  • General software tool discussion
    5 Topics
    To my greatest regret the FireFTP of Firefox is not supported any more since Version 60 of FireFox. That ftp client was always easy and fast to use. OK, FileZilla and command line ftp work too, but FireFTP was more convenient. Sigh ........
  • Software tool wishlist & desired features
    9 Topics
    Heya, There is currently no system in place to export data. but one should be ready soon. Paul
  • Anything related to software tool issues & bugs
    86 Topics
    I think there could be several causes for this problem. It could be because your network connection is unstable. Or your time like the date and time on your device is set wrong. It could also be because you are trying to register more devices than the device registration limit.
  • today visual studio code + pymakr + ubuntu 17.04 64bit
    pymakr
    Hi @james Could you try reinstalling VSCode and Pymakr? I've tried 1.27.2 and it works fine, so it might be something with your config. I haven't seen this issue yet, so it might be related to something else.
  • "Run" and "Upload" buttons gone after deep sleep wake up in Atom
    pymakr
    Yup, still the same lack of buttons after disconnect/reconnect
  • VSCode 1.26.1 - Breaking Change?
    pymakr bug
    Thanks heaps @dan Its working fine for me now on VSCode 1.27.2 :-)
  • Console on Atom is hard to read
    pymakr enhancement
    in this section, there was only : #terminal { background: #000; padding-left: 2px; } I have added the line : font-size: 16px; and that is better to read , thanks !
  • Prepare firmware for flashing with firmware upgrade tool
    other
    Thank you! Worked on first try! Johan
  • Pymakr Atom REPL console
    pymakr bug
    @alvaroav Good to hear it's solved. I'm still not sure if it's another plugin, because another user had this and it was gone after a window reload. Might be some edge case in button usage.
  • Pymakr @ 25,000
    pymakr
    That's a lot! I did not expect that when we started working on the plugin :) Thanks for posting!
  • can not install pymakr in atom 1.28.0
    pymakr
    @ralph Thanks for the fix. We appreciate it! Chris
  • can not install pymakr 1.3.2 in atom 1.27.2
    pymakr
    OK Ralph, It wil work now
  • Workable editor for Windows virtual machine
    pymakr
    @charly86 No idea. I ran it once, and it worked. Now that I tried it again, it fails. I can get the file listing, but cannot download files. Normally, I use FireFTP, since I have anyhow Firefox running most of the time.
  • Pybytes and LTE
    pybyte
    @orcua I'm not sure. I'll ping the Pybytes team and ask them to post here
  • Unable to install Pymakr 1.2.10 in Atom 1.25.0
    pymakr
    @seb Thanks. Did the trick. Remove directory, reinstall and rebuild the package Thx, Geert
  • hmac on on lopy
    other
    @this-wiederkehr Seems to work perfectly fine. Even calling it multiple times (from REPL at least) works. Thanks alot! Also for the quick response.
  • Pymakr stopped working in Atom 1.25
    pymakr
    HI @smbunn, thanks for reporting, sorry for not having this issue fixed yet. We spent some time today re-compiling the serialport-lib that's in Pymakr for Atom 1.25. It hasn't succeeded yet for all operating systems. There is a new release of pymakr v1.2.10 which contains new precompiles for osx and win64, but the latter still has issues. Bear with us on this, we'll be sure to fix it in the next days. And there's always VSCode to fall back to for a few days. I'll keep you up to date.
  • Atom with Pymakr have some promble
    pymakr bug
    @u0452047: I think you should put it in the categories Bug/Issues
  • pycom-fwtool-cli
    other bug enhancement
    @seb Yes I meant copying single files. I installed mpfshell and this can do the job for me. I did use an FTP toool for this, bud when using the WiFi radio in my app I constntly had to switch between IP addresses. Thanks again.
  • MicroPython Plugin for PyCharm
    other
    8 Votes
    I've been using Atom with it's plugin and it's been working well for me. It's got it's quirks and feels clunky, but it gets the job done. I would like to see a proper plugin for PyCharm however, because I like that IDE.
  • Sublime Text 3 + PyMakr .... Status?
    pymakr
    Hi, At this time the plans to make a sublime text plugin have been cancelled, I will remove this from the documentation
    Connect a jumper between P12 and 3.3V and press the reset button, this will cause the onboard LED to flash orange, when you see this please remove the jumper. This puts the device into "safe boot", in this mode it will not run the boot.py and main.py files and drop you straight into the interactive REPL terminal
