  • General software tool discussion
    5 Topics
    To my greatest regret the FireFTP of Firefox is not supported any more since Version 60 of FireFox. That ftp client was always easy and fast to use. OK, FileZilla and command line ftp work too, but FireFTP was more convenient. Sigh ........
  • Software tool wishlist & desired features
    9 Topics
    Heya, There is currently no system in place to export data. but one should be ready soon. Paul
  • Anything related to software tool issues & bugs
    86 Topics
    I think there could be several causes for this problem. It could be because your network connection is unstable. Or your time like the date and time on your device is set wrong. It could also be because you are trying to register more devices than the device registration limit.
  • VS Code COM port setting ignored
    bug pymakr
    I also could not connect to my board and solved the problem as follows: If your PC has Bluetooth, have you ever tried to turn off Bluetooth? On my PC, Bluetooth uses COM3. Pymark always tried to connect to COM3. After I turned off Bluetooth, I was able to connect to my Pycom board without any problems. Once a connection to the board has been established, the board can also reconnect successfully with Bluetooth turned on. I hope this information helps. (: In my case COM3 is used by Bluetooth and Pymark tries to connect to COM3. [image: 1630835630712-85fee3ed-fbf7-4c3a-aafa-7c2e4310b551-image.png] In this menu you can disable Bluetooth [image: 1630835590640-a2ac2595-41ee-4d30-98cf-a1336265b5ab-image.png] Connection to the board has been established successfully: [image: 1630835997595-72640caf-babc-4421-aa13-34d4d1ce8800-image.png]
  • Cant install Pymakr in Atom
    That diagnostic seems to reference VisualStudio rather than Atom. The pymakr plugins for VS & Atom are different as far as I know, are you sure you have the right one? As far as Atom goes you probably need to roll back. https://forum.pycom.io/topic/6970/pymakr-not-compatible-with-atom-1-56/7
  • Not able to connect to Pysense via Atom, VSCode or Putty.
    @simon-tischler Re-flashing fixed the issue. Thank you very much.
  • Pymakr 1.1.8 VS Code - Failed to Connect
    I just downgraded my VSCode to 1.52.1 (November 2020), forgot to disable auto-upgrades, and it re-upgraded to 1.53.2. Although was the same version as before, now the pymakr plugin is working correctly with my lopy... Running on Windows 10, using FTDI usb-serial with W10 usb serial driver....
  • Pymakr connection timed out, REPL accessible via screen
    I'm also having the same issue on VSCode. I can't downgrade to an earlier version.
  • I need help with pybyte
    Could you perhaps elaborate on the issues you are experiencing? Below I have provided an example of how to setup a connection to pybytes (and make sure that it is activated on boot) https://docs.pycom.io/pybytes/gettingstarted/#step-3-provision-your-device You can then use pybytes.send_signal(1, your data) to make it show up on the platform Gijs
  • Recent Vs Code update, no more Pymakr
    @martin-golding PS.. you have to set the update Mode to NONE [image: 1612521555268-cb9af29c-b5dc-4f39-8f03-6057d5e6f781-image.png]
  • Bulk programming
    pymakr other
    You can try this technology https://itmaster-soft.com/en/angular-development-services
  • pycom-fwtool-cli does not work on macOS Big Sur
    I have not run into issues this far. You will need to update the pyserial package though (if i remember correctly) using pip3 install -U --pre pyserial Gijs
  • Erasing flash via pycom-fwtool-cli with barebones LoPy4
    @robert-hh Thanks for the mention of the -c option! I did not know this, but it works! No more resets needed between commands. And yes, I understand that I do not need to erase the flash every time I load a new firmware. But my example was trying to show that any 2 commands in a row had the same behaviour, for example: Run pycom-fwtool-cli -p COM7 lpwan The correct output is shown, with the SMAC, SID, PAC and LORA REGION Run pycom-fwtool-cli -p COM7 lpwan once again, without resetting LoPy The same error occurs: Exception: Failed to connect to ESP32: Timed out waiting for packet header Now, with the -c option enabled, the procedure above works! Thanks so much!
  • Automatic release deployment - wanted feature
    @troy-salt it should definitely be something you can control, though, so you can decide to which version you want to upgrade, and which devices should be upgraded. Many past firmware versions have broken quite a few things, so you need to be able to test any new firmware on a limited set of test devices before deploying it widely.
  • Upgrade Pygate firmware
    @papasmurph I just ran into the same issue even though I checked the "include development Software" and I had the boards (patate and WiPy) already setup and running before I did the upgrade. I tried to clear the user space as well and go through a clean build but still stuck. I am stuck with the same error : Starting LoRaWAN concentrator Traceback (most recent call last): File "main.py", line 26, in <module> AttributeError: 'module' object has no attribute 'callback' Pycom MicroPython 1.20.2.r0 [v1.11-783192e] on 2020-08-06; WiPy with ESP32 Pybytes Version: 1.5.1 Anyone faced this issue ?
  • Sigfox region selection
    @pabloIsrael16 Thank you very much the update was successful.
  • How to config loragw_hal registers for the PyGate
    @Gijs Understood. Is there an ETA that you could share for the code release? Thanks, Cheers, Paul
  • New file detection sucks + files not being overwritten...
    techykermitT
    We are not using the serial connection, we are using USB. But I can get back to you in a couple of days when we have a serial converter available. Thank you for the suggestion! :)
  • Mac - VS Code - PyMakr
    @pyfun thanks, figured it as well, would prefer VS code still
