                  def http_post(uri, header, tx_data):
                      # --> AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                      # xx> POST <uri> HTTP/1.1
                      # xx> <header>
                      # xx> Content-Length: <tx_size>
                      # xx> Content-Type: application/octet-stream
                      # xx> <blank line>
                      # --> <tx_data bytes>
                      # <-- OK
                      # <-- +SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<rx_size>
                      # --> AT+SQNHTTPRCV=1,0\r
                      # <-- /r/n<<<
                      # <-- <rx_data bytes>
                      # <-- OK
                      try:
                          log("HTTP post")
                              # note: init_modem() sets configuration "AT+SQNHTTPCFG=..." at startup
                              tx_size = len(tx_data)
                              # log("writing message: {0}".format(tx_data))
                              log("tx_data length: {0}".format(tx_size))
                              # AT+SQNHTTPSND=<prof_id>,<command>,<resource>,<data_len>[,<post_param>[,<extra_header_line>]]
                              # prof_id=1, command=0 (POST), <uri>, <tx_size>, post_parm="2" (application/octet-stream), header="Host: <host_name>"
                              a = at('AT+SQNHTTPSND=1,0,"{0}",{1},"2","{2}"'.format(uri, tx_size, header),'> ')
                              if len(a) == 0:
                                  break   # error
                              uart.write(tx_data)
                              a = at_response('OK')
                              if len(a) == 0:
                                  break   # error
                              # modem responds with "+SQNHTTPRING: <prof_id,<http_status_code>,<content_type>,<data_size>"
                              a = at_response("+SQNHTTPRING:")
                              if len(a) == 0:
                                  break   # error
                              a = a[0].split(",")
                              http_status_code = int(a[1])
                              if http_status_code != 200:
                                  break   # error
                              rx_size = int(a[3])
                              log("rx_data length: {0}".format(rx_size))
                              # get response
                              cmd = 'AT+SQNHTTPRCV=1,0\r'
                              log("  modem command: {0}".format(cmd))
                              uart.write(cmd)
                              r = wait_rx(5, 10000)   # wait for b'\r\n<<<'
                              if r == False:
                                  break   # error
                              b = uart.read(5)
                              # log(" modem response: {0}".format(b))
                              if b[2:5] != b'<<<':
                                  break   # error
                              t0 = ticks_ms()
                              b = b''
                              n = rx_size     # no. bytes remaining to be read
                                  if uart.any() > 0:
                                      log("attempt to read {0} bytes".format(n))
                                      bx = uart.read(n)
                                      log("bytes read: {0}".format(len(bx)))
                                      # log(" modem response: {0}".format(bx))
                                      b = b + bx
                                      if len(b) == rx_size:
                                          break   # entire message received
                                      n = rx_size - len(b)
                                      t0 = ticks_ms()     # reset timeout
                                  t1 = ticks_ms()
                                  if tx > 10000:
                                      log("timeout error receiving response")
                                      return b''
                                  sleep_ms(400)
                              log("total bytes read: {0}".format(len(b)))
                              # log(" post response: {0}".format(b))
                              if len(a) == 0:
                                  break   # error
                              # log(b)
                              return b
                      # error
                      return b''
                  #                     Get SIM Card ICCID Number
                  def iccid():
                      # CFUN must be 1 or 4
                      try:
                          log("get SIM card ICCID")
                          a = at('AT+SQNCCID?','+SQNCCID:')
                          # example response: ['+SQNCCID: "89014103271203065543",""', 'OK']
                          if len(a) == 0:
                              return ''
                          a = a[0].split(",")
                          n = len(a[0])
                          r = a[0][11:n-1]
                          r = ''
                      log("ICCID = {0}".format(r))
                      return r    # ICCID as string
                  #                       Get Modem IMEI Number
                  def imei():
                      try:
                          log("get modem IMEI number")
                          a = at('AT+CGSN=1','+CGSN:')
                          # example response: ['+CGSN: "354347094028575"', 'OK']
                          if len(a) == 0:
                              return ''
                          n = len(a[0])
                          r = a[0][8:n-1]
                          r = ''
                      log("IMEI = {0}".format(r))
                      return r    # IMEI as string
                  #                       Initialize Modem
                  def init_modem():
                      try:
                          log("initializing modem")
                          if uart == None:
                              init_uart()
                          disable_modem()
                          # set profile #1 parameters for HTTP connection
                          # prof_id=1 (profile), ip, port, auth_type=0 (None), username="", password="",
                          # ssl_enabled=0, timeout, cid=1 (PDN Context Identifier)
                          server = g.oIni.host_ip     # note: host_name could also be used (auto DNS lookup)
                          port = g.oIni.host_port
                          timeout = 10    # secs to wait for response from server
                          cmd = 'AT+SQNHTTPCFG=1,"{0}",{1},0,"","",0,{2},1'.format(server, port, timeout)
                          a = at(cmd,'OK')
                          if len(a) == 0:
                              log("error initializing modem")
                          set_sms_mode()
                          enable_modem()
                  #               Initialize Uart Connected To LTE Modem
                  def init_uart():
                      global uart
                      # pins=(TXD, RXD, RTS, CTS)
                      # FiPy: pins=('P20', 'P18', 'P19', 'P17')
                      # GPy:  pins=('P5', 'P98', 'P7', 'P99')
                      log("initializing UART")
                      # rx_buffer_size: must be > 127, 200000 works, 250000 crashes, http_post seems to work with any size
                      uart = UART(1, baudrate=921600, bits=8, parity=None, stop=1, timeout_chars=2, pins=('P5', 'P98', 'P7', 'P99'), rx_buffer_size=512)
                  #           Is Cellular Modem Attached To Packet Domain Service
                  def isattached():
                      # returns: True/False
                      try:
                          a = at('AT+CGATT?','+CGATT:')
                          # example response: ['+CGATT: 0', 'OK']
                          if len(a) == 0:
                              return False
                          if a[0][8] == '1':
                              return True
                      return False
                  #                           Reset Modem
                  def reset_modem():
                      try:
                          if uart == None:
                              init_uart()
                          log("reseting modem...")
                          a = at('AT^RESET','+SHUTDOWN')
                          # generates +SHUTDOWN ... +SYSSTART responses
                          if len(a) == 0:
                              log("error resetting modem - no +SHUTDOWN")
                          a = at_response('+SYSSTART')
                          if len(a) == 0:
                              log("error resetting modem - no +SYSSTART")
                  #                  Check Modem For Restart/Crash
                  def restarted():
                      # return True if modem has crashed / restarted
                      try:
                          # if CFUN != 1, modem has crashed / restarted
                          cfun = get_cfun()
                          if cfun != 1:
                              return True
                          # if SMS text mode is reset to zero, modem has crashed / restarted
                          mode = get_sms_mode()
                          if mode != 1:
                              return True
                          return False
                      return True
                  #                           Set APN
                  def set_apn():
                      try:
                          log("set APN")
                          # ICCID is only valid after registration
                          r = iccid()[0:5]
                          if r == "89014":
                              apn = g.oIni.apn_89014   # Kore AT&T SIM
                          elif r == "89012":
                              apn = g.oIni.apn_89012   # Kore T-Mobile SIM
                          elif r == "89445":
                              apn = g.oIni.apn_89445   # Hologram SIM
                          g.oIni.apn = apn
                          log("APN: {0}".format(apn))
                          # try to reduce wear of non-volatile memory
                          a = at('AT+CGDCONT?','+CGDCONT:')
                          # response --> ['+CGDCONT: 1,"IP","10569.mcs",,,,0,0,0,0,0,0', ...]
                          if len(a) > 0:
                              a = a[0].split(",")
                              if (a[0] == '+CGDCONT: 1') and (a[1] == '"IP"') and (a[2] == '"'+apn+'"'):
                                  return
                          # apn needs setting
                          cmd = 'AT+CGDCONT=1,"IP","{0}"'.format(apn)
                          a = at(cmd,'OK')
                          if len(a) == 0:
                              log("error setting APN")
                  #                       Set SMS Mode To Text
                  def set_sms_mode():
                      try:
                          log("set SMS mode to text")
                          a = at('AT+CMGF=1','OK')     # set SMS mode to text
                          if len(a) == 0:
                              log("error setting SMS mode to text")
                  #                       Get Signal Strength
                  def signal_strength():
                      # 0-31, 99-unknown
                      try:
                              log("check signal strength")
                              a = at('AT+CSQ','+CSQ:')
                              # example response: ['+CSQ: 18,99', 'OK'] where 18 is signal strength
                              if len(a) == 0:
                                  break
                              n = len(a[0])
                              s = a[0][6:n-1]
                              a = s.split(",")
                              cell_signal = int(a[0])
                              g.oStatus.cell_signal = cell_signal
                              log("signal strength = {0}".format(cell_signal))
                              return cell_signal
                      # unknown signal strength
                      g.oStatus.cell_signal = 99
                      log("signal strength unknown")
                      return 99
                  #             Delete Read, Sent, and Unsent SMS Messages
                  def sms_delete():
                      try:
                          log("delete all READ, SENT, and UNSENT SMS messages")
                          a = at('AT+CMGD=1,3','OK')
                          if len(a) == 0:
                              log("error trying to delete read, sent, and unsent SMS messages")
                  #                     Delete All SMS Messages
                  def sms_delete_all():
                      # doesn't work until some time after attach() is called
                      try:
                          log("delete all SMS messages")
                          a = at('AT+CMGD=1,4','OK')
                          if len(a) == 0:
                              log("error trying to delete all SMS messages")
                  #                     Process SMS Messages
                  def sms_process(r):
                      # example response:
                      # ['+CMGL: 1,"REC READ","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', '+CMGL: 2,"REC READ","+1xxxxxxxxxx",,"19/01/07,11:12:30-20"', 'Test4', 'OK']
                      try:
                          for m in r:
                              if (m[0:5] == "+CMGL"):
                                  continue
                              a = m.split("=")
                              cmd = a[0].upper()
                  #                      Read Unread SMS Messages
                  def sms_read():
                      # response example: ['+CMGL: 1,"REC UNREAD","+1xxxxxxxxxx",,"19/01/07,09:16:53-20"', 'Test3', 'OK']
                      log("read unread SMS messages")
                      a = at('AT+CMGL="REC UNREAD"')
                      return a
                  #                       Read All SMS Messages
                  def sms_read_all():
                      # response example:
                      log("read all SMS messages")
                      a = at('AT+CMGL="ALL"')
                      return a
                      # timeout in msecs
                      t0 = ticks_ms()
                          if uart.any() >= n:
                              break
                          t1 = ticks_ms()
                          if tx > timeout:
                              return False
                          sleep_ms(10)
                      return True
                  Here's the code being used. The code shown is incomplete since it is application dependent. I'm somewhat disappointed in the necessary placement of the modem.apn_set() call. This may change in the future.
                  # COM.PY Module
                  import globals as g
                  import modem
                  import sys
                  import uos
                  import util
                  import wifi
                  def com_task():
                      try:
                          sleep_ms(500)
                          wifi.deinit()
                          modem.reset_modem()
                          modem.init_modem()
                          try:
                              if modem_ready():
                                  if ready_to_poll():
                                      modem.set_apn()
                                      transmit()
                              sleep_ms(2000)
                  #                           Modem Ready
                  def modem_ready():
                      try:
                              # registered
                              g.com_secs = 0
                              if len(r) > 1:
                                  modem.sms_delete()
                              return True
                          reset = False
                              reset = True
                              reset = True
                          if reset:
                              modem.reset_modem()
                              modem.init_modem()
                              g.com_secs = 0
                          return False
                      return False
                    tlanier
                    I seemed to have hit a major problem using the AT+SQNHTTPSND modem command. Although the manual does not state this, the maximum size of the data posted is apparently 1500 bytes.
                    If anyone has ideas of how to increase this, please let me know. Unfortunately my app requires posting messages over 3000 bytes.
                    Disappointed...
                      tlanier
                      I've now converted my code to use the Sequans modem socket commands in command mode (not on-line mode). I first tried to use the on-line mode, but ran into issues (no good way I could find to prevent overrunning tx buffer). This code resolves the 1500 byte limitation I ran into using the HTTP modem commands. There's still some cleanup to do to make the code more robust; however, it is working with large transmit and receive data blocks now.
                      During development while I had coding errors and the program would terminate abnormally, I did put the modem in a mode that I couldn't recover from without power cycling the GPy. The modem would not response to AT commands, Trying to do lte = LTE() would generate the following error (OSError: Couldn't connect to Modem (modem_state=disconnected)). Doing machine.reset() would not correct the problem.
                      Link to discussion of similar problem on Github
                      Hopefully whatever I did to cause the problem will not occur in debugged code. There needs to be a true hardware reset of the modem. It seems that a GPIO pin should be tied to a physical reset line going to the modem that we could pulse if needed. I'm also of the opinion that the watchdog timer in the GPy should have been a hardware circuit not dependent on software to work.
                      So far I have not seen any unexplained crashes while running the code.
                      This code has been added to my modem.py module.
                      #                       Socket Close
                      def socket_close():
                          # socket close
                          # connID = 1 --> socket connection identifier
                          a = at('AT+SQNSH=1', 'OK')
                          if len(a) == 0:
                              log("error closing connection")
                              return
                      #                       Socket Connect
                      def socket_connect(ip, port, timeout_secs=10):
                          # returns: True if connection successful
                          log("connecting to ip - {0}, port - {1}".format(ip, port))
                          # make sure socket is closed
                          socket_close()
                          # socket configuration
                          # cid = 1 --> PDP context identifier
                          # pktSz = 1500 --> packet size
                          # maxTo = 10 --> exchange timeout in secs
                          # connTo = 600 --> connection timeout in msecs
                          # txTo = 3 --> data sending timeout in hundreds of msecs
                          # a = at('AT+SQNSCFG=1,1,1500,10,600,3', 'OK')
                          a = at('AT+SQNSCFG=1,1,1500,{0},600,3'.format(timeout_secs), 'OK')
                          if len(a) == 0:
                              log("error connecting")
                              return False
                          # socket extended configuration
                          # srMode = 1 --> SQNSRING URC data amount mode
                          # recvDataMode = 1 --> data in hex
                          # keepalive = 0 --> unused
                          # listenAutoRsp = 0 --> deactivated
                          # sendDataMode = 1 --> data in hex
                          a = at('AT+SQNSCFGEXT=1,1,1,0,0,1', 'OK')
                          if len(a) == 0:
                              return False
                          # socket dial
                          # txProt = 0 --> TCP protocol
                          # rPort = <port> --> remote host port to contact
                          # IPaddr = <ip> --> address of remote host
                          # closureType = 0 --> local host closes immediately when remote host has closed
                          # lPort = 0 --> UDP port (not used)
                          # connMode = 1 --> command mode connection
                          # acceptAnyRemote = 0 --> disabled
                          a = at('AT+SQNSD=1,0,{0},"{1}",0,0,1,0'.format(port,ip), 'OK')
                          if len(a) == 0:
                              return False
                          log("** connection successful **")
                          return True
                      #                       Socket Info
                      def socket_info():
                          # modem response: ['+SQNSI: 1,0,0,0,0', 'OK']
                          # connId: 1
                          # sent: total bytes sent
                          # received: total bytes received
                          # buff_in: total bytes not yet read (buffered)
                          # ack_waiting: total bytes sent but not yet acknowledged
                          a = at('AT+SQNSI=1')
                      #                       Socket Receive Data
                      def socket_rx():
                          # receives up to 1500 bytes maximum
                          log("check for rx data")
                          a = at('AT+SQNSRECV=1,1500')
                          # no data ready --> modem response: ['+CME ERROR: operation not supported']
                          # data ready --> modem response: ['+SQNSRECV: 1,3', '010203', 'OK']
                          b = b''
                          for i in range(len(a)):
                              if a[i].startswith('+SQNSRECV:'):
                                  # next line is the data
                                  b = unhexlify(a[i+1])
                          log("rx {0} bytes".format(len(b)))
                          return b
                      #                       Socket Status
                      def socket_status():
                          # modem response: ['+SQNSS: 1,0', '+SQNSS: 2,0', '+SQNSS: 3,0', '+SQNSS: 4,0', '+SQNSS: 5,0', '+SQNSS: 6,0', 'OK']
                          # connID
                          # state:
                          #   0-socket closed
                          #   1-socket with active data transfer connection
                          #   2-socket suspended
                          #   3-socket suspended with pending data
                          #   4-socket listening
                          #   5-socket with incoming connection
                          #   6-socket in opening process
                          a = at('AT+SQNSS?')
                          return a
                      #                       Socket Transmit Data
                      def socket_tx(tx, n=0):
                          # transmits up to 1500 bytes maximum
                          # returns: True if successful
                          if n == 0:
                              n = len(tx)
                          log("tx {0} bytes".format(n))
                          a = at('AT+SQNSSENDEXT=1,{0}'.format(n), '> ')
                          hex = hexlify(tx)
                          uart.write(hex)
                          if len(a) == 0:
                              log("error transmitting data")
                              return False
                          return True
                      This code is in my http.py module.
                      import modem
                      import sys
                      import ubinascii
                      import uos
                      import ustruct
                      import util
                      BUFFER_SIZE = const(1500)
                      CR = const(0x0d)
                      LF = const(0x0a)
                      MAX_HEADER_SIZE = const(128)
                      MAX_TX_SIZE = const(1500)
                      HTTP_TIMEOUT_MSECS = const(15000)
                      # HTTP_TIMEOUT_MSECS = const(300000)  # TESTING
                      http_error = False      # HTTP communication error: True/False
                      http_size = 0           # HTTP POST message size
                      rx_cnt = 0              # no. bytes in rx_data buffer
                      rx_data = b''           # rx data buffer
                      rx_pt = 0               # pointer into rx data buffer
                      tx_cnt = 0              # no. bytes in tx_data buffer
                      tx_data = bytearray(MAX_TX_SIZE)    # tx data buffer
                      tx_flag = False         # controls tx_byte
                      #                       Close HTTP Socket
                      def close_http():
                          modem.socket_close()
                      #                       Open HTTP Socket
                      def open_http(host_ip, host_port):
                          global http_error, rx_cnt, rx_data, rx_pt, tx_cnt
                          http_error = False
                          rx_cnt = 0
                          rx_data = b''
                          rx_pt = 0
                          tx_cnt = 0
                          r = modem.socket_connect(host_ip, host_port)
                          if r == False:
                              log("TCP socket connect error")
                              http_error = True
                      #                    Receive BLOCK From Response
                      def rx_block(cnt):
                          b = bytearray(cnt)
                          i = 0
                          while i < cnt:
                              b[i] = rx_byte()
                              i = i + 1
                          return b
                      #                    Receive BYTE From Response
                      def rx_byte():
                          global http_error, http_size, rx_cnt, rx_data, rx_pt
                          t0 = ticks_ms()
                          while rx_cnt == 0:
                              rx_data = modem.socket_rx()
                              rx_cnt = len(rx_data)
                              rx_pt = 0
                              if rx_cnt > 0:
                                  break
                              t1 = ticks_ms()
                              if (tx > HTTP_TIMEOUT_MSECS):
                                  http_error = True
                                  return 0
                              sleep_ms(200)
                          b = rx_data[rx_pt]
                          rx_cnt = rx_cnt - 1
                          rx_pt = rx_pt + 1
                          http_size = http_size - 1
                          # print("rx byte: {0}".format(hex(b)))
                          return b
                      #                    Receive DWORD From Response
                      def rx_dword():
                          dw1 = rx_byte()
                          dw2 = rx_byte()
                          dw3 = rx_byte()
                          dw4 = rx_byte()
                          return (dw1 + (dw2<<8) + (dw3<<16) + (dw4<<24))
                      #                    Receive One HTTP Header
                      def rx_http_header():
                          # returns header string
                          global http_error
                          n = 0
                          header = bytearray(MAX_HEADER_SIZE)
                          s = ""
                              b = rx_byte()
                              # print("byte = {0}".format(b))
                              if http_error:
                                  return ""
                              if b == CR:
                                  continue
                              if b == LF:
                                  break
                              header[n] = b
                              n = n + 1
                              if n >= MAX_HEADER_SIZE-1:
                                  http_error = True
                                  return ""
                          if n > 0:
                              # print("n = {0}, header = {1}".format(n,header))
                              s = header[0:n].decode('utf-8')
                          return s
                      #                    Receive HTTP Headers
                      # HTTP/1.1 200 OK
                      # <headers>
                      # Content-Length: nnn
                      # <headers>
                      # <crlf>
                      # Updates: http_size, http_error
                      def rx_http_headers():
                          headers = []      # array of header lines
                          http_size = 0
                              s = rx_http_header()
                              log("length = {0}, header = {1}".format(len(s), s))
                              if http_error:
                                  return headers
                              if s == "":
                                  break
                              headers.append(s)
                          if len(headers) < 2:
                              http_error = True
                              return headers
                          a = headers[0].split(' ')
                          if (a[1] != "200") or (a[2]) != "OK":
                              http_error = True
                              return headers
                          for s in headers:
                              if s.startswith("Content-Length:"):
                                  a = s.split(' ')
                                  http_size = int(a[1])
                          return headers
                      #                    Receive String From Response
                      def rx_string(max_len):
                          rx = bytearray(max_len)
                          i = 0
                          while i < max_len:
                              b = rx_byte()
                              if b == 0:
                                  break
                              rx[i] = b
                              i = i + 1
                          if i == 0:
                              return ""
                          s = rx[0:i].decode('utf-8')
                          return s
                      #                    Receive WORD From Response
                      def rx_word():
                          dw1 = rx_byte()
                          dw2 = rx_byte()
                          return (dw1 + (dw2<<8))
                      #                       Transmit Block
                      def tx_block(b):
                          for x in b:
                              tx_byte(x)
                      #                       Transmit Byte
                      def tx_byte(b):
                          global http_size, tx_cnt, tx_data, tx_flag
                          if tx_flag == False:
                              http_size = http_size + 1
                              # print("tx byte: {0}, http size: {1}".format(hex(b), http_size))
                              return
                          # print("tx byte: {0}".format(hex(b)))
                          tx_data[tx_cnt] = b
                          tx_cnt = tx_cnt + 1
                          if tx_cnt >= MAX_TX_SIZE:
                              tx_flush()
                      #                       Transmit DWORD
                      def tx_dword(dw):
                          tx_word(dw & 0xffff)
                          tx_word((dw >> 16) & 0xffff)
                      #                       Transmit Flush
                      def tx_flush():
                          global tx_cnt, tx_data
                          if tx_cnt == 0:
                              return
                          r = modem.socket_tx(tx_data, tx_cnt)
                          if not r:
                              http_error = True
                              return
                          tx_cnt = 0
                      #                       Transmit HTTP Headers
                      def tx_http_headers(http_post, host_name, host_port):
                          # example:
                          # POST <http_post> HTTP/1.1
                          # Host: <host_name>:<host_port>
                          # Content-Length: <http_size>
                          # Content-Type: application/octet-stream
                          # <crlf>
                          log("tx HTTP headers")
                          if http_error:
                              return
                          s = "POST {0} HTTP/1.1\r\n".format(http_post)
                          tx_string(s)
                          if host_port != 80:
                              s = "Host: {0}:{1}\r\n".format(host_name, host_port)
                              s = "Host: {0}\r\n".format(host_name)
                          tx_string(s)
                          s = "Content-Length: {0}\r\n".format(http_size)
                          tx_string(s)
                          s = "Content-Type: application/octet-stream\r\n"
                          tx_string(s)
                          s = "\r\n"
                          tx_string(s)
                      #                       Transmit String
                      def tx_string(s):
                          b = s.encode('utf-8')
                          for x in b:
                              tx_byte(x)
                      #                       Transmit WORD
                      def tx_word(w):
                          tx_byte(w & 0xff)
                          tx_byte((w >> 8) & 0xff)
                        tlanier
                        We now have our program running completely independent of the LTE module. 26 units have been running for multiple days with no crashes. I now think we have found a reliable solution. The Sequans modem AT socket commands are used to do the HTTP posts. We reliably receive 90K files and transmit 1-5K of data with no issues. Pycom MicroPython V1.20.0.rc13 is the OS version we are using.
                        Currently we are using whatever version of the modem firmware (41065, 43818, and 47510 have been seen) that comes with the GPy. The version of the OS we are using has the ability to "downgrade" the modem firmware to 41065 if we decide it is needed. Some newer versions of the OS do not have this ability.
                        One note of importance is we did discover that in our case the default stack size was marginal when receiving large files. Yes, I did go back and check the old program and verified that the stack issue was not the cause of the original crash problems.
                        #                          Initialize Tasks
                        def init_tasks():
                            n = 8192    # 4096 is marginal
                            _thread.stack_size(n)
                            log("initializing tasks with stack size: {}".format(n))
                            _thread.start_new_thread(com.com_task, ())
                            _thread.start_new_thread(cycle.cycle_task, ())
                        • R Offline
                          ruok4t @tlanier
                          @tlanier I really like the sound of what your doing here. I've been struggling with Pycom LTE module for months now. Really don't like the way it blocks other threads and randomly locks up for no apparent reason. Are you possibly in a position to share a complete "Hello LTE World" example. I'm sure I wouldn't be the only one around here who would be very interested. Hopefully someone from Pycom might also take an interest and finally admit they need to revise their code.
                            tlanier @ruok4t
                            @ruok4t Sorry I didn't see your request earlier.
                            The software below is now working in production units. We ran about 20 units testing in house for two weeks with no crashes before beginning deployment with the new version. We are using MicroPython V1.20.0.rc13 with multiple versions of the modem firmware. It's a shame we had to resort to this, but it seems to work reliably.
                            I've had to break the post up into 3 parts because of limitations of this forum.
                            Part 1 of 3
                            Here's the modem.py module:
                            import globals as g
                            import gpio
                            import micropython
                            import sys
                            import util
                            from ubinascii import hexlify, unhexlify
                            from util import log, mem_info
                            uart = None
                                try:
                                    # util.mem_info("modem.at")
                                    if uart.any() > 0:
                                        a = at_response()
                                        for s in a:
                                            at_process(s)
                                    if gpio.G():
                                        if gpio.G():
                                        return []
                                    return a
                                    a = []
                                # filter response
                                if filterx == "":
                                    return
                                n = len(filterx)
                                i = len(a)
                                while i > 0:
                                    i = i - 1
                                    if not a[i].startswith(filterx):
                                        at_process(a[i])
                                        a.pop(i)
                            def at_process(s):
                                if s == 'OK':
                                    return
                                if s.startswith("ERROR"):
                                    return
                                if s.startswith("+CME ERROR:"):
                                    return
                                # process unsolicited response here
                                if gpio.G():
                                    log("  unsolicited modem response: {}".format(s))
                                try:
                                    t0 = ticks_ms()
                                        if uart.any() > 0:
                                            sleep_ms(50)
                                            break
                                        t1 = ticks_ms()
                                        if tx > 10000:
                                            return []
                                        sleep_ms(100)
                                    b = uart.read()
                                    s = str(b, 'utf-8')
                                    a = s.split('\r\n')
                                    if gpio.G():
                                    a = []
                                try:
                                        if len(a) == 0:
                                            break
                                        a = a[0].split(",")
                                            break
                                        reg = int(a[1])
                                        if reg == 1:
                                            log("*** registered - home network ***")
                                        elif reg == 5:
                                            log("*** registered - roaming ***")
                                            log("*** NOT registered ***")
                                        return reg
                                return 99
                            #                       Check SIM Status
                            def check_sim_status():
                                try:
                                    log("checking SIM card status")
                                    a = at('AT+CPIN?', '+CPIN: READY')
                                    if len(a) > 0:
                                        return True
                                log("error SIM card not ready")
                                return False
                            #                       Disable LTE Modem
                                try:
                                    if len(a) == 0:
                            #                       Enable Modem
                            def enable_modem():
                                try:
                                    if len(a) == 0:
                            def get_cfun():
                                # -1 - unknown
                                try:
                                        if len(a) == 0:
                                            break
                                        cfun = int(a[0][7])
                                        return cfun
                                return -1
                            #                           Get SMS Mode
                            def get_sms_mode():
                                try:
                                    log("get SMS mode")
                                    if len(a) == 0:
                                    mode = int(a[0][7])
                                    return mode
                            def iccid():
                                # SIM status must be ready
                                try:
                                    a = at('AT+SQNCCID?', '+SQNCCID:')
                                    if len(a) == 0:
                                        return ''
                                    a = a[0].split(",")
                                    n = len(a[0])
                                    r = a[0][11:n-1]
                                    r = ''
                            def imei():
                                try:
                                    if len(a) == 0:
                                        return ''
                                    n = len(a[0])
                                    r = a[0][8:n-1]
                                    r = ''
                            #                   Modem Firmware Info
                            def info():
                                log("get modem firmware version")
                                a = at('ATI1')
                                return a
                            #                       Initialize Modem
                            def init_modem():
                                try:
                                    if uart == None:
                                        init_uart()
                                    info()
                                    set_sms_mode()
                                    # enable +CME ERROR: <err> result code and use verbose <err> values
                                    at('AT+CMEE=2')
                                    enable_modem()
                                    log("wait for SIM card ready")
                                    n = 0
                                        if len(a) > 0:
                                            break
                                        n = n + 1
                                        if n > 20:
                                            util.reset(13, "No SIM card")
                                        sleep_ms(200)
                                    set_apn()
                            def init_uart():
                                global uart
                            def isattached():
                                try:
                                    if len(a) == 0:
                                        return False
                                    if a[0][8] == '1':
                                        return True
                                return False
                            #                           Reset Modem
                            def reset_modem():
                                try:
                                    if uart == None:
                                        init_uart()
                                    a = at('AT^RESET', '+SHUTDOWN')
                                    if len(a) == 0:
                                    if len(a) == 0:
                            def restarted():
                                try:
                                    cfun = get_cfun()
                                    if cfun != 1:
                                        return True
                                    if mode != 1:
                                        return True
                                    return False
                                return True
                            #                           Set APN
                            def set_apn():
                                try:
                                    log("set APN")
                                    # ICCID is only valid if SIM status is ready
                                    r = iccid()[0:5]
                                    if r == "89014":
                                    elif r == "89012":
                                    elif r == "89445":
                                    g.oIni.apn = apn
                                    a = at('AT+CGDCONT?', '+CGDCONT:')
                                    if len(a) > 0:
                                        a = a[0].split(",")
                                            return
                                    # apn needs setting
                                    a = at(cmd, 'OK')
                                    if len(a) == 0:
                            def set_sms_mode():
                                try:
                                    a = at('AT+CMGF=1', 'OK')     # set SMS mode to text
                                    if len(a) == 0:
                                # 0-31, 99-unknown
                                try:
                                        a = at('AT+CSQ', '+CSQ:')
                                        if len(a) == 0:
                                            break
                                        n = len(a[0])
                                        s = a[0][6:n-1]
                                        a = s.split(",")
                                        return cell_signal
                                return 99
                            def sms_delete():
                                try:
                                    a = at('AT+CMGD=1,3', 'OK')
                                    if len(a) == 0:
                                try:
                                    a = at('AT+CMGD=1,4', 'OK')
                                    if len(a) == 0:
                            def sms_process(r):
                                # example response:
                                try:
                                    for m in r:
                                            continue
                                        a = m.split("=")
                                        cmd = a[0].upper()
                            			# process message here
                            def sms_read():
                                return a
                            def sms_read_all():
                                # response example:
                                return a
                            #                       Socket Close
                            def socket_close():
                                # socket close
                                log("closing socket")
                                if len(a) == 0:
                            #                       Socket Connect
                                socket_close()
                                if len(a) == 0:
                                    return False
                                if len(a) == 0:
                                    return False
                                # socket dial
                                if len(a) == 0:
                                    return False
                                return True
                            #                       Socket Info
                            def socket_info():
                                # connId: 1
                                log("socket info")
                            def socket_rx():
                                b = b''
                                return b
                            #                       Socket Status
                                # connID
                                # state:
                                #   0-socket closed
                                log("socket status")
                                a = at('AT+SQNSS?')
                                return a
                                if n == 0:
                                    n = len(tx)
                                b = hexlify(tx)
                                uart.write(b)
                                if len(a) == 0:
                                    return False
                                return True
                            T R 2 Replies Last reply Reply Quote 0
                              tlanier @tlanier
                              @tlanier
                              Part 2 of 3
                              Here's our com.py module. It is more application dependent but it may give you some ideas of how to use the modem module.
                              import globals as g
                              import modem
                              import sys
                              import uos
                              import util
                              import wifi
                              _reset = True    # modem reset
                              def com_task():
                                  global _reset
                                  try:
                                      sleep_ms(500)
                                      # this opens the door for continuous resets to cause high data usage
                                      util.set_ppp_errors(0)
                                      wifi.deinit()
                                      try:
                                          _reset = False
                                          g.modem_state = g.MS_RESET_MODEM
                                          modem.reset_modem()
                                          g.modem_state = g.MS_INIT_MODEM
                                          modem.init_modem()
                                          while _reset == False:
                                              # util.mem_info("com_task")
                                              if modem_ready():
                                                  g.modem_state = g.MS_REGISTERED
                                                  if ready_to_poll():
                                                      transmit()
                                                  g.modem_state = g.MS_REGISTERING
                                              sleep_ms(2000)
                              #                           Modem Ready
                              def modem_ready():
                                  global _reset
                                  try:
                                          # registered
                                          g.com_secs = 0
                                          if len(r) > 1:
                                              modem.sms_delete()
                                          return True
                                          _reset = True
                                          _reset = True
                                      return False
                                  return False
                              #                           Ready To Poll
                              def ready_to_poll():
                                  # return: True/False
                                  try:
                                      log("--- time since last poll: {0} secs ---".format(g.oNvram.last_poll_secs))
                                      if (g.ppp_error_secs > 0):
                                          log("*** poll throttling: {0} secs ***".format(g.ppp_error_secs))
                                          return False
                                      if (g.oIni.intra_poll_secs > 0):
                                          # contact server every <oIni.intra_poll_secs> seconds
                                          if (g.oNvram.last_poll_secs > g.oIni.intra_poll_secs):
                                              return True
                                      if (g.oSetup.intra_cycle_count > 0):
                                          # contact server every <oSetup.intra_cycle_count> cycles
                                          if (g.oNvram.cycle_count >= g.oSetup.intra_cycle_count):
                                              return True
                                      # g.poll_host is set at startup and by SMS POLL_HOST message
                                      if (g.poll_host == True):
                                          return True
                                  return False
                              #                         Transmit
                              def transmit():
                                  try:
                                      util.lcd("Transmitting", "")
                                      g.modem_state = g.MS_CONNECTING
                                      r = poll()
                                      g.modem_state = g.MS_DISCONNECT
                                      if (r == False):
                                          util.lcd("Transmit failed", "")
                                          sleep_ms(2500)
                                          util.lcd("","")
                                          return
                                      util.lcd("Successful", "")
                                      sleep_ms(2500)
                                      util.lcd("","")
                                      g.poll_host = False
                                      g.oNvram.last_poll_secs = 0
                                      g.poll_secs = 0
                                      if (g.update_flag == True):
                                          # done after disconnect
                                          try:
                                              if util.file_exists("REMOTE.TAR"):
                                                  log("remove old REMOTE.TAR")
                                                  util.remove("REMOTE.TAR")
                                              log("rename TEMP to REMOTE.TAR")
                                              uos.rename("TEMP", "REMOTE.TAR")
                                              # create file to signal boot.py that update is available
                                              log("create UPDATE signal file")
                                              with open("UPDATE", "w") as f:
                                                  f.write("UPDATE")
                                              log("** New REMOTE.TAR ready to update")
                                      if (g.reboot_after_poll == True):
                                          log("SMS message changed INI setting, rebooting")
                                          util.reset(6, "INI changed")
                                      if (g.oHost.erase == True):
                                          log("Erase command received, rebooting")
                                          g.oNvram.erase()
                                          util.reset(7, "Erase NVRAM")
                                      if (g.oHost.reset == True):
                                          log("Reset command received, rebooting")
                                          util.reset(8, "Reset command")
                                tlanier @tlanier
                                @tlanier
                                Part 3 of 3
                                Here's the http.py module:
                                Note that the modem socket commands have a 1500 byte limitation. The HTTP module overcomes that by breaking longer messages up into smaller blocks.
                                import modem
                                import sys
                                import ubinascii
                                import uos
                                import ustruct
                                import util
                                # note: HTTP errors raise exceptions
                                CR = const(0x0d)
                                LF = const(0x0a)
                                #                       Close HTTP Socket
                                def close_http():
                                #                       Open HTTP Socket
                                    global rx_cnt, rx_data, rx_pt, tx_cnt
                                    rx_cnt = 0
                                    rx_data = b''
                                    rx_pt = 0
                                    tx_cnt = 0
                                    if r == False:
                                        raise Exception("TCP socket connect error")
                                def rx_block(cnt):
                                    b = bytearray(cnt)
                                    i = 0
                                    while i < cnt:
                                        b[i] = rx_byte()
                                        i = i + 1
                                    log("rx_block: {} bytes".format(len(b)))
                                    return b
                                def rx_byte():
                                    global http_size, rx_cnt, rx_data, rx_pt
                                    t0 = ticks_ms()
                                    while rx_cnt == 0:
                                        rx_pt = 0
                                        if rx_cnt > 0:
                                            break
                                        t1 = ticks_ms()
                                            raise Exception("HTTP timeout in rx_byte")
                                        sleep_ms(200)
                                    b = rx_data[rx_pt]
                                    rx_cnt = rx_cnt - 1
                                    rx_pt = rx_pt + 1
                                    return b
                                def rx_dword():
                                    dw1 = rx_byte()
                                    dw2 = rx_byte()
                                    dw3 = rx_byte()
                                    dw4 = rx_byte()
                                    n = 0
                                    s = ""
                                        b = rx_byte()
                                        if b == CR:
                                            continue
                                        if b == LF:
                                            break
                                        header[n] = b
                                        n = n + 1
                                            raise Exception("Maximum header size error in rx_http_header")
                                    if n > 0:
                                        # older versions of MicroPython do not implement decode on bytearrays
                                        a = bytes(header[0:n])
                                        s = a.decode('utf-8')
                                        log("header = {}".format(s))
                                    return s
                                # HTTP/1.1 200 OK
                                # <headers>
                                # <headers>
                                # <crlf>
                                    global http_size
                                    http_size = 0
                                        # log("length = {0}, header = {1}".format(len(s), s))
                                        if s == "":
                                            break
                                        headers.append(s)
                                        raise Exception("Not enough headers received in rx_http_headers")
                                        raise Exception("Invalid first header line: {0}".format(headers[0]))
                                    for s in headers:
                                            a = s.split(' ')
                                    return headers
                                    i = 0
                                    while i < max_len:
                                        b = rx_byte()
                                        if b == 0:
                                            break
                                        rx[i] = b
                                        i = i + 1
                                    if i == 0:
                                        return ""
                                    a = bytes(rx[0:i])
                                    return s
                                def rx_word():
                                    dw1 = rx_byte()
                                    dw2 = rx_byte()
                                #                       Transmit Block
                                def tx_block(b):
                                    for x in b:
                                        tx_byte(x)
                                #                       Transmit Byte
                                def tx_byte(b):
                                        return
                                    tx_data[tx_cnt] = b
                                    tx_cnt = tx_cnt + 1
                                        tx_flush()
                                #                       Transmit DWORD
                                def tx_dword(dw):
                                #                       Transmit Flush
                                def tx_flush():
                                    if tx_cnt == 0:
                                        return
                                    if not r:
                                        raise Exception("Error transmitting in tx_flush")
                                    tx_cnt = 0
                                    # example:
                                    # <crlf>
                                    global http_size
                                    tx_string(s)
                                    if host_port != 80:
                                    tx_string(s)
                                    tx_string(s)
                                    tx_string(s)
                                    s = "\r\n"
                                    tx_string(s)
                                #                       Transmit String
                                def tx_string(s):
                                    for x in b:
                                        tx_byte(x)
                                #                       Transmit WORD
                                def tx_word(w):
                                    tx_byte(w & 0xff)
                                • R Offline
                                  ruok4t @tlanier
                                  @tlanier Thanks, will download all parts and take a look.
                                    SciWax
                                    @tlanier
                                    Thank you for compiling all this information for the community. I really appreciate it. It could become handy for my project.
                                      Scott Basgaard @tlanier
                                      @tlanier did you ever put this in a repo?
                                        tlanier @Scott Basgaard
                                        @Scott-Basgaard Sorry, I have not.
                                          Petteri Salo
                                          @tlanier Hey, I started looking into the three files you posted (http.py, com.py, modem.py) and it is looking very usefull! However, both com.py and modem.py have a line:
                                          "import globals as g"
                                          and I'm guessing it is a file you have, but I get an "ImportError: no module named 'globals'"
                                          Perhaps you could upload that file too? After a quick look throuh all "g.*" I could probably deduce most of it, but things like :
                                          would probably be usefull and save us some time.
                                          Anyway, Thanks for helping the community at large with your efforts!!
                                          Cheers,
                                          Petteri
                                          S T 2 Replies Last reply Reply Quote 1
                                            Scott Basgaard @Petteri Salo
                                            @Petteri-Salo agree! Would be great @tlanier if you could share anything else here. Really struggling to get LTE working stable and any further insight for us others would be greatly appreciated. Digging into this more now and will let you know how far I get as well. Thanks for sharing!
                                            • 1
                                            • 2
                                            • 3
                                            • 2 / 3
