@catalin said in PySense nonsense altitude readings:
You could look into datasheet for better explanations: https://www.nxp.com/docs/en/data-sheet/MPL3115A2.pdf
Yet another data sheet with complete non-sense... It's saying you should use OFF_H, when really the registers to use are BAR_IN_MSB/BAR_IN_LSB.
@seb or @catalin, it would probably be a good idea to add a function in PL3115A2.py to set this value.
self.i2c.writeto_mem(MPL3115_I2CADDR, MPL3115_BAR_IN_MSB, bytes([int(qnh*100/2) >> 8, int(qnh*100/2) & 255]))
Note that even with this, one should not expect a very precise altitude indication, it can vary several meters up or down. If you want a more precise altitude (and independence from the weather), you probably need to use a GPS.
