• GPy status
    delay gpy
    @Leo_Sol From updates on Kickstarter the GPy is coming at the same time as the FiPy https://www.kickstarter.com/projects/1795343078/fipy-the-worlds-first-5-network-iot-dev-board/posts/1969778 Sounds like it'll be shipping within a month or so as they've started collecting shipping details from backers.
  • For Sale. WiPy 2, expansion board, W01 modules
    for-sale sale
  • Wipy transmits data for 4 hours then stops
    wipy
    @robmarkcole Using robust.py, I'm seeing the same problems, but now I'm getting a good error message back. Typically after a few hours I get (continuously repeated): mqtt reconnect: OSError(105,) So, I should be able to catch that and then kill and then restart the session.
  • Error in example deep sleep shield api doc
    example deepsleep documentation
  • LoPy power draw
    lopy current
  • How to change Lora band from 868 to 915 MHz and back?
    lopy lora
    @bmarkus Version has been updated, change to 1.7.4.b1 and not 1.7.3.b3 The download should work then
  • Pytrack LIS2HH12 Interrupts make I2c bus freeze
    pytrack i2c bus error
    By the way, one error which presists is, that I get a lot of false interrupts especially during wifi activity. The only workaround I found was to check in the isr if the pin really is low.. Not sure if this is an electrical problem or an sw problem...
  • L01 OEM modules new pricing
    l01 oem py discount
  • Pysense LIS2HH12 motion sensor
    pysense
  • Connect LoPy LoRa with Semtech Board
    lora semtech packet loss parsing
  • Deep Sleep Shields - delivery update
    deep sleep shield delivery
    @ssetu No track ! Yesterday morning i find a black plastic envelope in my letter box !! Surprise ;-) I contibute to the 2 pycom kickstarter projects and i am still waiting for the FiPy.
  • battery and TPS2115A
    battery tps2115a
    @NicolaC The Expansion board 2.0 does not provide status of the TPS2115A and battery charge is only available via the voltage divider connected to the ADC (not very accurate, especially for LiPos) But the status of the TPS2115A power mux could good idea for future improvements and/or a Coloumb counter.
  • Moved docs... WHY?!?
    Locked docs 404
    feel your pain i need to change al links on my website lol
  • Ble break a Loop
    ble connect
  • Casing for the Pytrack and Pysense together with LoPy
    pycase pytrack pysense lopy
    @bucknall Thanks for following up on this. For trials, the pytrack would be mounted in a car. The pysense is indoors, wall mounted. I'm in the process of 3D printing a casing myself for this. But as a review I can add that an enclosure similar to Pycase Clear, which is able to house the Pysense and Pytrack boards, would be a best suited solution. I have seen in TI SensorTags that they have transparent casing pieces on top of the sensor side of the board with slits and grids to let both light and humidity in. Perhaps this is also something to consider in the design.
  • What's up with sigfox in the github repository name?
    github pycom general brand
    @jmarcelino you could have pushed the sigfox binaries to a separate branch (without history) and then made that branch the default branch. that way you wouldn't have broken anyone's git remote or pull requests while still hiding the history :)
  • Pysense example I2C not correct
    pysense i2c bus error examplecode
    @gertjanvanhethof odd, I had to change a few things: import for LIS2HH12 was in lower but file is upper "acc = LIS2HH12()" - was getting an error that it didn't want any parameter so I emptied that and it's working now I didn't need to change the pins. This is with WiPy 2.0. Odd, looking thru the documentation, the pins for I2C don't match between the pysense and any of the boards. Anyway, it's working for me on 9 and 10. - EDIT - Wondering if it's taken care of in the library now instead. I just commented out the line and it still works. Edit again - yes, looking in the libraries, it's actually set there which makes more sense anyway. Below is working fine: from machine import I2C from LIS2HH12 import LIS2HH12 import time acc = LIS2HH12() while True: print('----------------------------------') print('X, Y, Z:', acc.read()) print('Roll:', acc.roll()) print('Pitch:', acc.pitch()) print('Yaw:', acc.yaw()) time.sleep(1)
  • Documentation Errata: utime.mktime()
    documentation utime
    @Eric24 Noted - will check this for you!
  • Print(recv_ack) and Print(recv_pkg)
    lora lopy gateway
    @PiAir Thanks.
