• LoRa Problem with 1.10.2.b1 FW
    lora
    Just no LoRa ints getting through. Found a discussion on github about adding a 50mS delay in the while loop of the main program and now I am getting packets through. I need to understand the interrupt processing better. It should break out of a tight while loop with an interrupt but seems like it doesn't. I also had to add a sleep delay after boot before loading our BT code or the device would core dump with this version of code. Here's the link: https://github.com/pycom/pycom-micropython-sigfox/issues/102
  • LoPy Lora issue connecting to Multitech conduit
    lora multitech lopy
    a) Yes, 2nd pin and 4th pin on the other side and are clearly labeled GND and G23 b) Yes, I'm using the same COM port with TeraTerm to run a script... So it must be the right one
  • Easy way to fade the on-board LED?
    lopy led rgbled fade
    @livius Thanks! I couldn't figure it out (quite new to python).. Ended up with this: def rgb_to_hex(red, green, blue): """Return color as #rrggbb for the given color values.""" return '%02x%02x%02x' % (red, green, blue) for i in range(256): color = rgb_to_hex(i,i,i) pycom.rgbled(256-int(color,16)) time.sleep(0.005) This just fades from white to off, removing the '256' fades from off to white.. Probably not the smoothest way to do it, but it works. :)
  • What is the best way to send downlink data?
    data lora
  • Terminal Shield for Lopy / Wipy
    lopy wipy shield
    Here is what it looks like mounted to a DIN rail platform. I haven't soldered the other terminals on yet.. [image: 1512701280654-sss-resized.jpg]
  • Pymakr atom plugin only syncing boot.py
    lopy sync problem
    @iplooky FYI this 'GetOverlappedResult' error on windows has now been solved with Pymakr 1.2.2. Let me know if it works for you!
    Did you give every node an unique dev_eui?
  • LoPy stopped working, gets hot, Broken?
    support
    Just tried updating the firmware. Lights blink on my UART board however it said failed. [image: 1512337728173-screenshot-from-2017-12-03-21-36-42.png] Connected GP23 to GND like I did originally to update the firmware. Rather odd as I took precautions to make sure I used only the 3v3 UART however like explained It was just plugged in normally when it stopped working. Odd! I'll return it to the retailer and request a replacement as I was rather enjoying it. Thanks
  • LOPY Timer interrup
    timer interrup real time chang frequency
    @jmarcelino thanks. I'll wait and try.
  • Lopy nano gateway transmits data via UART
    lopy gateway
    Yesterday i was testing ADR on LoPy with confirmed packets. I achieved that LoPy change to a SF8BW125 but no more, the communication range was the same. I forced the LoPy to transmit at SF12 in the socket configuration, and the range is the same too... I looked from lora.tx_power() and the value is 13, i think 13 dBm. About 100 meters in line vision, the gateway measured SNR = 8 dB and RSSI = -78 dB ... it is OK?
  • Lopy with pysense shield + deep sleep issues
    deep sleep lopy pysense
    @andy12 said in Lopy with pysense shield + deep sleep issues: wake_s = ds.get_wake_status() Hi, I have the same problem, maybe Did you resolve it?
  • pycom.nvs_get...
    pin lopy
    have you tried something like this? power = pycom.nvs_get('POWER') if not power: print(".........
    @eric24 That is the plan, although it might not come on the first firmware releases. Since LoRa/LoRaWAN (Class A) or Sigfox don't really have a "connection", they just send uplinks or wait to receive for very well determined periods it should certainly be possible to send for example one packet over LoRa and switch to Sigfox for the next one and so on.
  • How to decode the data in the Nanogateway example?
    lopy nanogatewa data lopy
    Thank you, that was really helpful. The online decoder works perfectly. When I searched for Lorawan decoder I got also some really useful links.
    You do not need 0.5 ppm at least not for 125/250/500 kHz bandwidth.
    @danielm said in No more LoRa packet reception after updating firmware: https://github.com/pycom/pycom-micropython-sigfox/issues/102 Daniel is currently out on a business trip so is quite busy. I will remind him about this issue.
  • LoPy in New Zealand
    lopy lo1
    ahaw021A
    LoRaWAN you should be ok if you use the Australian/NZ 915-928 frequencies Note: when you use the examples from the github use the US 915 codebase for the server and client https://github.com/pycom/pycom-libraries/tree/master/examples/lorawan-nano-gateway there is a youtube video about this code. Search pycom alexs corner https://www.thethingsnetwork.org/wiki/LoRaWAN/Frequencies/By-Country
  • UNIX Time
    21
    8k Views
    @jmarcelino It works for me now! I had to enable NTP client using the command line in Windows. Before that, "rtc.synced()" was returning False. Thanks.
  • Timer Alarm settings
    @soren https://stackoverflow.com/questions/14301967/python-bare-asterisk-in-function-argument to set something as named parameter specify its name and value ms=15
