  • Announcements regarding our community
    3 Topics
    @jirkakrepl said in New Pybytes firmware 1.18.1.r9 (Experimental LTE support): If your LTE configuration is correct, your device with a Simcard should connect to Pybytes using LTE. Then Terminal and Flash OTA update should work too. Awesome, I'll try it out soon, thanks! LTE OTA was only thing holding us back from a production release.
  • Discussion for Feature Request and Future Additions to Pybytes
    15 Topics
    i am interested in your post, but can you share more detail
  • Discussion for Pybytes Beta Support and Assistance
    158 Topics
    Åke ForslundÅ
    Now it seems to be back up.
  • no signal found in pybytes
    @Akshaya-Korrapati Pycom Inc went bankrupt about two years ago. There is no one left for support or further development. Only some servers are still online, whoever pays for power and Internet access.
  • Pybytes Learning Resources
  • How to remove pybytes from WiPy
    Hello, i think you should use pycom firmware update tool in order to change stack. see the following link https://docs.pycom.io/updatefirmware/device/.
  • Hidden connectivity
  • pybytes no longer working
    So known problem and pray that it gets back up. Thanks for replying Robert
  • what about PyMesh firmware update?
    15
    hi Pycom - I have a large project depending on this working - we want to do species call identification using AI in the field - but first of all the mesh needs to work. I am super frustrated as I have been asking about this now for 2 months and there has been no solution or even communication with you to assist me get this working. I have posted details in the support ticket showing that the mesh license is not installed when the device is being setup. Please can you give us some support to make this work very soon. thanks, Garth
  • Send an HEX array to a sensor and get an HEX response
  • Find a Pycom Expansion Board 3.0
    @Meric-NESSANGE The main question is why do you need expansion board, only for flash? If yes, you can replace it by TTL USB/UART converter (look only if it support 3V3 voltage). look at my old post https://forum.pycom.io/post/7176
  • Pybytes Project Release Error
  • Some questions on Pybytes release deployment
    I have the same problem (GPy 1.0, Expansionboard 3.1, FW 1.20.2r4, PyBytes 1.6.1).
    Hello, I'm trying to provision my new FiPy devices, and I get exactly the same error: [ 70.320] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments [ 89.743] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments [ 109.000] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments [ 127.997] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments [ 147.543] [1073517588] /v2/register-sigfox returned response: registerSigfoxDevice is missing some arguments Unable to provision Sigfox! Please try again. Activation failed! I'm not using Sigfox nor Lora for the moment. Can you help me register correctly my devices on PyBytes? Thanks.
  • Pycom is not connected to pybytes after uppdate
    ahmadelmasriA
    Hi @popescu-Cristina, Please make sure you restart the device if you did provision using the in-browser app. let me know if the issue is still available so we can take a deeper look. Have a nice day, Best Regards,
  • getMessages doesn't retrieve messages for the given device
    ahmadelmasriA
    Hi @Tamim-Jabr, Thank you for reporting the issue. We will take a look and try to fix it. Have a nice day. Best Regards, Ahmad El Masri
  • Online Firmware Updater COM port Configuration
    Hi Team, Any luck to solve mentioned issue while configuring COM port using Online Firmware Updater? Thanks Kiran
  • Register 1nce simcard in Pybytes
    @ahmadelmasri Thanks for quick reply. Yes I see it is showing all my SIMs now. Finally I am able to connect and use my 1NCE SIM with GPY in USA.
  • Alerting on Gateway Node unreachability
  • Properly detecting and reconnecting to Pybytes
