• Restart mqtt service?
    mqtt mqtt connect
  • LOPY with Raspberry pi 3
    lopy raspberry pi uart
    @livius i did already.. still the same problem.. Now i connected my lopy to raspberry pi through usb0 and putty.. the data bieng sent by raspberry pi is showing on the terminal instead of in uart.readall()...
  • Lopy LoRa socket timeout
    lopy lopy lorawan socket timeout
    @livius Thank you so much!!! that's exactly what I needed
  • LOPY on a lorawan public network,
    lopy lorawan join issues spreading facto
    Hello bruno, this is what I did, instead of using the exemple code, I can set and catch the timeout error hence loop while not joint. while lora.has_joined() is not True: try: lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=20000, dr=0) except Exception as e: print('Not joined yet...')
  • Fried Lopy
    bricked lopy
    @brotherdust Don't supply 3.3V to the 3.3V pin. This is an output only. It can burn up the power supply chip.
  • Memory leak
    Hi @colateral. Thanks for replying. My MemoryError issue was reported in https://forum.pycom.io/topic/2600/threads-generate-memoryerror-when-there-s-an-empty-while-cycle-not-necessarily-infinite/6
  • Blynk on LoPy
    blynk lopy sensors android app lora
    Hi @gruia-nichita I'm using LoPy with Blynk via WiFi, but am also interested in using it with LoRa, let me know if you find a solution (I haven't looked at LoRa+Blynk with enough detail yet...) I'm using BlynkLib : https://github.com/vshymanskyy/blynk-library-python
  • LoPy Bluetooth eddystone
    pycom bluetooth eddystone
  • Lopy4-Pytrack , CayenneLPP code for GPS.
    lopy4 pytrack cayennelpp gps
  • LoPy4 GPIO pins and LDO regulator
    lopy4 gpio regulator
    I can confirm @River is correct, the LDO automatically switches modes, there is no GPIO pin involved in this
  • Piezo element as input for ADC
    lopy piezo
  • OSError: [Errno 11] EAGAIN
    lopy oserror
    @wstallwood said in OSError: [Errno 11] EAGAIN: https://forum.pycom.io/topic/502/socket-send-msg-timeout Hi, in order to catch an error without crashing you can just wrap the call with: try: s.send(data) except OSError as e: if e.args[0] == 11: # EAGAIN error occurred, add your retry logic here A list of what all the error numbers mean can be found in this file: https://github.com/pycom/pycom-micropython-sigfox/blob/5bed5e9a84bb1abfc4d59476f3f62b38920c5eda/py/mperrno.h Onto why this error occurs, having a look at the lora source code you can find that this error is raised here: https://github.com/pycom/pycom-micropython-sigfox/blob/master/esp32/mods/modlora.c#L2082 This error is raised if send_lorawan returns zero, which can happen for two reasons, the message was added to the queue (which is what I believe you are refering to with the duty cycle limiting) or there was a LORA_STATUS_ERROR.
  • Multiple JOIN
    lora join nvramsave lorawan
    @brunos ! With s.setblocking (True) before s.send(), it's OK !!
  • Lopy & Pytrack sending data by Lora KPN network
    lora lopy
    Hello everybody, I have tested the Lopy with the gc.collect function. It isn`t giving a error message anymore! Thanks for the help.
  • ABP keys (nwk_swkey, app_swkey)
    otaa abp
    Z
    @jmarcelino One more 'beginners' question: how do I read data back from TTN?
  • LoRa antenna kit
    lora antenna
    @jmarcelino Is there any specification for official LoRa antenna kit? I would appreciate manufacturer name and type as well. Thanks! https://pycom.io/product/lora-antenna-kit/
  • Buffer size **SOLVED**
    Moved lopy lora solved
    @jeromemaquoi really better if you show some sample what do. As you can read here detail was provided by chat but better is write on the forum and ask question with sample and exact error message.
  • How to connect with a BLE device having a passkey using LoPy
    lopy ble
    Hi, We do not currently support connecting to bluetooth devices with a passcode. This feature is on our firmware roadmap and will be released in the future but I cannot provide a specific time frame.
