  • General software tool discussion
    5 Topics
    To my greatest regret the FireFTP of Firefox is not supported any more since Version 60 of FireFox. That ftp client was always easy and fast to use. OK, FileZilla and command line ftp work too, but FireFTP was more convenient. Sigh ........
  • Software tool wishlist & desired features
    9 Topics
    Heya, There is currently no system in place to export data. but one should be ready soon. Paul
  • Anything related to software tool issues & bugs
    86 Topics
    I think there could be several causes for this problem. It could be because your network connection is unstable. Or your time like the date and time on your device is set wrong. It could also be because you are trying to register more devices than the device registration limit.
  • Pymate and LoPy
    pymate
  • SmarIoT: A Barebones REST App
    other
  • VSCode and Pymakr Broken?
    pymakr bug
    We've just uploaded a new version (0.1.6) that works on windows x64. Try it out and let me know if your problem is fixed.
  • Restart code when micropython throws error
    other
    @aptusmarvin you can use also watchdog https://docs.pycom.io/chapter/firmwareapi/pycom/machine/WDT.html
  • pybytes login data
    pybyte
    @jmarcelino thank you for the answer
  • Atom + PyMakr Plugin: Console not working
    pymakr
    @heut have a look in the thread of the latest firmware update. Either you wait until monday for the next fix or you can try to outcomment your UART settings in boot.py/main.py
  • PyMate (iOS) does not connect to WiPy 2.0
    pymate pymakr
    Hello everyone, I was able to rebuild the iOS Pymate app for iOS 11.0.2 and I'm getting some very basic functionality out of it. There are still some bugs that I need to fix before I can try to submit this new version to the Apple App Store. There are also some aesthetic issues but I'm ignoring them for now. I'm hoping to have some more news in the next few days.
  • Bone Idle
    pymakr
    Too bad to hear that you dislike the plugin. If you have time, please let us know some specific things you think that can be improved in your opinion. We're always open to feedback.
  • Debugger gives wrong line numbers
    bug
  • pymakr repl dump output
    pymakr
    @robert-hh that should do the work. thanks!
  • pymakr plugin + atom
    pymakr bug
    ledbelly2142L
    Not sure what operating system you are using... If you have Windows you could try VS Code instead of Atom. If you are on Windows, you should try using Atom version 1.18 with the Pymakr plugin. More about Atom and Pymakr plugin issues on Github HERE More info if you are using Windows 10: The easiest way to fix this for Windows 10 is to downgrade to Atom 1.18, you can download it from here: https://github.com/atom/atom/releases?after=v1.19.0-beta5 half way down the page is version 1.18, I downloaded the AtomSetup.exe file for windows10. Make sure you don't upgrade to 1.19 or above until the Pymakr plugin is fixed. Also Atom is by default set to auto update so as soon as you open it, go to menu >>> help >>> about atom Then un-check the "Automatically download updates" Then install the Pymakr package. From Menu >>> Packages >>> Settings View >>> Install Packages In the Install Packages search box, type in pymakr, it's down a couple in the search, press 'Install' I had to remove the pymakr package manually because I had Atom previously installed. It's located something like c:\users\yourusername.atom\packages I have it all working, now dealing with a serial port connection issue. Can't connect with all the default settings and the correct com port (com6 port etc... )
  • [FOSS] Sigfox Companion App
    pymate
  • Need Help with VSCode Pymakr
    pymakr
    Ralph I was using VSC for an extended period earlier today. The board kept losing connection to my PC. I had to keep resetting and re connecting. Eventually my PC crashed (bluescreen) with an error of "Memory Issue" or similar with root cause being ftser2k.sys which I think is the FTDI driver. The program I was working on involved reading a BLE beacon if that's relevant. As this may be related to the issue I thought I would let you know. BTW I switched to ATOM and am not having the same issue (so far!)
  • How can I clear Serial Terminal screen using Atom/Pymakr plugin?
    pymakr
    Will add this feature to the task list. Right now you can clear it by closing and opening the terminal.
  • Add /sd folder to the Atom Project
    pymakr
  • Pymate docs
    pymate
    Hi @BetterAuto, You are correct - there isn't anything available currently - this will change in the near future as we're planning on making some updates and changes with it and how it integrates with the upcoming PyBytes platform. Please bear with us, thanks!
  • Sync not working with latest Atom plugin?
    bug
    Same here. Sync does not work reliably with pymakr and the plugin. It says sync finished and then when i opent the device with filezilla main.py is 0 bytes.
  • VSCODE Plugin
    enhancement pymakr
    @livius ok. Thanks. I can see the method used in that source. DOCS for the file transfer API would be really useful too but this will get me started. Thanks
