    okay cool, thanks very much for the reply. Will update the firmware
  • LoPy doesn't run applications which ran before
    lopy problem nameerror
    Hi @cylex can you please share your code so we can help you? Thanks, Alex
  • LoRa repeater between node and gateway
    Moved lora range
    Hi bmarkus, i've not yet made any hardware solutions for this. Was hoping that someone already made a lora gateway repeater, if possible
  • LoRa live reception meter
    lora meter
    Dear PiAir and Rob (bedankt Rob ;)). Thx so much for your answer regarding this issue, I guess me best option is to write a custom script for this. All the best, Jeroen
  • LoPy OEM Programming
    lopy oem lopy
  • OTAA Node says 'Not yet Joined..'
    otaa nanogateway frequency lopy
    Even after repeated attempts, unable to get my node working. I tried Sodaq One and lopy nano gateway which worked fine. So, I'm guessing there is a problem with my other LoPy which I'm trying to use as a node. Thanks everyone for your help.
  • LOPY OEM VDD1V8
    lopy oem power pin
    OEM modules use 1.8v flash and ram. not sure if they are powered by discrete ldo or esp32 onboard ldo and whether the pin is intended as alternate supply or output.
  • Problem pairing OTAA Node to nano gateway in US TTN
    lopy ttn ttn gateway
    you can find the code that is working right now for TTN US here on my GitHub I also made a guide on my blog
  • Deep sleep mode reset the board?
    deepsleep lopy sleep
    Hi...i am a new user here. As per my knowledge Pin states can be remembered through deepsleep using pin.hold([hold]). Also you can do this in boot it start same as removing power ,you start from clear point. pcb assembly
  • How to save data permanently ?
    lopy saving data storage
    @livius FW of the SD card should prevent corruption of file system of the card if power fail happens during writing. How this is achieved I don't know.
  • Cheapest GPS for time sync only
    gps time
    @jmarcelino said in Cheapest GPS for time sync only: Interesting alternative, but i will stay with GPS - it also work on ship and is really simple to use (mostly UART). As always i probably do not need position - but if i can get it than it sometimes can be usefull as a gadget. And can be simply repleaced by more accurate GPS without firmware modification. Then better is GPS for me here.
  • Blocking vs non blocking socket
    lopy non blockin blocking
  • FSK and RX2 Windows
    fsk rx2 addchannel
  • BLE advertising rate
    lopy ble advertising
    Hi @sthomson, I do not believe that our library supports this as of current but if you create an issue for the problem on https://github.com/pycom/pycom-micropython-sigfox, the engineering team will be aware of it and will build it into our roadmap! Cheers, Alex
  • LoPy and LIDAR-Lite v2 I2C
    lopy i2c
    @kingj first change your init to only one line - i do not suppose that this matter but... i2c = I2C(0, I2C.MASTER, baudrate=100000) and try to add first default config i2c.writeto_mem(addr,0x00,bytes([0x00]))
  • LOPY HC-SR04 Adaptation
    hc-sr04 lopy ultrasonic
    papasmurphP
    @robert-hh Pick it apart :).
  • Nodes unable to join TTN via LoPy nano gateway
    lopy nanogateway join lorawan ttn
    Finally I could get the node to join TTN! :D I needed to add a delay of 5 seconds before the node starts listening for the response of the Join Request with the command AT+JD: > AT+JD=5 OK > AT+JOIN Successfully joined network OK Also the fix for _send_down_link in my last post is no more needed as the frequency in the Event Data is now ok.
  • How to send large data over Lora?
    lopy lora
    8k Views
    There are a few keys here. One is that beartooth is using both lora and FSK modulations with p2p and not lorawan. FSK will give higher datarate. Two is that there is not a 1% duty cycle limitation on 915mhz in us like 868mhz in Europe. There are still power restrictions. Would love to see an open source beartooth clone with 2 lopy's. Beartooth and gotenna are cool but too expensive, I just stick to cheap 2-way radios for now.
  • SPI Interface Questions
    spi
    I can offer the following info; The SPI is implemented in hardware. (I2C not yet, still software) Maximum clock rate is half the system clock frequency which currently is set at 160Mhz, so SPI clk can be as high as 80Mhz. Next slower frequency will be 40Mhz, then 20Mhz, then 10Mhz ......
