• Universal IP67 Case availability
    universal ip67 case
    Charly86C
    @dan just dropped a mail to sales for a coupon/refund or new order (whatever) Now I just need to wait for a answer, because last time I emailed for a question about VAT of my order I didn't received any answer.
  • pysense: why a coprocessor
    pysense
    @jcaron thanks for pointing to this informative thread! I've looked through the library code as well, very informative. In addition, I spent half a day reverse engineering the connections and looking up cryptic SMT markings for the undocumented parts on the board (TPS78233 LDO, BQ24040 Lipo charger, TT8J13 dual P channel FET). Thankfully I don't need the low power capabilities of this board (I need an active WiFi connection), I only need the sensors, so this simplifies things. Let's hope Pycom releases the secrecy around this board and published PIC source code and schematics.
  • BLE & Low power
    ble bluetooth deepsleep consumption low power
  • Only 1 year Sigfox?
    sigfox lopy4
    Update: Sigfox confirmed it's 1 year now: https://ask.sigfox.com/questions/5899/lopy-4-1-year-connectivity-or-2.html Still not a bad deal I think, as 1 year's worth is still about half the price of the LoPy4. But it would be good to clarify this on the website.
    For starters, you could use the Pysense board (which has a light sensor and a basic driver) and the AWS example to push the data to AWS IoT. This should work out of the box. What you do in AWS IoT is another topic.
  • Lopy4 deep sleep problem
    lopy4 lora deepsleep
    23
    @jcaron Of course!
  • uasyncio support (thread 2)
    uasyncio v1.19.0.b4
    @ahmedach At the moment we offer the Smaller IP67 Case for Pysense/Pytrack. We are looking at options for a universal IP67 case but don’t yet have any committed timelines for this. The earliest we could deliver this would be late Autumn but there’s a good chance it will be pushed into next year
  • Help needed signing the Contributor License Agreement
    contributing license
    Thanks @alejandro ! I see that the Contributor link was fixed -- now I understand why I was using the CLA in the wrong repository. I've redone my pull request after signing the CLA. Best Regards, Brian
  • How to modify LoRa modulation protocols?
    encoding protocols source-code lora
    @jokr2 Hi, in fact i doesn't understood what do you mean. LoraMac allows you to send data using lora radio modulation, this radio layer doesn't have ECC. LoraWan is upper protocol used by lot of gateway and have only a MIC field in frame (Message Integrity Control), i doesn't allow correction, only detection of altered frame (and AES used in lorawan is only used for encryption). If you use LoraMac mode you have to add to your data payload your ECC code by your own. Finaly, if you want to have your ECC added to all frame send by your socket without explicitly add ECC in python code (but it will added on lower layer in C code), you can build your own custom lopy firmware (instruction is present in the forum) Hope this help you
  • fipy eagle footprint
    eagle fipy library
    @pas We have KiCad footprints available on GitHub https://github.com/pycom/footprints All our development modules have the same footprint so if you have one for a WiPy2, LoPy or SiPy etc (NOT WiPy/WiPy1) then that will also work with the FiPy. We also have Altium design files for the Universal Expansion Board https://docs.pycom.io/chapter/datasheets/oem/universal_reference.html which for the headers uses the same footprint as the FiPy (it fits into the expansion board the same way).
  • How to transmit every 30-60 seconds data from LoPy
    lora communication realtime
    @bmarkus said in How to transmit every 30-60 seconds data from LoPy: @rcolistete said in How to transmit every 30-60 seconds data from LoPy: LoRa or LoRaWan ? Regulations are the same for all devices independtly they are LoRa, LoRaWAN or other ISM devices. To know the packet size = payload + LoRaWan header/etc (typically 13 bytes).
    LoRaWAN is using a non-licensed shared frequency band. As long as you meet local regulations, e.g. in Europe max. 1% transmit duty cycle, do not exceed transmit power and bandwidth limits you are safe. It is not about LoRaWAN it is about local radio regulations. These rules are the same for single and 'normal' multi channel GW's.
  • socket.getaddrinfo always fails
    internet sockets dns
    @treanorv have you checked what DNS server your wipy is binding too ? This will be part of the DHCP process T
  • Question and help concerning Pysense/LoPy with Graphite
    pysense
    @tbuteau You should probably start by looking at the various inbound methods you can talk to carbon (the graphite daemon you will send data too). You should establish what is expected by your graphite cloud. I would imagine it is authenticated in some fashion. https://graphite.readthedocs.io/en/latest/feeding-carbon.html pickle or plain text would be the way to go, (I am not aware of AMQP libe for MicroPython)
