  • Moving onwards! Next stage for Pycom
    Pinned
  • Introducing our latest F1 Smart Module
    Pinned Locked
    @Xykon Good to see a sign of life from the team, however it is called now.
  • The future of Pycom
    Pinned Locked
    34
    8 Votes
    @DEFRAINE-JM any further updates on what's happening with Pycom apart from Season Group buying the assets?
  • Pymakr 2 for Visual Studio Code
    Pinned pymakr vscode vsc micropython
  • Firmware Release v1.20.2.r6
    Pinned
    @Developer-Pydro Thank you for this solution, you made my day !
  • Firmware Release v1.20.2.r5
    @Xykon That sounds promising. Good luck.
  • Firmware Release v1.20.2.r4
    @peterp so how to change to NBIOT via uart if sqnsupgrade crashes?
  • LTE modem firmware release for Cat-M1 5.2-48829
    @Gijs Yes, no luck for us using 1.20.2.r4 neither. Still haven't been able to connect in US. Will create another post as you suggest and continue to solve it there.
  • Firmware Release v1.20.2.r3
    @peterp When I wrote that post it was reproducible using my example. Please try it out just as I posted it and see. I don't have a device on me at the moment, but I can give it another shot in a few hours. Best, Troy
  • Firmware Release v1.20.2.r2
    @mxklt said in Firmware Release v1.20.2.r2: I get an error when i try to use machine.pygate_reset() -> LORAPF_ERROR:pygate_reset failed to reset Pycom MicroPython 1.20.2.r2 [v1.11-3a7776d] on 2020-11-23; GPy with ESP32 Please update the Pygate FW and try again: https://docs.pycom.io/updatefirmware/expansionboard/
  • Launching MESH Networks on Pycom
    mesh mesh network ipv6 6lowpan lora
    5 Votes
    This can only be done when the data transmission rates within the mesh network are very low.
  • 11 Votes
    89k Views
    I am trying to use the config for both, node and nano-gtw
  • Firmware Release v1.20.2.r1
    Locked
  • Restructure of the documentation
    Nice to see that someone started to update the documentation. I don't know the actual status. When I started many examples were broken or not implemented completely, Not a big deal for professionals, but you target beginners as well. They need running examples. Experts and beginners struggle together when examples show deprecated or outdated code. This will be problem in the near future. You decided to stop updating LoPys. So we need documentation and examples for different versions. It will be nice, if the examples are part of your tests, so you can notice bad examples early.
  • Pygate PoE Adapters
    poe announcement
    @thinginnovations said in Pygate PoE Adapters: I think the date should be 6th July Sorry yes this has been corrected. @robert-hh said in Pygate PoE Adapters: For those who want to replace the diode in case it looks bad after de-soldering, it would be interesting to know which diode model can be used. I'll check with the hardware team
  • New Firmware Release 1.20.2.rc6
    Locked
    23
    Any change log of firmware 1.20.2.rc7 ? It is not cited in the GitHub releases page : https://github.com/pycom/pycom-micropython-sigfox/releases
  • New Firmware Release 1.20.2.rc3
    Locked
    @Xykon Thanks.
  • Q&A on MicroPython Multi-threading and Garbage Collector
    I am just started to dig into to threading, but my understanding is that pycom only support _thread, which has limited functionality compared to threading. Like lack of .start or .stop. Is my understanding false? Cause the sample code is not working on my wipy.
  • FROM ALL OF US TO ALL OF YOU
    @Bettina Thank you very much Bettina & team. I hope you all have good and quiet days. Robert
