  • LoPy Lora error correction
    lopy lora error sending
  • Get Client Mac Address in GATTSService/Characteristic
    ble lopy lopy ble
    ledbelly2142L
    We created a service with multiple characteristics but could only see the first characteristic using BLE scanner.
  • DeepSleep Shield & LoPy
    lopy deepsleep
    Also measuring over 500 uA with a LoPy + deep sleep shield, which is a shocking amount of current. To continue using the LoPy, i have had to use a humungus sized battery (6600 mAh) and shorten the life-span of the device. Please fix this pycom guys. This has taken far too long! I like the LoPy, but if this is not fixed pretty soon i will be forced to switch to a low power arduino alternative.
  • Lopy continues to restart and then stops !!!
    lopy reboot update
    @jmarcelino , @robert-hh After the flash is deleted and the refresh seems to work with the latest release ... we hope well.. Thanks to everyone for help Regards [image: 1504513403378-lopy-ok-resized.png]
    Dear Emmanuel, As i mentioned in my reply about a month ago, i could get it working when shifting the frequency a bit. Not sure what is causing it, but then communication could be established as well for uplink, downlink message as join requests.
  • How to set a specific IP Address in boot.py
    lopy static ip
  • LoPy FTP not working
    lopy ftp upload error
    @robert-hh Thank you, that did it (Setting the single connection only).
  • LoPy Brownout detector trigered with last firmware .
    lopy power brownout
    SmeedyS
    This was due to a change in the ESP32 IDF a couple of month ago. I've seen the brownout also in some C projects on the WROOM32. Make sure you can compensate when the MCU is spiking in power consumption by placing a big capacitor in the circuit. Google is your friend.
  • e-Paper Display
    e-paper display
  • LoPy with 3.3V direct powering fails to start.
    lopy power fault 3v3 issues
    24
    10k Views
    @jcaron Isn't this the opposite of what what stated here: Not completely the opposite, it's still more efficient to use a regulated 3.3V supply (low voltage forces the onboard regulator into bypass ECO mode) But it needs to be updated to reflect that 3.3V should be applied to the 5V/VIN pin. Is the Pysense/Pytrack sending power to the module via 5V Yes, all the various shields implementing deep sleep control the *py board's 5V rail
  • LoRa.ABP Downlink messages no receive
    lora ttn downling abp
    @jcaron I know that you must perform an uplink in order to have a downlink. The strange thing is that the nanogateway makes the LoRa TX but nothing is received. Nano Gateway code """ LoPy Nano Gateway class """ from network import WLAN from network import LoRa from machine import Timer from network import Server as tcpserver import os import binascii import machine import json import time import errno import _thread import socket PROTOCOL_VERSION = const(2) PUSH_DATA = const(0) PUSH_ACK = const(1) PULL_DATA = const(2) PULL_ACK = const(4) PULL_RESP = const(3) TX_ERR_NONE = "NONE" TX_ERR_TOO_LATE = "TOO_LATE" TX_ERR_TOO_EARLY = "TOO_EARLY" TX_ERR_COLLISION_PACKET = "COLLISION_PACKET" TX_ERR_COLLISION_BEACON = "COLLISION_BEACON" TX_ERR_TX_FREQ = "TX_FREQ" TX_ERR_TX_POWER = "TX_POWER" TX_ERR_GPS_UNLOCKED = "GPS_UNLOCKED" STAT_PK = {"stat": {"time": "", "lati": 0, "long": 0, "alti": 0, "rxnb": 0, "rxok": 0, "rxfw": 0, "ackr": 100.0, "dwnb": 0, "txnb": 0}} RX_PK = {"rxpk": [{"time": "", "tmst": 0, "chan": 0, "rfch": 0, "freq": 868.1, "stat": 1, "modu": "LORA", "datr": "SF7BW125", "codr": "4/5", "rssi": 0, "lsnr": 0, "size": 0, "data": ""}]} TX_ACK_PK = {"txpk_ack":{"error":""}} class NanoGateway: def __init__(self, id, frequency, datarate, ssid, password, server, port, ntp='pool.ntp.org', ntp_period=3600): self.id = id self.frequency = frequency self.datarate = datarate self.sf = self._dr_to_sf(datarate) self.ssid = ssid self.password = password self.server = server self.port = port self.ntp = ntp self.ntp_period = ntp_period self.rxnb = 0 self.rxok = 0 self.rxfw = 0 self.dwnb = 0 self.txnb = 0 self.stat_alarm = None self.pull_alarm = None self.uplink_alarm = None self.udp_lock = _thread.allocate_lock() self.lora = None self.lora_sock = None def start(self): # Change WiFi to STA mode and connect print("Starting nanogateway") self.wlan = WLAN(mode=WLAN.STA) self._connect_to_wifi() # Get a time Sync self.rtc = machine.RTC() self.rtc.ntp_sync(self.ntp, update_period=self.ntp_period) # Get the server IP and create an UDP socket self.server_ip = socket.getaddrinfo(self.server, self.port)[0][-1] print("Gateway IP:",self.server_ip) self.sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM, socket.IPPROTO_UDP) self.sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1) self.sock.setblocking(False) # Push the first time immediatelly self._push_data(self._make_stat_packet()) # Create the alarms self.stat_alarm = Timer.Alarm(handler=lambda t: self._push_data(self._make_stat_packet()), s=60, periodic=True) self.pull_alarm = Timer.Alarm(handler=lambda u: self._pull_data(), s=25, periodic=True) # Start the UDP receive thread _thread.start_new_thread(self._udp_thread, ()) # Initialize LoRa in LORA mode self.lora = LoRa(mode=LoRa.LORA, frequency=self.frequency, bandwidth=LoRa.BW_125KHZ, sf=self.sf, preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True) # Create a raw LoRa socket self.lora_sock = socket.socket(socket.AF_LORA, socket.SOCK_RAW) self.lora_sock.setblocking(False) self.lora_tx_done = False self.lora.callback(trigger=(LoRa.RX_PACKET_EVENT | LoRa.TX_PACKET_EVENT), handler=self._lora_cb) print("Started") def stop(self): # TODO: Check how to stop the NTP sync # TODO: Create a cancel method for the alarm # TODO: kill the UDP thread self.sock.close() def _connect_to_wifi(self): self.wlan.connect(self.ssid, auth=(None, self.password)) while not self.wlan.isconnected(): time.sleep(0.5) print("WiFi connected!") tserver=tcpserver() tserver.deinit() tserver.init(login=("nemet", "nemet.gr"), timeout=60) def _dr_to_sf(self, dr): sf = dr[2:4] if sf[1] not in '0123456789': sf = sf[:1] return int(sf) def _sf_to_dr(self, sf): return self.datarate def _make_stat_packet(self): now = self.rtc.now() STAT_PK["stat"]["time"] = "%d-%02d-%02d %02d:%02d:%02d GMT" % (now[0], now[1], now[2], now[3], now[4], now[5]) STAT_PK["stat"]["rxnb"] = self.rxnb STAT_PK["stat"]["rxok"] = self.rxok STAT_PK["stat"]["rxfw"] = self.rxfw STAT_PK["stat"]["dwnb"] = self.dwnb STAT_PK["stat"]["txnb"] = self.txnb return json.dumps(STAT_PK) def _make_node_packet(self, rx_data, rx_time, tmst, sf, rssi, snr): RX_PK["rxpk"][0]["time"] = "%d-%02d-%02dT%02d:%02d:%02d.%dZ" % (rx_time[0], rx_time[1], rx_time[2], rx_time[3], rx_time[4], rx_time[5], rx_time[6]) RX_PK["rxpk"][0]["tmst"] = tmst RX_PK["rxpk"][0]["datr"] = self._sf_to_dr(sf) RX_PK["rxpk"][0]["rssi"] = rssi RX_PK["rxpk"][0]["lsnr"] = float(snr) RX_PK["rxpk"][0]["data"] = binascii.b2a_base64(rx_data)[:-1] RX_PK["rxpk"][0]["size"] = len(rx_data) return json.dumps(RX_PK) def _push_data(self, data): token = os.urandom(2) packet = bytes([PROTOCOL_VERSION]) + token + bytes([PUSH_DATA]) + binascii.unhexlify(self.id) + data with self.udp_lock: try: self.sock.sendto(packet, self.server_ip) except Exception: print("PUSH exception") def _pull_data(self): token = os.urandom(2) packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_DATA]) + binascii.unhexlify(self.id) with self.udp_lock: try: self.sock.sendto(packet, self.server_ip) except Exception: print("PULL exception") def _ack_pull_rsp(self, token, error): TX_ACK_PK["txpk_ack"]["error"] = error resp = json.dumps(TX_ACK_PK) packet = bytes([PROTOCOL_VERSION]) + token + bytes([PULL_ACK]) + binascii.unhexlify(self.id) + resp with self.udp_lock: try: self.sock.sendto(packet, self.server_ip) except Exception: print("PULL RSP ACK exception") def _lora_cb(self, lora): events = lora.events() if events & LoRa.RX_PACKET_EVENT: self.rxnb += 1 self.rxok += 1 rx_data = self.lora_sock.recv(256) print("LoRa_RX:",rx_data) stats = lora.stats() self._push_data(self._make_node_packet(rx_data, self.rtc.now(), stats.rx_timestamp, stats.sfrx, stats.rssi, stats.snr)) self.rxfw += 1 if events & LoRa.TX_PACKET_EVENT: self.txnb += 1 lora.init(mode=LoRa.LORA, frequency=self.frequency, bandwidth=LoRa.BW_125KHZ, sf=self.sf, preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True) def _send_down_link(self, data, tmst, datarate, frequency): self.lora.init(mode=LoRa.LORA, frequency=frequency, bandwidth=LoRa.BW_125KHZ, sf=self._dr_to_sf(datarate), preamble=8, coding_rate=LoRa.CODING_4_5, tx_iq=True) while time.ticks_us() < tmst: pass print("LoRa_TX",data) self.lora_sock.send(data) def _udp_thread(self): while True: try: data, src = self.sock.recvfrom(1024) _token = data[1:3] _type = data[3] if _type == PUSH_ACK: print("Push ack") elif _type == PULL_ACK: print("Pull ack") elif _type == PULL_RESP: self.dwnb += 1 ack_error = TX_ERR_NONE tx_pk = json.loads(data[4:]) tmst = tx_pk["txpk"]["tmst"] t_us = tmst - time.ticks_us() - 5000 if t_us < 0: t_us += 0xFFFFFFFF if t_us < 20000000: self.uplink_alarm = Timer.Alarm(handler=lambda x: self._send_down_link(binascii.a2b_base64(tx_pk["txpk"]["data"]), tx_pk["txpk"]["tmst"] - 10, tx_pk["txpk"]["datr"], int(tx_pk["txpk"]["freq"] * 1000000)), us=t_us) else: ack_error = TX_ERR_TOO_LATE print("Downlink timestamp error!, t_us:", t_us) self._ack_pull_rsp(_token, ack_error) print("Pull rsp") except socket.timeout: print("Socket Timeout") except OSError as e: if e.errno == errno.EAGAIN: #print("UDP recv errno.EAGAIN") pass else: print("UDP recv OSError Exception") except Exception: print("UDP recv Exception") # Wait before trying to receive again time.sleep(0.025) Node code from network import LoRa import socket import binascii import struct import time import pycom pycom.heartbeat(False) # Initialize LoRa in LORAWAN mode. lora = LoRa(mode=LoRa.LORAWAN) # create an ABP authentication params dev_addr = struct.unpack(">l", binascii.unhexlify('260110AD'.replace(' ','')))[0] nwk_swkey = binascii.unhexlify('2F8184207979F18CE1F64B6B74B75A99'.replace(' ','')) app_swkey = binascii.unhexlify('53A7AA9AFA94FEB1F859F76EF5E0BA4C'.replace(' ','')) # join a network using ABP (Activation By Personalization) lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey)) # remove all the non-default channels for i in range(3, 16): lora.remove_channel(i) # set the 3 default channels to the same frequency lora.add_channel(0, frequency=868100000, dr_min=0, dr_max=5) lora.add_channel(1, frequency=868100000, dr_min=0, dr_max=5) lora.add_channel(2, frequency=868100000, dr_min=0, dr_max=5) # create a LoRa socket s = socket.socket(socket.AF_LORA, socket.SOCK_RAW) # set the LoRaWAN data rate s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5) # make the socket blocking s.setblocking(False) i = 1 while True: pycom.rgbled(0x100000) print("sending:",i,i % 255,"msg:",struct.pack('LB',i,i % 255)) s.send(struct.pack('LB',i,i % 255)) time.sleep(1) pycom.rgbled(0x001000) for k in range(29): rx = s.recv(256) if rx: print("RX:",rx) time.sleep(1) i += 1
  • LoRa TTN never joined but I can see the requests on TTN
    Moved lopy lora 868 ttn
    @jmarcelino It works as it should be. Many thanks for your advice. You are always right! I also have problem with downlink messages thru ttn console...
  • Solar Lipo charger
    solar battery charger lopy
    @JimT Sorry, I could have told you. You may use a 1N4001 model (or any of the 1N400x series). You have to put that in series to the solar module, Anode of the diode at the + pin of the solar module, Kathode (the side with the ring on the diode case) to the charger module's + input. Doing that, the voltage of the solar panel will be reduced by about 0.7 V. I would add a small load too behind the diode, to cap the no-load case, like by a 1 k resistor at the chargers module input between + and GND. You can use the additional power in lead pads of the charger module for that. I see that the module has already a built in diode, but that is a MPB120 Schottky type and reduces the Voltage only by 0.3 V.
    ledbelly2142L
    @jmarcelino Once again, thanks for the great feedback. I was looking for a simple way to alert when the battery needs to be recharged. Looks like some simple logic could be: if voltages gets to 3.3, alert for recharge... So many LiPo batteries have differing characteristics, even among the same model/make/capacity/manufacturer. I don't think there is real value is tracking a percentage... without extensive battery testing. Simplest thing to do is just report voltage. From the example from HERE do you recommend using the following: numADCreadings = const(100) def ADCloopMeanStdDev(): adc = machine.ADC(0) adcread = adc.channel(attn=1, pin='P16') samplesADC = [0.0]*numADCreadings; meanADC = 0.0 i = 0 while (i < numADCreadings): adcint = adcread() samplesADC[i] = adcint meanADC += adcint i += 1 meanADC /= numADCreadings varianceADC = 0.0 for adcint in samplesADC: varianceADC += (adcint - meanADC)**2 varianceADC /= (numADCreadings - 1) print("%u ADC readings :\n%s" %(numADCreadings, str(samplesADC))) print("Mean of ADC readings (0-1023) = %15.13f" % meanADC) print("Mean of ADC readings (0-1400 mV) = %15.13f" % (meanADC*1400/1024)) print("Variance of ADC readings = %15.13f" % varianceADC) print("10**6*Variance/(Mean**2) of ADC readings = %15.13f" % ((varianceADC*10**6)//(meanADC**2))) print("ADC reading for Voltage (0-1400 mV) = %15.4f" % (meanADC*1400/1024)) From the ACD pin 16 voltage, the voltage is the meanACD*1400/1024 Does not seem right, the output is 4966.3634.
    @stef , sensor type Pycon should be avail: [image: 1504110987993-upload-1a444523-8dc6-46da-9fee-46a782b7b215-resized.png]
  • BLE Crash
    ble
    Is anything happening with this bug. Every LoPy I update to 1.7.9 now crashes with this error. It wouldn't be as big of an issue if Pycom would let us select which firmware to flash on the board.
  • Program is erased from internal memory
    lopy internal flash
    You need to close the file as soon as the write is complete. If the unit shuts down while the file is open there's a good chance to corrupt the flash. This will erase the flash when it reboots.
