  • Announcements regarding our community
    3 Topics
    @jirkakrepl said in New Pybytes firmware 1.18.1.r9 (Experimental LTE support): If your LTE configuration is correct, your device with a Simcard should connect to Pybytes using LTE. Then Terminal and Flash OTA update should work too. Awesome, I'll try it out soon, thanks! LTE OTA was only thing holding us back from a production release.
  • Discussion for Feature Request and Future Additions to Pybytes
    15 Topics
    i am interested in your post, but can you share more detail
  • Discussion for Pybytes Beta Support and Assistance
    158 Topics
    Åke ForslundÅ
    Now it seems to be back up.
  • No more local connection after Pybytes
    In the meantime, it has been documented ;) http://docs.pycom.io/firmwareapi/pycom/pycom/#pycompybytes_on_boot Soon, it will be in the Pybytes section as well Gijs
  • Pymaps
    Hi, If the device is connected to pybytes, using the update location button will update the location in the map. You can find the map in the dashboard of the device. To send a custom location, you should be able to use the following function: pybytes.send_custom_location(), but it appears to not work (yet)
  • Fipy, not enter to main.py using pybytes and LTE
    @Gijs I found the issue! The GPy was connected to my guest wifi which apparently has a firewall that blocks all non-websurfing and -email traffic (probably by only allowing ports 80 and 443). Connecting it to my main wifi or disabling this firewall let the GPy start up. It would be nice if Pybytes still continues booting up even if it can not connect to the MQTT server.
  • Using builtin pybytes mqtt client in user code
    @ShanevanJ BUMP - keen to do this as well
  • Accessing SD card via Pybytes (follow up)
    @VST-Admin Funny, reading back after another posting I just made and realized suddenly I was talking to myself. Either Pycom never reads their forums or they are not seriously interested in business.
  • Pybtes Amazon IoT integration missing example of use
    May be I was too optimistic, I can publish but I can't subscribe
  • Pybytes.pycom.io notifications - how does this work?
  • Updating FiPy modem firmware for NB-IoT
    Thanks very much @Gijs! I've managed to make it work
  • Webhooks - Send Data to Device
  • Pycom Chirpstack server +Pygate
    I have gone throught the tutorial of pygate with chirpstack setup (https://docs.pycom.io/pybytes/networks/lora/chirpstack/) and have done the process of addign gateway a few times now. Under the network server setting of adding a gateway, I get pycom as the only option. Gateway ID is the same ID I am using which I used to get my pygate connected to TTN. But my pygate never connects to pycom chirpstack NS. The last activity says Never. There are no errors on my pygate as well [image: 1596009564619-ba767f75-b3b9-4716-9b58-33aa787d7ef6-image.png]
  • LoPy Pybytes - LoRa OTAA Connection Failed
    Yes, I have a gateway set up to TTN that works in the same room
  • Integration with Google Cloud doesn't work
    ahmadelmasriA
    Hi @bruyn, Kindly note that this has been solved. if you face any other issue I am happy to help. Thank you for reporting that. Best Regards, Ahmad El Masri
  • board goes to sleep befote it sends out data to pybytes
  • TTN EU router And PyBytes
    @ahmadelmasri Thanks for your support on this. Yes everything is working now, I just got a duplication of the "Signal 1" in my dashboard. But messages are coming via LoRaWAN and device is online, Thank you again ! [image: 1589985666419-d5f427cb-2c45-4f34-94b2-cbe0f353b59f-image.png]
  • How to use webhook integration? Any examples for the documentation?
    @VST-Admin Im not sure if this is the final answer or not, but I have discovered that the integration does not like a \r in the data. my data extractions were adding a Carriage Return by mistake. I could send any data I wanted to through the integration EXCEPT the variable containing the string I needed. I then had it echo that string as an array of bytes and then I could see there was an additional \r at the end. I removed it and the line started working through the integration immediately. I really wish something like this was documented, so I wouldn't literally lose days of work.
  • String vs Byte Array
  • OTA firmware update not working for 1.20.2.rc7
    Hi @troy-salt I tried the OTA firmware update on WiPy from 1.20.1.r2 to 1.20.2.r7 using OTA firmware update example and the update worked fine. Please refer to this example (https://docs.pycom.io/tutorials/all/ota/) for the exact steps to perform an OTA update. The image file that you have in the flash seems to be corrupt. Make sure that the file is written correctly.
  • BLE connection in FiPy with pygatt
    @brugues isn’t this using Classic Bluetooth rather than Bluetooth Low Energy (BLE)? Even though the ESP32 supports both, I believe Pycom firmware only supports BLE.
  • How many devices can Pybyes support?
  • Sigfox Callback failing to send to pybytes
    @plsecker Can someone just post the Callback url they have for a Sigfox device? Mine (above) has been provisioned as: https://sigfoxbridge.pybytes.pycom.io/sigfox/callback (its listed under Devicetypes|Callbacks). Bit bemused as to the lack of help on this. No response from Pycom either.
