• How to get the automatic AP back on lopy ?
    lopy4 ap mode wifi access point
    @robert-hh Ok, thanks !
  • lora.nvram_save / restore() | frame counter updates
    @morrison my personal guess would be that you are going to sleep a bit too quickly after sending/saving state. The Pysense-controlled Deep Sleep is quite brutal, it just cuts the power supply to the ESP32 without any warning. Try adding short delays between send and save and between save and sleep to see if that helps. Also, is your device rejoining each time, or just sending with the same counter over and over again?
  • Lopy nano gateway in ABP mode does not receive all frames from LoRa node
    @jg_spitfire The gateway is not in ABP mode, and it does not matter whether the node was configures with ABP or OTAA. What most likely happens that the messages of the node are sent at different frequencies. Since the nanogateway only listens on one frequency, it misses languages. The abp_node.py example tries to configure the node to use a single frequency only, and in my test that worked, but recent comments seem to tell the opposite.
  • WDT count down during deepsleep?
  • LoPy: bytes data received in HEX convert to original text
  • loramesh example crashing on LoPy4
    thanks for your reply, i fixed the problem and raised a pull-request!
  • pytrack / pysense supply through normal alkaline batteries
    Don't know about the lopy. On the pysense they have a BQ24040 charger, which has a maximum battery voltage of 7 V (see datasheet). As jcaron wrote, alkaline cells have significant internal impedance, which is increasing with discharge and lower temperature. Watch the battery holders, the popular conical spring coil ones are crap. Maybe add a supercap to buffer current pulses from the RF transmitter.
  • Sending MAC layer commands
    lorawan
    Hi, I know this is not a gateway. I have been using other devices where I am able to send MAC layer commands. Your response fails to answer any of this. Andrew
  • LoPy Gatewat With Heltec ESP32
    @jamesbowers remember that the LoPy can only listen on one channel at a time, not several like a real gateway should. You will have to make changes to your client device so it used only the same frequency as the LoPy. What region are you in?
  • LoRa testing - what equipment is best
    antenna sdr test equipment
    @jdcrunchman I see that you leared to split your text in secitions: about SDR: That is only needed if you have doubts on whether RF is happening at specific times and frequencies. Normally, you can expect that, so RF testing is not mandatory. besides that, I have good experience with the model SDRplay RSP2pro. The deviecs is only as good as the software, and the supplied software works well with Windows. There hiccups with Linux. A SDR will not tell you about precise timing of RF bursts. For that, an oscilloscope give better results. If just the presence of a RF signal is to eb detected, usinf a small signal Schottky diode (e.g. 1N5711) as Antenna allows using a low bandwith oscilloscope. about the Antenna: Depends on your application. For a node, it may have to be small, for a gateway, the antenna gain may have to be the most important factor. Given the huge link budget of LoRa devices, a few dB antenna gain more or less may be not that important. So proper RF design, placement and orientation of your set-up may have a larger impact. I tested a few small antennas from different sources, and they all behaved similar. The PyCom Lora antenna works fine, and being a wavelength/2 design, the RF properties of the LoPy enclosure are not so critical. Supply by Solar Panel: You would need an external charger between Solar Panel and battery: Solar Panel -> Charger -> Battery -> Lopy
  • Firmware source code?
    39
    18k Views
    @jeremy I'm considering developing a proof of concept for a possible commercial product, and the LoPy 4 board would be an ideal choice for a POC demo. I'm just concerned with what the LoPy board has for battery management for both our back pack units and relay stations. It's the relay stations that has to be smart on battery management, although we think we can get away with 1 watt solar panels for the relay stations, both initially designed around the LoPy, but who do we talk to to at PyCom to talk about licensing the LoPy for commercial use?
  • Using LoraWan and raw lora in the same device
    @jcaron My first try was performing a new join every time and that worked but it was not efficient. Finally I could make it work using the lora.nvram_save() before leaving LoraWan and lora.nvram_restore() after entering LoRAWAN mode again. It seems to be working now :) Thanks for your help!
  • LoPy source code, is the "LoRa" Python module open source?
    lora source cod
    @jdcrunchman the firmware is subject to GPLV3. The licences to use is included with genuine Pycom hardware. You can use the stack on different hardware but there are conditions that need to be met or alternatively a small licence fee is applicable. Please contact us on sales@pycom.io. Thanks
    You could look for NVRAM here: https://docs.pycom.io/firmwareapi/pycom/pycom.html
  • How to enable other network after initial setup/firmware update?
  • OTAA Node to Nano Gateway AU915
    Y
    Thanks @jcaron , Got it working using ABP and a few change to the TNN config, but would still like to get it working with OTAA this was all done with the Pybytes firmware, I have now removed it on your suggestion and I'll see how it goes. Current configuration Gateway config.py #!/usr/bin/env python # # Copyright (c) 2019, Pycom Limited. # # This software is licensed under the GNU GPL version 3 or any # later version, with permitted additional terms. For more information # see the Pycom Licence v1.0 document supplied with this file, or # available at https://www.pycom.io/opensource/licensing # """ LoPy LoRaWAN Nano Gateway configuration options """ import machine import ubinascii WIFI_MAC = ubinascii.hexlify(machine.unique_id()).upper() # Set the Gateway ID to be the first 3 bytes of MAC address + 'FFFE' + last 3 bytes of MAC address GATEWAY_ID = WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12] SERVER = 'router.au.thethings.network' PORT = 1700 NTP = "au.pool.ntp.org" NTP_PERIOD_S = 3600 WIFI_SSID = 'ssid' WIFI_PASS = 'password' WIFI_ADDRESS = '192.168.1.50' WIFI_MASK = '255.255.255.0' WIFI_GATEWAY = '192.168.1.1' # for EU868 # LORA_FREQUENCY = 868100000 # LORA_GW_DR = "SF7BW125" # DR_5 # LORA_NODE_DR = 5 # for US915 # LORA_FREQUENCY = 903900000 # LORA_GW_DR = "SF7BW125" # DR_3 # LORA_NODE_DR = 3 # for AU915 LORA_FREQUENCY = 916800000 LORA_GW_DR = "SF7BW125" LORA_NODE_DR = 5 nanogateway.py #!/usr/bin/env python # # Copyright (c) 2019, Pycom Limited. # # This software is licensed under the GNU GPL version 3 or any # later version, with permitted additional terms. For more information # see the Pycom Licence v1.0 document supplied with this file, or # available at https://www.pycom.io/opensource/licensing # """ LoPy LoRaWAN Nano Gateway. Can be used for both EU868 and US915. """ import errno import machine import ubinascii import ujson import uos import usocket import utime import _thread from micropython import const from network import LoRa from network import WLAN from machine import Timer PROTOCOL_VERSION = const(2) PUSH_DATA = const(0) PUSH_ACK = const(1) PULL_DATA = const(2) PULL_ACK = const(4) PULL_RESP = const(3) TX_ERR_NONE = 'NONE' TX_ERR_TOO_LATE = 'TOO_LATE' TX_ERR_TOO_EARLY = 'TOO_EARLY' TX_ERR_COLLISION_PACKET = 'COLLISION_PACKET' TX_ERR_COLLISION_BEACON = 'COLLISION_BEACON' TX_ERR_TX_FREQ = 'TX_FREQ' TX_ERR_TX_POWER = 'TX_POWER' TX_ERR_GPS_UNLOCKED = 'GPS_UNLOCKED' UDP_THREAD_CYCLE_MS = const(20) STAT_PK = { 'stat': { 'time': '', 'lati': 0, 'long': 0, 'alti': 0, 'rxnb': 0, 'rxok': 0, 'rxfw': 0, 'ackr': 100.0, 'dwnb': 0, 'txnb': 0 } } RX_PK = { 'rxpk': [{ 'time': '', 'tmst': 0, 'chan': 0, 'rfch': 0, 'freq': 0, 'stat': 1, 'modu': 'LORA', 'datr': '', 'codr': '4/5', 'rssi': 0, 'lsnr': 0, 'size': 0, 'data': '' }] } TX_ACK_PK = { 'txpk_ack': { 'error': '' } } class NanoGateway: """ Nano gateway class, set up by default for use with TTN, but can be configured for any other network supporting the Semtech Packet Forwarder. Only required configuration is wifi_ssid and wifi_password which are used for connecting to the Internet. """ def __init__(self, id, frequency, datarate, ssid, password, address, mask, gateway, server, port, ntp_server='au.pool.ntp.org', ntp_period=3600): self.id = id self.server = server self.port = port self.frequency = frequency self.datarate = datarate self.ssid = ssid self.password = password self.address = address self.mask = mask self.gateway = gateway self.ntp_server = ntp_server self.ntp_period = ntp_period self.server_ip = None self.rxnb = 0 self.rxok = 0 self.rxfw = 0 self.dwnb = 0 self.txnb = 0 self.sf = self._dr_to_sf(self.datarate) self.bw = self._dr_to_bw(self.datarate) self.stat_alarm = None self.pull_alarm = None self.uplink_alarm = None self.wlan = None self.sock = None self.udp_stop = False self.udp_lock = _thread.allocate_lock() self.lora = None self.lora_sock = None self.rtc = machine.RTC() def start(self): """ Starts the LoRaWAN nano gateway. """ self._log('Starting LoRaWAN nano gateway with id: {}', self.id) # setup WiFi as a station and connect self.wlan = WLAN(mode=WLAN.STA) self.wlan.ifconfig(config=(self.address, self.mask, self.gateway, self.gateway)) self._connect_to_wifi() # get a time sync self._log('Syncing time with {} ...', self.ntp_server) self.rtc.ntp_sync(self.ntp_server, update_period=self.ntp_period) while not self.rtc.synced(): utime.sleep_ms(50) self._log("RTC NTP sync complete") # get the server IP and create an UDP socket self.server_ip = usocket.getaddrinfo(self.server, self.port)[0][-1] self._log('Opening UDP socket to {} ({}) port {}...', self.server, self.server_ip[0], self.server_ip[1]) self.sock = usocket.socket(usocket.AF_INET, usocket.SOCK_DGRAM, usocket.IPPROTO_UDP) self.sock.setsockopt(usocket.SOL_SOCKET, usocket.SO_REUSEADDR, 1) self.sock.setblocking(False) # push the first time immediatelly self._push_data(self._make_stat_packet()) # create the alarms self.stat_alarm = Timer.Alarm(handler=lambda t: self._push_data(self._make_stat_packet()), s=60, periodic=True) self.pull_alarm = Timer.Alarm(handler=lambda u: self._pull_data(), s=25, periodic=True) # start the UDP receive thread self.udp_stop = False _thread.start_new_thread(self._udp_thread, ()) # initialize the LoRa radio in LORA mode self._log('Setting up the LoRa radio at {} Mhz using {}', self._freq_to_float(self.frequency), self.datarate) self.lora = LoRa( mode=LoRa.LORA, frequency=self.frequency, bandwidth=self.bw, sf=self.sf, preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True ) # create a raw LoRa socket self.lora_sock = usocket.socket(usocket.AF_LORA, usocket.SOCK_RAW) self.lora_sock.setblocking(False) self.lora_tx_done = False self.lora.callback(trigger=(LoRa.RX_PACKET_EVENT | LoRa.TX_PACKET_EVENT), handler=self._lora_cb) self._log('LoRaWAN nano gateway online') def stop(self): """ Stops the LoRaWAN nano gateway. """ self._log('Stopping...') # send the LoRa radio to sleep self.lora.callback(trigger=None, handler=None) self.lora.power_mode(LoRa.SLEEP) # stop the NTP sync self.rtc.ntp_sync(None) # cancel all the alarms self.stat_alarm.cancel() self.pull_alarm.cancel() # signal the UDP thread to stop self.udp_stop = True while self.udp_stop: utime.sleep_ms(50) # disable WLAN self.wlan.disconnect() self.wlan.deinit() def _connect_to_wifi(self): self.wlan.connect(self.ssid, auth=(None, self.password)) while not self.wlan.isconnected(): utime.sleep_ms(50) self._log('WiFi connected to: {}', self.ssid) def _dr_to_sf(self, dr): sf = dr[2:4] if sf[1] not in '0123456789': sf = sf[:1] return int(sf) def _dr_to_bw(self, dr): bw = dr[-5:] if bw == 'BW125': return LoRa.BW_125KHZ elif bw == 'BW250': return LoRa.BW_250KHZ else: return LoRa.BW_500KHZ def _sf_bw_to_dr(self, sf, bw): dr = 'SF' + str(sf) if bw == LoRa.BW_125KHZ: return dr + 'BW125' elif bw == LoRa.BW_250KHZ: return dr + 'BW250' else: return dr + 'BW500' def _lora_cb(self, lora): """ LoRa radio events callback handler. """ events = lora.events() if events & LoRa.RX_PACKET_EVENT: self.rxnb += 1 self.rxok += 1 rx_data = self.lora_sock.recv(256) stats = lora.stats() packet = self._make_node_packet(rx_data, self.rtc.now(), stats.rx_timestamp, stats.sfrx, self.bw, stats.rssi, stats.snr) packet = self.frequency_rounding_fix(packet, self.frequency) self._push_data(packet) self._log('Received packet: {}', packet) self.rxfw += 1 if events & LoRa.TX_PACKET_EVENT: self.txnb += 1 lora.init( mode=LoRa.LORA, frequency=self.frequency, bandwidth=self.bw, sf=self.sf, preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True ) def _freq_to_float(self, frequency): """ MicroPython has some inprecision when doing large float division. To counter this, this method first does integer division until we reach the decimal breaking point. This doesn't completely elimate the issue in all cases, but it does help for a number of commonly used frequencies. """ divider = 6 while divider > 0 and frequency % 10 == 0: frequency = frequency // 10 divider -= 1 if divider > 0: frequency = frequency / (10 ** divider) return frequency def frequency_rounding_fix(self, packet, frequency): freq = str(frequency)[0:3] + '.' + str(frequency)[3] start = packet.find("freq\":") end = packet.find(",", start) packet = packet[:start + 7] + freq + packet[end:] return packet def _make_stat_packet(self): now = self.rtc.now() STAT_PK["stat"]["time"] = "%d-%02d-%02d %02d:%02d:%02d GMT" % (now[0], now[1], now[2], now[3], now[4], now[5]) STAT_PK["stat"]["rxnb"] = self.rxnb STAT_PK["stat"]["rxok"] = self.rxok STAT_PK["stat"]["rxfw"] = self.rxfw STAT_PK["stat"]["dwnb"] = self.dwnb STAT_PK["stat"]["txnb"] = self.txnb return ujson.dumps(STAT_PK) def _make_node_packet(self, rx_data, rx_time, tmst, sf, bw, rssi, snr): RX_PK["rxpk"][0]["time"] = "%d-%02d-%02dT%02d:%02d:%02d.%dZ" % (rx_time[0], rx_time[1], rx_time[2], rx_time[3], rx_time[4], rx_time[5], rx_time[6]) RX_PK["rxpk"][0]["tmst"] = tmst RX_PK["rxpk"][0]["freq"] = self._freq_to_float(self.frequency) RX_PK["rxpk"][0]["datr"] = self._sf_bw_to_dr(sf, bw) RX_PK["rxpk"][0]["rssi"] = rssi RX_PK["rxpk"][0]["lsnr"] = snr RX_PK["rxpk"][0]["data"] = ubinascii.b2a_base64(rx_data)[:-1] RX_PK["rxpk"][0]["size"] = len(rx_data) return ujson.dumps(RX_PK) def _push_data(self, data): token = uos.urandom(2) packet = bytes([PROTOCOL_VERSION]) + token + bytes([PUSH_DATA]) + ubinascii.unhexlify(self.id) + data with self.udp_lock: try: self.sock.sendto(packet, self.server_ip) except Exception as ex: self._log('Failed to push uplink packet to server: {}', ex) def _pull_data(self): token = uos.urandom(2) packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_DATA]) + ubinascii.unhexlify(self.id) with self.udp_lock: try: self.sock.sendto(packet, self.server_ip) except Exception as ex: self._log('Failed to pull downlink packets from server: {}', ex) def _ack_pull_rsp(self, token, error): TX_ACK_PK["txpk_ack"]["error"] = error resp = ujson.dumps(TX_ACK_PK) packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_ACK]) + ubinascii.unhexlify(self.id) + resp with self.udp_lock: try: self.sock.sendto(packet, self.server_ip) except Exception as ex: self._log('PULL RSP ACK exception: {}', ex) def _send_down_link(self, data, tmst, datarate, frequency): """ Transmits a downlink message over LoRa. """ self.lora.init( mode=LoRa.LORA, frequency=frequency, bandwidth=self._dr_to_bw(datarate), sf=self._dr_to_sf(datarate), preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True ) #while utime.ticks_cpu() < tmst: # pass self.lora_sock.send(data) self._log( 'Sent downlink packet scheduled on {:.3f}, at {:.3f} Mhz using {}: {}', tmst / 1000000, self._freq_to_float(frequency), datarate, data ) def _send_down_link_class_c(self, data, datarate, frequency): self.lora.init( mode=LoRa.LORA, frequency=frequency, bandwidth=self._dr_to_bw(datarate), sf=self._dr_to_sf(datarate), preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True, device_class=LoRa.CLASS_C ) self.lora_sock.send(data) self._log( 'Sent downlink packet scheduled on {:.3f}, at {:.3f} Mhz using {}: {}', utime.time(), self._freq_to_float(frequency), datarate, data ) def _udp_thread(self): """ UDP thread, reads data from the server and handles it. """ while not self.udp_stop: try: data, src = self.sock.recvfrom(1024) _token = data[1:3] _type = data[3] if _type == PUSH_ACK: self._log("Push ack") elif _type == PULL_ACK: self._log("Pull ack") elif _type == PULL_RESP: self.dwnb += 1 ack_error = TX_ERR_NONE tx_pk = ujson.loads(data[4:]) if "tmst" in data: tmst = tx_pk["txpk"]["tmst"] t_us = tmst - utime.ticks_cpu() - 15000 if t_us < 0: t_us += 0xFFFFFFFF if t_us < 20000000: self.uplink_alarm = Timer.Alarm( handler=lambda x: self._send_down_link( ubinascii.a2b_base64(tx_pk["txpk"]["data"]), tx_pk["txpk"]["tmst"] - 50, tx_pk["txpk"]["datr"], int(tx_pk["txpk"]["freq"] * 1000) * 1000 ), us=t_us ) else: ack_error = TX_ERR_TOO_LATE self._log('Downlink timestamp error!, t_us: {}', t_us) else: self.uplink_alarm = Timer.Alarm( handler=lambda x: self._send_down_link_class_c( ubinascii.a2b_base64(tx_pk["txpk"]["data"]), tx_pk["txpk"]["datr"], int(tx_pk["txpk"]["freq"] * 1000) * 1000 ), us=50 ) self._ack_pull_rsp(_token, ack_error) self._log("Pull rsp") except usocket.timeout: pass except OSError as ex: if ex.errno != errno.EAGAIN: self._log('UDP recv OSError Exception: {}', ex) except Exception as ex: self._log('UDP recv Exception: {}', ex) # wait before trying to receive again utime.sleep_ms(UDP_THREAD_CYCLE_MS) # we are to close the socket self.sock.close() self.udp_stop = False self._log('UDP thread stopped') def _log(self, message, *args): """ Outputs a log message to stdout. """ print('[{:>10.3f}] {}'.format( utime.ticks_ms() / 1000, str(message).format(*args) )) main.py #!/usr/bin/env python # # Copyright (c) 2019, Pycom Limited. # # This software is licensed under the GNU GPL version 3 or any # later version, with permitted additional terms. For more information # see the Pycom Licence v1.0 document supplied with this file, or # available at https://www.pycom.io/opensource/licensing # """ LoPy LoRaWAN Nano Gateway example usage """ import config from nanogateway import NanoGateway if __name__ == '__main__': nanogw = NanoGateway( id=config.GATEWAY_ID, frequency=config.LORA_FREQUENCY, datarate=config.LORA_GW_DR, ssid=config.WIFI_SSID, password=config.WIFI_PASS, address=config.WIFI_ADDRESS, mask=config.WIFI_MASK, gateway=config.WIFI_GATEWAY, server=config.SERVER, port=config.PORT, ntp_server=config.NTP, ntp_period=config.NTP_PERIOD_S ) nanogw.start() nanogw._log('You may now press ENTER to enter the REPL') input() Connecting to COM11... [ 2.595] Starting LoRaWAN nano gateway with id: b'3C71BFFFFE8750F0' [ 6.118] WiFi connected to: ssid [ 6.123] Syncing time with au.pool.ntp.org ... [ 6.179] RTC NTP sync complete [ 6.189] Opening UDP socket to router.au.thethings.network (52.62.83.250) port 1700... [ 6.204] Setting up the LoRa radio at 916.7999 Mhz using SF7BW125 [ 6.213] LoRaWAN nano gateway online [ 6.218] You may now press ENTER to enter the REPL Pycom MicroPython 1.18.2.r7 [v1.8.6-849-df9f237] on 2019-05-14; LoPy4 with ESP32 Type "help()" for more information. >>> [ 6.249] Push ack [ 21.068] Received packet: {"rxpk": [{"data": "QLIXAiYAAAACQ9+WpQPqPkmVOg==", "time": "2019-05-31T19:49:52.173381Z", "chan": 0, "tmst": 21050429, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": 0, "rfch": 0, "codr": "4/5", "freq": 916.8, "datr": "SF7BW125", "size": 19}]} [ 21.129] Push ack [ 31.066] Received packet: {"rxpk": [{"data": "QLIXAiYAAQAC1T4VWxMKlrC8Aw==", "time": "2019-05-31T19:50:02.172292Z", "chan": 0, "tmst": 31049439, "stat": 1, "modu": "LORA", "lsnr": 6.0, "rssi": -1, "rfch": 0, "codr": "4/5", "freq": 916.8, "datr": "SF7BW125", "size": 19}]} [ 31.208] Push ack [ 31.252] Pull ack ABP Node config.py #!/usr/bin/env python # # Copyright (c) 2019, Pycom Limited. # # This software is licensed under the GNU GPL version 3 or any # later version, with permitted additional terms. For more information # see the Pycom Licence v1.0 document supplied with this file, or # available at https://www.pycom.io/opensource/licensing # """ LoPy Node configuration options """ import machine import binascii import struct WIFI_MAC = binascii.hexlify(machine.unique_id()).upper() # Set the Node ID to be the first 3 bytes of MAC address + 'FFFE' + last 3 bytes of MAC address NODE_ID = WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12] # create an OTA authentication params DEV_EUI = binascii.unhexlify('0x') APP_EUI = binascii.unhexlify('0x') APP_KEY = binascii.unhexlify('0x') DEV_ADDR = struct.unpack(">l", binascii.unhexlify('0x'))[0] NWK_SWKEY = binascii.unhexlify('0x') APP_SWKEY = binascii.unhexlify('0x') # for EU868 # LORA_FREQUENCY = 868100000 # LORA_GW_DR = "SF7BW125" # DR_5 # LORA_NODE_DR = 5 # for US915 # LORA_FREQUENCY = 903900000 # LORA_GW_DR = "SF7BW125" # DR_3 # LORA_NODE_DR = 3 # for AU915 LORA_FREQUENCY = 916800000 LORA_GATEWAY_DR = "SF7BW125" LORA_NODE_DR = 5 main.py #!/usr/bin/env python # # Copyright (c) 2019, Pycom Limited. # # This software is licensed under the GNU GPL version 3 or any # later version, with permitted additional terms. For more information # see the Pycom Licence v1.0 document supplied with this file, or # available at https://www.pycom.io/opensource/licensing # """ ABP Node example compatible with the LoPy Nano Gateway """ from network import LoRa import socket import binascii import struct import time import config # initialize LoRa in LORAWAN mode. # Please pick the region that matches where you are using the device: # Asia = LoRa.AS923 # Australia = LoRa.AU915 # Europe = LoRa.EU868 # United States = LoRa.US915 lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915) # remove all the channels for channel in range(0, 72): lora.remove_channel(channel) # # set all channels to the same frequency (must be before sending the OTAA join request) # for channel in range(0, 72): # lora.add_channel(channel, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=config.LORA_NODE_DR) # set the 3 default channels to the same frequency lora.add_channel(0, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=config.LORA_NODE_DR) lora.add_channel(1, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=config.LORA_NODE_DR) lora.add_channel(2, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=config.LORA_NODE_DR) # join a network using ABP lora.join(activation=LoRa.ABP, auth=(config.DEV_ADDR, config.NWK_SWKEY, config.APP_SWKEY)) # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR) # make the socket non-blocking s.setblocking(False) for i in range (200): pkt = b'PKT #' + bytes([i]) print('Sending:', pkt) s.send(pkt) time.sleep(4) rx, port = s.recvfrom(256) if rx: print('Received: {}, on port: {}'.format(rx, port)) time.sleep(6) Connecting to COM11... Sending: b'PKT #\x00' Sending: b'PKT #\x01' Sending: b'PKT #\x02'
  • Feeding Expansion Board v3
    expansion board power in vin
  • LoPy - Pybytes - LoRA
  • Lopy with modbus
    @svonbentzel No, for me too. I have use this one for get modbus run fine: github.com/pycom/pycom-modbus/tree/master/uModbus
