• WLAN init = core dumped?
    I just tried it using the most recent firmware 1.6.5.b1 and it seems to work just fine now 👍
  • Regex ure library is broken?
    ure regex danicampora micropython freertos
    @paul12345 : I do not know why the implementation is recursive. Maybe it always was, or it's the most elegant solution. About the double quote: No, it does not work on WiPy if you drop the double quote at the end of the search string. But you will have a match on machines with more memory, simply because the sample string (line) you are searching at does not contain the pattern mp3". B.T.W.: Shortening the string in line works on WiPy. Regards, Robert
  • Onewire, Wifi, MQTT, crash...
    Moved onewire mqtt wifi crash ds18b20
    The freeze with gc.collect seems to be a bug in the firmware. @daniel is already working on it : https://forum.pycom.io/post/4219
  • Another new crash - byte code not implemented
    Moved crash
    @Shaun - my experience is very similar to yours, I have compromised and changed my code to avoid anything that I know or suspect will cause a problem, but without certain fundamental and reliable building blocks it is impossible to continue. While I applaud their innovation and attempts at pushing the envelope, I wish that communication was better managed, for example I know nothing of this memory issue until you just mentioned it ! I face continued system reboots (Guru mediation unhandled exceptions) , socket disconnections (and never reconnect) and no matter how I streamline my code, I just can't prevent them, as you say there's only so much you can do. I am guessing that their test environment does not include real world examples, but simplistic things like creating a thread that prints 'Hello World' while the main thread does nothing at all. I have also spent soo much unnecessary time trying to convert libraries from esp8266 to esp32 instead of spending time on developing my apps, I would have expected pycom to create a comprehensive 'official' library of various sensor drivers and utilities and use this library to test against when rolling out any new releases.
  • Guru Meditation Error Dumps
    @jmarcelino - good point, thanks I have added them.
  • Telnet disconnect and need hard reset
    Hi Gabriel, Thanks for the extra info. I'll go through a debugging session tomorrow and see what's going on... Cheers, Daniel
