    @seb thanks... I look at that but I cant understand how I should do it spend alot of time with it :( and I cant get to a solution...
  • Lopy with VC0706
    lopy uart camera vc0706
    @matamune you can turn automatic gc on gc.enable() and also you can do manual gc.collect()
  • Read and write value of the characteristic
    characteristic python pysense lopy lopy ble
  • Two LoPys as a LoRa + TCP/IP bridge?
    lora
    @jmarcelino said in Two LoPys as a LoRa + TCP/IP bridge?: People have managed 10Km on such a setup. Only with udp kind "connection" modified wifi stack. I have self with normal wifi setup and directional antennas max ~600 m. But i have many wifi stations around and in industrial environment.
  • Lopy vs. L01 differences
    l01 differences lopy
    @jcaron Just added it
  • Requesting Manual Flashing procedure
    firmware update memoryerror
    @robert-hh Thanks will try and come back to you,
  • LOPY in case running on battery
    battery battery connect getting started new
    @thr If you are using Pytrack, connect the battery to the dedicated battery connector on Pytrack.
    @seb Yep! That fixed it. Thanks! Cheers, Thomas
  • Lopy OEM reference design?
    pcb lopy4
    You can also find the expansion board schematics here: https://github.com/wipy/wipy/tree/master/hardware/ExpansionBoard-v1.2
  • Lopy with pytrack, how connect/use GPS?
    gps lopy pytrack
    76
    34k Views
    @zceld I often see an issue like this when I have another atom window/tab open that is also connected to the same serial port. Can you make sure nothing else is trying to access the serial port?
  • LoRa Multicast
    lora lorawan
    Yes, this is the way I was trying to implement it, without success until I realized there was an error with the device address. So now, it works fine many thanks !
  • Country Code Setting
    countrycode country list
  • Security Hardening
    I've finally gotten around to doing a bit more, so I have a utility now on the device we run to "harden" them aside from setting some parameters in our code to disable debugging does two things. pycom.wifi_on_boot(False) (our project doesn't need the wifi radio at all and it better than halves the power consumption on the L01 we found) Then it writes the following into boot.py import os os.dupterm(None) Which disables the REPL Console, leaving only the initial boot messages generated by the ESP. The only easy way back in then is to short the pins on the module to perform a clean boot.
  • TTN OTAA join acknowledgement not being received ?
    ttn lorawan otaa
    @seb Yes, it's in the EU, 868 Region. Using ABP, I can connect, send messages from the node (FiPy) to the gateway (LoPy), they are reported on the TTN cosole, and they arrive in the test target, but downlink messages travel only to the gateway (LoPy), are sent out by the getaeway, but almost never the node confirms reception. This may block OTAA.
  • Visibility of LoRa traffic
    lopy ttn
  • Lopy + PyTrack + Gravity UART GSM/GPRS module
    lopy uart gsm
  • lib folder "not working"
    importerror lopy lib folder
    @livius thx for your advice, there haven't been a second pysense.py but a lot of other crap and folders, i deleted them now it is working fine! Thank you! i will now use ftp to upload my libs or at least check if everything is ok
  • LoraWan OTAA example without antenna
    lora ttn otaa
    @jmarcelino yup, thanks a lot.. i tried it outside and succeeded in getting the payloads as well..
  • LoPy4 Crash with NanoGateway
    lopy4 crash
    15
    @jmarcelino Thanks. I was thinking on something like the FT2232H. I would also say it is difficult but it is for an academic research, so I think it is worthy. :) I have just read that page, but today the OpenOCD page with the compatible JTAG adapters seems to have fallen.
  • LoPy + SP3485 + Modbus Lib Test. Register Read Error
    lopy modbus sp3485
    26
    9k Views
    @daniel Good afternoon, the modifications work perfect. Best regards. Mariano.
