• Trying to connect LoPy4 to Xiaomi MiBand 2
    lopy4 ble firmware
    @seb I tried, but still to no avail.
  • Short indoor range with LoPy
    lopy pytrack range lorawan lora
    Solved! Thanks again everyone. The problem was indeed that the antenna was mounted according to the specification for the LoPy1r, so it was actually on the LoRa 433-510 MHz antenna slot. After a quick range test I now receive packets at at least 400 meters distance. Many thanks, I thought I had gone crazy there for a while!
  • LoRaWan and MatchX
    lopy matchx
    @misterlisty I just told you what is work for me ..... BTW why did u remove channels? On this firmware u can set Region Eu, US AS from code without remove channels and add others ... Also you can try to set from your MatchX lbt_cfg": { "enable": false,
  • Changing port for sending data via LoRa
    lora lora lopy lopy lorawan otaa ttn
    @jmarcelino Thanks, it works!
  • LoPy and custom PCB with L76-L GPS module
    lopy gps quectel i2c i2c bus error
    @seb No luck with pull up resistors. There is also garbage when connected on P22/P21. PyTrack connected to the same pins with the same settings goes smooth. While connecting our L76-L there is no response on I2C ;-( only garbage response for i2c.scan(). Maybe you reconfigure L76-L chip through UART after mounting ? Will try to connect oscilloscope and/or logic analyzer
  • Pytrack usage?
    pytrack
    philwilkinsonP
    hey @misterlisty great to hear you are trying to interact with the sensors on the PySense. I have found that watching Alex's Corner Week 7 video on YouTube was the best introduction, together with the basic main.py document on the GitHub and reading the datasheets of course! good luck and don't forget to post your project back on the forum! Phil
  • [LoPy on AS923] Channel, DR and other selections required
    lopy as923 otaa gateway asia
    Hello @jmarcelino I have currently set up a nano gateway and several nodes (with LoPy) on the 868MHz using the EU868. From what I understand, AS923 is supposed to be used, but there are no strict regulations on the frequencies around 868MHz as of today. It would be better to work on the 923MHz frequency, thus I am currently wondering if anyone has gotten any success on 923MHz, or AS923. When I tried to replicate the EU868 to the AS923, I couldn't get the TTN to display any values other than a random value to pop up only once. I was wondering if anyone with success or failures can share their experience. [image: 1519737904112-lopy-resized.png]
  • Boot Mode through software?
    @seb Isn't the tenet just sending a characater string when you press cntrl-f?
  • LoraWAN packet performance?
    lorawan otaa
    @misterlisty it's an optional parameter on the LoRa constructor which enables ADR (adaptive data rate), which is a LoRaWAN features which enables the node and network to adjust parameters (the most important being the data rate, but channels lists as well). Some MAC commands sent by the network are only honoured by the LoPy if ADR is enabled. However @jmarcelino says the network doesn't send those commands anyway, so it may not be useful. Also note that the current firmware version does not correctly preserve channel masks during deep sleep.
  • ABP mode and frame counters
    lora lopy
    18
    Wow. This is really a great debugging technique @robert-hh :)
  • I need working code for LoRaWAN
    lorawan otaa lopy
    @rachelsimida I gave up. I have my LoPy for 1 year and I cannot find a single working code that reads a sensor (dht22 for example) and sends it to the things network.
  • LoRa on 2 LOPYs plus serial
    lopy serial lora loramac
    @monersss Can you post a sample of the file stored on the SD card? I programmed the first lopy to constantly send hello, and this was my result: Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello ...
  • Problem joining TTN in Australia with OTAA using a LoPy 4
    lopy4 ttn join otaa
    15
    philwilkinsonP
    @jmarcelino thanks for the clear explanation. It would be really useful if you could put this small section of code on the Getting Started section of Pycom's LoPy documentation for those who are connecting to TTN; the most popular LoRa network in Australia/New Zealand region. I will try and post something in The Things Network Australia Community page too. If you would prefer, I can raise it through GitHub, but I suspect your ability to change the Pycom documentation is much quicker! thanks again for your help Jose. Also, I really enjoyed your talk on The Things Network conference
  • deepsleep maximum time
    deepsleep
    22
    @jcaron Sorry, yes you are correct, looks like I need a stronger morning coffee! @combaindeft The Pytrack has the same functionality as the deepsleep shield built in, the example code should be very similar and can be found here: https://docs.pycom.io/chapter/pytrackpysense/apireference/sleep.html
  • LOPY1.0 with new firmware unable to connect to TTN
    lopy ttn firmware update
    philwilkinsonP
    anyone reading this. please refer to: Problem joining TTN in Australia with OTAA using a LoPy 4 post on the LoPy section of the forum. The solution to this issue seems to be to restrict the channels of the AU915 regional settings.
  • How to connect a LoPy to a moisture sensor?
    lopy sensor sen0193 moisture sensor
    15
    @robert-hh Thanks for your reply. I only have two sensors at hand now. No matter which one I use, it's ok. Since the principle is completely different. For the two sensors, do you familiar with them? Can you teach me some direction about how to program if you know. It's hard to find the same topic in the website and I am extremely confused now. Thanks! This is the image of the sensor, which provided by my supervisor.[image: 1519505208052-hc-sr04-sonar-sensor.jpg] [image: 1519505214245-ultrasonic_6.png]
  • LoRa receive windows
    lora
    @jcaron Now I have set the parameter in the Lora Stack for timing error to 100ms, which seems to give proper joins.
    What is the ETA for the board?
