  • Announcements regarding our community
    3 Topics
    @jirkakrepl said in New Pybytes firmware 1.18.1.r9 (Experimental LTE support): If your LTE configuration is correct, your device with a Simcard should connect to Pybytes using LTE. Then Terminal and Flash OTA update should work too. Awesome, I'll try it out soon, thanks! LTE OTA was only thing holding us back from a production release.
  • Discussion for Feature Request and Future Additions to Pybytes
    15 Topics
    i am interested in your post, but can you share more detail
  • Discussion for Pybytes Beta Support and Assistance
    158 Topics
    Åke ForslundÅ
    Now it seems to be back up.
  • [SOLVED] WiPy 2.0 on Pybytes?
    Problem was I wasn't using 5V on VCC and the guru meditation was coming from not having enough power.
  • Pybytes online REPL covered by legal bar
    Hi, We're aware of the issue and working on fixing the layout :) Gijs
  • Deploy release via pybytes
    Hi, Thanks for the suggestions / testing. I'll add it to the bugs list. I understand the feature is not quite as robust as you'd like. The Pybytes.conf file is unique to each device (it contains the unique id etc.), though Im not sure how that ties into the whole release process and if you have to include it.
  • Pybytes battery level doesn’t show up
    I was not even aware there was a distinction. It has to be around 10-15% that the notification text switches.
  • not receiving BLE notifications on pycom fipy
    @Robert-N have you had any success with notify egen connecting a pycom board as a client to a server (sensor) or is this not possible?
  • Error while connecting pybytes with LTE
    @Gijs Hi. The output of dnsserver after pybytes.start is ('172.31.16.100', '172.31.32.100'), while the output of AT+CGCONTRDP? is always ERROR. I tried to move the AT command in different parts of the code but the result was always ERROR. When the device fails I cannot retrieve any information, so I don't know what the dnsserver output is. I'm using your Vodafone SIM in Italy. Thank you
  • Pybytes and Chirpstack + OTAA + Thingsboard cloud
    Because the app eui is not checked for validity locally, but rather with the Chirpstack server somewhere in the backend. All three parameters are used to resolve the packets coming in over LoRa to your project console in Chirpstack. If you're planning on using the Pybytes / Pycom Chirpstack server, you should configure your device (node) through Pybytes to use a LoRa connection and all the keys will be handled automatically. A gateway setup should be very similar to setting up to TTN, except for the different server address / (possibly) gateway eui. If youre not using the Pycom Chirpstack server, all three parameters should be available somewhere as far as I know. Let me know if that answers your question
    As mentioned in the post you linked in, we're working on it :)
  • Pybytes MQTT Connection & topics
    I can imagine, sorry for the inconvenience. I submitted a feature request with the Pybytes team to be able to do this. If there's more people looking for this, it would bring higher up the list of course :) Thanks! Have a nice weekend yourself Gijs
  • Pymakr online console covered up by legal bar - formatting issue
    Thanks for informing us, I'll forward it to the Pybytes team!
  • Lopy4 LoraWAN Uplink Device Rejoin Command
    Nothing built in, you'd have to update the code to implement this, which you say is not possible. Andrew
  • Pybytes release
    @Gijs Interesting. Hopefully it gets sorted soon. Thanks.
  • LTE-M GPy Spain - Attach?
    @dpoza Hi, where you able to connect the Pycom board to LTE-M. I am also from Spain and would like to know if cellular connectivity is working correctly before buying the board. Gracias,
  • Pybytes Upgrade Firmware process
    @dnear1 Of course, a watched pot never boils... and seemingly, setting pybytes to a higher debug level seems to make firmware updates succeed.. Packet sent. (Length: 49) Packet sent. (Length: 49) Packet sent. (Length: 49) Packet sent. (Length: 49) Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49) This is PybytesProtocol.__process_recv_message() This is PybytesLibrary.unpack_message(message=b'\x06\x03') receiving FCOTA request Sending FCOTA ping back: __pack_message: b'0670' MQTT Protocol Packet sent. (Length: 49)
  • Size limit of releases on pybytes - whyyy?
  • How to remove Lopy4 from pybytes platform
    @Arnold-Quinsey I don't know exactly your problem, but maybe just usign 'pycom.pybytes_on_boot(False)' could answer your question?
  • Add lib to pybytes/pymakr online
    You can right-click on the device name to create file or folder. Next to that, you can use os.mkdir(...) to create a folder as well from the terminal, and/or open('lib/file.py', 'wb') to create a file At the moment, is not possible to automatically create the pytrack/pysense libraries in pymakr online.
  • Possible to have Lopy4 connected to both Pybytes and TTN
    I do not think this is possible, as the Pybytes TTN integration couples the Lopy4 through another TTN application, using only the LoRa connection. When you use WLAN to connect through pybytes to manage firmware updates etc, and LoRa to connect to TTN, there should be no issue.
